I was following this guide to test my camera
Jetson developer kits have multiple interfaces for connecting a camera, including USB, Ethernet, and MIPI CSI-2. This guide will show you how to quickly get up and running with CSI and USB cameras. By following this guide, you’ll be able to...
I can see preview display on my screen, take a picture and save to my disk. Everything was working perfectly.
But when I record a video, using command
nvgstcapture-1.0 --mode=2 --camsrc=0
I got error
bitrate = 4000000
Encoder Profile = High
Encoder control-rate = 1
Encoder EnableTwopassCBR = 0
opening in blocking mode
segmentation fault (core dumped)
No matter change the mode from still mode to video mode, or simply type nvgstcapture-1.0 --mode=2 --camsrc=0, same error keep poping up.
Any idea would be appreciated.
hello djjbxxz,
what’s the camera type you’re using, is it CSI camera or USB camera?
in addition, may I know which JetPack release you’re working on, please check release tag for details.
for example, $ cat /etc/nv_tegra_release
thanks
I am using an USB Camera and jetpack release 5.1.
system
closed
September 27, 2021, 1:06pm
#7
