Crash on startup
kit_20220510_120354.log (934.5 KB)
I am getting a crash when starting create beta, my laptop is below the minimum requirement but I can run Isaac perfectly fine.
Attached is the log, if you can help me find a solution that would be great.
Hello @tlemarec! From your logs, it looks like you are running out of VRAM on your RTX 3050 Laptop. The HydraRenderer is failing to execute due to Insufficient VRAM
You can take a look at our minimum requirements for Create here: Technical Requirements — Omniverse Create documentation
Thanks, we figured that. Any idea why I can run Isaac but not Create ?
They both have the same requirements. Maybe there is a workaround.
