I enabled the second mmc1 interface as
mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
on the Jetson Nano Developer Kit P3448 (16gb eMMC). After the update to JetPack 4.6.3 II am starting to get the following error (below). It appears that only single block read works?
Any help appreciated
D
[ 11.124925] mmc1: Data CRC error
[ 11.128156] sdhci: =========== REGISTER DUMP (mmc1)===========
[ 11.133980] sdhci: Sys addr: 0x00000020 | Version: 0x00000303
[ 11.139804] sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000006
[ 11.145627] sdhci: Argument: 0x00000800 | Trn mode: 0x0000003b
[ 11.151449] sdhci: Present: 0x01fb0000 | Host ctl: 0x00000013
[ 11.157271] sdhci: Power: 0x00000001 | Blk gap: 0x00000000
[ 11.163092] sdhci: Wake-up: 0x00000000 | Clock: 0x00000007
[ 11.168912] sdhci: Timeout: 0x0000000e | Int stat: 0x00000000
[ 11.174733] sdhci: Int enab: 0x02ff100b | Sig enab: 0x02fc100b
[ 11.180554] sdhci: AC12 err: 0x00000000 | Slot int: 0x00000000
[ 11.186375] sdhci: Caps: 0x376cd08c | Caps_1: 0x10006f77
[ 11.192197] sdhci: Cmd: 0x0000123a | Max curr: 0x00000000
[ 11.198016] sdhci: Host ctl2: 0x00003001
[ 11.201932] sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x00000000ffefe410
[ 11.208470] sdhci: ===========================================
[ 11.214551] mmcblk1: error -110 sending stop command, original cmd response 0x900, card status 0x400900
[ 11.214560] mmcblk1: error -84 transferring data, sector 2048, nr 32, cmd response 0x900, card status 0x0
[ 11.224200] mmcblk1: retrying using single block read
