CPU utilization using deepstream on Jetson AGX
• Hardware Platform (Jetson / GPU) Jetson
• DeepStream Version 6.2
• JetPack Version (valid for Jetson only) 5.1
• TensorRT Version 8.5
I am using deepstream python to build inference pipeline on Jetson AGX board. The CPU utilization keeps increasing all the time exceeding 100%. The issue is cause by frame copy in probe function.
            frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
            frame_copy = np.array(frame, copy=True, order='C')
            frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGR)
I have tried to add :
pyds.unmap_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
but still have the same issue.
The function of this code is to transfer memory from the GPU to the CPU, and then all the data is processed on the CPU by OpenCV. This puts a heavy load on the CPU.
Is there any way to copy the frame without that heavy load. The CPU utilization keep increasing without stop.
You may refer to our demo to use cupy deepstream_imagedata-multistream_cupy.py.
Thank you the issue was because of frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGR) function and using numpy to convert the color format solved it.
