I am able to connect and launch just fine, but when I try to capture I get a crash in the program. Here are some useful bits from GDB:
Program received signal SIGSEGV, Segmentation fault.
(gdb) frame 0
#0 0x0000003e270337a5 in XPending (dpy=0x76e48c0) at Pending.c:51
51 LockDisplay(dpy);
(gdb) bt
#1 0x00007ffff6e9cf18 in ?? () from /home/amelcher/.tgd/libs/libNvidia_gfx_debugger.so
#2 0x00007ffff6ce2988 in ?? () from /home/amelcher/.tgd/libs/libNvidia_gfx_debugger.so
#3 0x00007ffff6ce2a4d in ?? () from /home/amelcher/.tgd/libs/libNvidia_gfx_debugger.so
#4 0x00007ffff6ce6720 in ?? () from /home/amelcher/.tgd/libs/libNvidia_gfx_debugger.so
#5 0x00007ffff69f79ed in ?? () from /home/amelcher/.tgd/libs/libNvidia_gfx_debugger.so
#6 0x00007ffff6e6ce3c in ?? () from /home/amelcher/.tgd/libs/libNvidia_gfx_debugger.so
#7 0x00000000016c3c50 in hpl::cLowLevelGraphicsSDL::SwapBuffers
#8 0x00000000011bbfb0 in hpl::cEngine::Run
#9 0x0000000000fecab8 in cLuxBase::Run
#10 0x0000000000f0a550 in hplMain
#11 0x00000000016dd9c6 in main
(gdb) list
46 }
47
48 int XPending (register Display *dpy)
49 {
50 int ret_val;
52 if (dpy->qlen)
53 ret_val = dpy->qlen;
54 else
55 ret_val = _XEventsQueued (dpy, QueuedAfterFlush);
And some system information:
Operating System Version:
“Fedora release 19 (Schrödinger’s Cat)” (64 bit)
Kernel Name: Linux
Kernel Version: 3.14.27-100.fc19.x86_64
X Server Vendor: Fedora Project
X Server Release: 11404000
X Window Manager: GNOME Shell
Video Card:
Driver: NVIDIA Corporation GeForce GT 650M/PCIe/SSE2
Driver Version: 4.4.0 NVIDIA 331.67
OpenGL Version: 4.4
Desktop Color Depth: 24 bits per pixel
Monitor Refresh Rate: 59 Hz
VendorID: 0x10de
DeviceID: 0xfd5
Number of Monitors: 1
Number of Logical Video Cards: 2
Primary Display Resolution: 1680 x 1050
Desktop Resolution: 1680 x 1050
Primary Display Size: 13.03" x 8.15" (15.35" diag)
33.1cm x 20.7cm (39.0cm diag)
Primary Bus: PCI Express 16x
Primary VRAM: 1024 MB
Supported MSAA Modes: 2x 4x 8x 16x
