Hi Everyone,
So I am trying to build a new docker image by using the base docker image of 6.2-devel. I have modified the nvmsgconv and in the Docker file, I am trying to replace the files and build the new ‘libnvds_msgconv.so’. The docker images builds successfully but when I try to use the plugin in test-5 app I get the following error:
Hi There,
Thanks for the reply. No I didn’t remove any function. I just added some code in generate_dsmeta_message_minimal function. and then after that I rebuild the test-5 application.
But when I run deepstream-6.2-devel docker and then mount the above two files and make them inside container, then it worked fine.
I am not sure why this issue comes in when I build it from dockerfile
What you mean is that it is ok to compile nvds_msgconv in Docker's bash and then run test-5, but an error will be reported when run Docker build -f dockerfile, right?
for the readelf i got the following output:
139: 0000000000000000 0 NOTYPE GLOBAL DEFAULT UND generate_dsmeta_message_protobuf
2483: 0000000000000000 0 NOTYPE GLOBAL DEFAULT UND generate_dsmeta_message_protobuf
the test 5 app, I run the docker in interactive mode and build the test 5 app inside it. Sure I have attached all the three files : nvdsmeta.h, ds_meta_payload.cpp and tes5 app main file(renamed as app.c) dsmeta_payload.txt (16.5 KB) nvdsmeta.txt (40.6 KB) app.txt (53.4 KB)
My flow of work
I build the docker image by docker file
run the image in interactive mode
make the test5 app(kafka already up and running with topic created)
You did delete the generate_dsmeta_message_protobuf function in dsmeta_payload.cpp
Because -Wl,-no-undefined is missing from CFLAGS, there is no error during compilation.
In addition, when you run it in docker bash, libnvdsgst_msgconv.so may already be in the blacklist, you can use
gst-inspect-1.0 -b view
Or run the install.sh in /opt/nvidia/deepstream/deepstream to clean cache.
This issue will reappear.
You can modify the Makefile of /opt/nvidia/deepstream/deepstream/sources/libs/nvmsgconv to the following
Hence we are closing this topic. If need further support, please open a new one. Thanks
Please restore the generate_dsmeta_message_protobuf function in the code, and then implement your own generate_dsmeta_message_minimal
