Hello, when launching Isaac Sim from the Omniverse launcher, I encountered some crashes and had no idea how to fix them.
The test kit runs well and the Compatibility Checker app shows that everything is good. Can I have some help?
These error messages pertain to issues with the X Window System (X11) and its XCB (X Protocol C-language Binding) library. You may want to try updating or reinstalling the X11 libraries and extensions.
[1.005s] [ext: omni.kit.telemetry-0.5.0] startup
[xcb] Unknown sequence number while appending request
[xcb] You called XInitThreads, this is not your fault
[xcb] Aborting, sorry about that.
[xcb] Extra reply data still left in queue
[xcb] This is most likely caused by a broken X extension library
[1.077s] [ext: omni.pip.cloud-1.1.3] startup
2025-01-21 04:13:09 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2025-01-21 04:13:09 [14ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘/home/rvl-urop/UROP/UROP_wsy/omniverse/Kit/Isaac-Sim/4.2/823311cb-dd8f-4e93-a16ce484-af21b227.dmp.zip’ for upload.
2025-01-21 04:13:09 [94ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/home/rvl-urop/UROP/UROP_wsy/omniverse/Kit/Isaac-Sim/4.2/823311cb-dd8f-4e93-a16ce484-af21b227.dmp’ with 10 retries remaining.
2025-01-21 04:13:09 [95ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file ‘/home/rvl-urop/UROP/UROP_wsy/omniverse/Kit/Isaac-Sim/4.2/823311cb-dd8f-4e93-a16ce484-af21b227.dmp.toml’ with 10 retries remaining.
2025-01-21 04:13:39 [30,258ms] [Warning] [carb.crashreporter-breakpad.plugin] … waiting for PID 68677 to exit …
