I am using Isaac SDK 2019.3 on a desktop machine (Ubuntu 18.04)
I’m following the instructions reported in the manual (https://docs.nvidia.com/isaac/isaac/doc/getting_started.html?highlight=gdb) to debug an application, i.e.
bob@desktop:~/isaac$ bazel build -c dbg //apps/samples/pose_tensorrt_inference
bob@desktop:~/isaac$ gdb --args bazel-bin/engine/alice/tools/main --app apps/samples/pose_tensorrt_inference/pose_tensorrt_inference.app.json
However, when I use gdb in debug mode, I always get the same assertion failure on ALL the applications. Please note that if I compile the application in release mode, everything works, but then I have no symbols inside gdb.
I would like to know if you are experiencing the same problem too, or if it is a problem on my installation.
Here is the dump of gdb, which seems somehow related to boost::lockfree::queue
gdb --args ./bazel-bin/engine/alice/tools/main --app apps/flatsim/flatsim.app.json
GNU gdb (Ubuntu 8.1-0ubuntu3.2) 8.1.0.20180409-git
Copyright © 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later http://gnu.org/licenses/gpl.html
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type “show copying”
and “show warranty” for details.
This GDB was configured as “x86_64-linux-gnu”.
Type “show configuration” for configuration details.
For bug reporting instructions, please see:
http://www.gnu.org/software/gdb/bugs/.
Find the GDB manual and other documentation resources online at:
http://www.gnu.org/software/gdb/documentation/.
For help, type “help”.
Type “apropos word” to search for commands related to “word”…
Reading symbols from ./bazel-bin/engine/alice/tools/main…(no debugging symbols found)…done.
(gdb) run
Starting program: /home/user1/.cache/bazel/_bazel_user1/720d1ce4d0169d46a807b418dc594c19/execroot/com_nvidia_isaac/bazel-out/k8-dbg/bin/engine/alice/tools/main --app apps/flatsim/flatsim.app.json
[Thread debugging using libthread_db enabled]
Using host libthread_db library “/lib/x86_64-linux-gnu/libthread_db.so.1”.
main: external/boost/boost/lockfree/queue.hpp:188: boost::lockfree::queue<T, Options>::queue() [with T = long unsigned int; Options = {}]: Assertion `has_capacity’ failed.Program received signal SIGABRT, Aborted.
__GI_raise (sig=sig@entry=6) at …/sysdeps/unix/sysv/linux/raise.c:51
51 …/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb)
