I have been trying out Omiverse Create and during 1 day it froze more than 20 times. Exporting Meshes / Textures from Substance Painter. Even just switching the lightning caused a freeze.
I’m running Win 11 on a Threadripper Pro 64 Core, 256 GB Ram, Quad 3090, and a Raid 0 with 4 M2 SSD, 2 TB each.
Should I try Win 10, or what could potentially be the issue?
I also tried 2022.2.0 with the same problem, the app is freezing on almost anything I try to do.
Hello @3dpxl! With your computer specs, this should not be happening. Could you attach a copy of your logs from Create usually found here: C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Create. Your logs will hopefully have more information one what the issue might be.
Hello @3dpxl! The dev team asked me to have you run one more test for them if you can. Follow the same instructions as before but try this command a the prompt run: omni.create.bat --/renderer/multiGpu/maxGpuCount=3 (or 2 as well)
If you can let us know what your system reports, that will help us improve this issue in future builds!
