CPU1 & 2 shutdown with flashing screen
I have a problem regarding the CPU shutdown and I can not open the Jetson.
I uploaded a picture with the command lines I get when I start the Jetson.
I also tried to switch to console mode (ctr + alt + F1/F2/F6) without succes.
The last thing I was able to do with the Jetson was to record a video and then the storage capacty was almsot full and it crashed.
How can I solve this problem ?
Thank you for your help
What you saw on the monitor does not matter. CPU shutdown is normal behavior (because you have other cpu cores there)
Please dump the serial console log and see if you can still operate with the board.
Just some added trivia: Pretty much all multi-core systems boot on CPU0, and do not enable the other CPUs until later on in boot.
