CR2032 Battery connect
Hi, we want to connect a CR2032 battery to Nano, so that it can record the real-time even we disconnect the power supply. But we need your help to point out where the battery should be connected? And if you can give us some FW(driver) support that will be better.
Please check OEM DG and reference schematic, the pin 235 is for this. No fw needed.
