I have no idea why it doesn’t work properly, but my Jetson Nano is unable to handle object detection when using the GPU. I use the DNN module of OpenCV to run a MobileNetSSD-v2 model. Everything on the software side is fine, I build OpenCV with Cuda support and sometimes, the detection works for like 5 seconds or so. However each time, either at the beginning or a few seconds in, my Jetson Nano crashes and just turns off.
- I get no error message.
- I check with $ jtop and it doesn’t seem like a memory shortage is the case.
- I use 5V-4A DC power supply.
- No, for me, switching to 5W mode is not an option. I need fast framerates and to use all 4 CPU-Threads for multithreading purposes simultaneously.
I really need to get this system up and running, so is there any suggestion how to solve the problem? Thanks!
