Getting an error with cpu_set_t,
pgcc -c -I./Sources. -I/home/armnlib/ssm/all/include -I/opt/compilers/pgi/linux86-64/12.4/include -I/cm/shared/apps/gcc/4.4.6/include -I/cm/shared/apps/mvapich2/pgi/64/1.6/include -fpic -D_REENTRANT -I. -I/home/armnlib/ssm/infrastructure_1.0_linux24-x86-64/share/armnlib/include -I/home/armnlib/ssm/infrastructure_1.0_linux24-x86-64/share/armnlib/include/Linux_x86-64_pgi10xx -I. -O2 -D__x86_64 -DWITHOUT_OpenMP f90_threads.c
PGC-S-0040-Illegal use of symbol, cpu_set_t (/opt/compilers/pgi/linux86-64/12.4/include/sched.h: 82)
PGC-W-0156-Type not specified, 'int' assumed (/opt/compilers/pgi/linux86-64/12.4/include/sched.h: 82)
PGC-S-0040-Illegal use of symbol, cpu_set_t (/opt/compilers/pgi/linux86-64/12.4/include/sched.h: 86)
PGC-W-0156-Type not specified, 'int' assumed (/opt/compilers/pgi/linux86-64/12.4/include/sched.h: 86)
PGC/x86-64 Linux 12.4-0: compilation completed with severe errors
It seems like PGI has it’s own sched.h, and it’s there that this is failing.
Any idea how cpu_set_t could not get defined? There’s a definition for it in /usr/include/bits/sched.h, but that’s there only place I’ve found it. I’ve read that if I have stdlib included (and I do) that it should be fine…
I’m on a CentOS 6.2 Linux box, with PGI 12.4 86x64
