Crash when using RTP_BUFFER_TYPE_CUDA_LINEAR buffer type in optix prime
I’ve constructed a model object from a PrimeMesh object like this using RTP_BUFFER_TYPE_CUDA_LINEAR (slight modified primeSimplePP):
void SetModel(string path)
		contextType = RTP_CONTEXT_TYPE_CUDA;
		bufferType = RTP_BUFFER_TYPE_CUDA_LINEAR;
		context = Context::create(contextType);
		loadMesh(path, mesh);
		cudaMalloc((void**)&indices, sizeof(int3) * mesh.num_triangles);
		cudaMalloc((void**)&vertices, sizeof(float3) * mesh.num_vertices);
		cudaMemcpy(indices, mesh.getVertexIndices(), sizeof(int3) * mesh.num_triangles, cudaMemcpyHostToDevice);
		cudaMemcpy(vertices, mesh.getVertexData(), sizeof(float3) * mesh.num_vertices, cudaMemcpyHostToDevice);
		model = context->createModel();
		model->setTriangles(mesh.num_triangles, RTP_BUFFER_TYPE_CUDA_LINEAR,indices,
			mesh.num_vertices, RTP_BUFFER_TYPE_CUDA_LINEAR, vertices);
		model->update(0);
but it crashed at model->update(0) line.
The RTP_BUFFER_TYPE_CUDA_LINEAR buffertype works fine with ray & hit arrays in my previous experiments.
Same as https://devtalk.nvidia.com/default/topic/1016611/?comment=5178511
Could you please provide more information on your system configuration?
OS version, installed GPU(s), display driver version, OptiX version, CUDA toolkit version.
If that was not with the latest OptiX 4.1.1 release, please try that.
OptiX version is 4.11 release. Windows 10, Visual Studio 2017, and this is the output of deviceQuery.exe:
deviceQuery.exe Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 2 CUDA Capable device(s)
Device 0: "GeForce GTX 1080"
  CUDA Driver Version / Runtime Version          9.0 / 9.0
  CUDA Capability Major/Minor version number:    6.1
  Total amount of global memory:                 8192 MBytes (8589934592 bytes)
  (20) Multiprocessors, (128) CUDA Cores/MP:     2560 CUDA Cores
  GPU Max Clock rate:                            1734 MHz (1.73 GHz)
  Memory Clock rate:                             5005 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 2097152 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  2048
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     Yes
  Integrated GPU sharing Host Memory:            No
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  CUDA Device Driver Mode (TCC or WDDM):         WDDM (Windows Display Driver Model)
  Device supports Unified Addressing (UVA):      Yes
  Supports Cooperative Kernel Launch:            No
  Supports MultiDevice Co-op Kernel Launch:      No
  Device PCI Domain ID / Bus ID / location ID:   0 / 1 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
Device 1: "GeForce GTX 1080"
  Warp size:                                     32
  Device PCI Domain ID / Bus ID / location ID:   0 / 3 / 0
  Compute Mode:
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 9.0, CUDA Runtime Version = 9.0, NumDevs = 2, Device0 = GeForce GTX 1080, Device1 = GeForce GTX 1080
Result = PASS
