Description
I would like to create a program in python that can detect deviation in images. There are subtle deviation but still. The regular deep learning method I use is training on a lot of images with a defect and classifying those.
I want to do the opposite. I want to tell the AI that this is good. Anything else is crap. How can I do that?
Anyone knows how? Where to start? I tried openAI but it just brings back a solution that always results in 0 prediction.
Environment
TensorRT Version: Not working
GPU Type: ~
Nvidia Driver Version:
CUDA Version:
CUDNN Version:
Operating System + Version: Ubuntu 20.04
Python Version (if applicable): 3.8.10
TensorFlow Version (if applicable): Latest
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
import cv2
import numpy as np
import os
from tensorflow import keras
from tensorflow.keras.applications import ResNet50
from tensorflow.keras.applications.resnet50 import preprocess_input
# Function to load and preprocess images from a directory
def load_images_from_folder(folder):
images = []
for filename in os.listdir(folder):
if filename.endswith('.jpg') or filename.endswith('.png'):
image_path = os.path.join(folder, filename)
image = cv2.imread(image_path)
image = cv2.cvtColor(image, cv2.COLOR_BGR2RGB)
image = cv2.resize(image, (224, 224))
image = preprocess_input(image)
images.append(image)
return images
# Load the reference images from a folder
reference_images_folder = 'path/to/reference/images/folder'
reference_images = load_images_from_folder(reference_images_folder)
# Load the pre-trained ResNet50 model
base_model = ResNet50(weights='imagenet', include_top=False, input_shape=(224, 224, 3))
# Freeze the pre-trained layers
for layer in base_model.layers:
layer.trainable = False
# Add custom classification layers on top of the pre-trained model
model = keras.Sequential([
base_model,
keras.layers.GlobalAveragePooling2D(),
keras.layers.Dense(256, activation='relu'),
keras.layers.Dense(1, activation='sigmoid')
# Compile the model
model.compile(optimizer='adam', loss='binary_crossentropy', metrics=['accuracy'])
# Create labels for the reference images (all labeled as 0 for no deviation)
reference_labels = np.zeros(len(reference_images))
# Train the model with the reference images
model.fit(np.array(reference_images), reference_labels, epochs=10, batch_size=1)
# Perform inference on multiple input images
input_images_folder = 'path/to/input/images/folder'
input_images = load_images_from_folder(input_images_folder)
# Define a threshold for deviation prediction
threshold = 0.5
# Iterate over the input images
for i, input_image in enumerate(input_images):
input_image = np.expand_dims(input_image, axis=0)
# Predict deviation using the input image
prediction = model.predict(input_image)[0][0]
# Print the result
if prediction >= threshold:
print(f"Deviation detected in input image {i+1}!")
print(f"Prediction: {prediction:.4f}")
else:
print(f"No deviation detected in input image {i+1}.")
