I am using the Create 2022.3.3 version
and testing modulus extension by referring to the documents.
When running create app, the command line I used was:
~/.local/share/ov/pkg/create-2022.3.3/omni.create.sh --enable modulus_ext.core
The following extensions are autoloaded.
modulus_ext.core, modulus_ext.ui, hpcvis.vtkm_bridge.core
So far, there is no problem, but when I activate the FPGA scenario, the create app suddenly exits.
The following is the error displayed in the console.
[30.544s] [ext: modulus_scenario_fpga-22.9.0] startup
: CommandLine Error: Option 'debug-pass' registered more than once!
LLVM ERROR: inconsistency in registered CommandLine options
2023-06-12 02:03:20 [32,778ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-06-12 02:03:20 [32,778ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-06-12 02:03:20 [32,778ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 1 files into '/home/intown/.local/share/ov/data/Kit/Create.Next/2022.3/fd63d16f-be12-4109-92af4088-6d9b2871.dmp.zip' for upload.
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/home/intown/.local/share/ov/data/Kit/Create.Next/2022.3/fd63d16f-be12-4109-92af4088-6d9b2871.dmp.zip' svr:'https://services.nvidia.com/submit'
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'fd63d16f-be12-4109-92af4088-6d9b2871'
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-06-12 02:03:20 [32,970ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1686535367'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '33'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Create.Next'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.3.3-rc.15'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'hpcvis.vtkm_bridge.core-1.0.2-alpha-03,modulus_ext.core-22.9.0,modulus_ext.ui-2.0.0'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = 'Intel64 Family 6 Model 141 Stepping 1'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = '11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = 'GenuineIntel'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = '(0, 0)'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = '3840x1080'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = '2'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = '1920x1080x32bit@240Hz'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_1 = '1920x1080x32bit@60Hz'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Create Next'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = '1'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = '0x5402006'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_1 = '525.105'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = '12348205056'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_1 = '8589934592'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = 'Intel(R) UHD Graphics (TGL GT1)'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_1 = 'NVIDIA GeForce RTX 3070 Laptop GPU'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '525.105'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=),CreatePrim(prim_path=/Environment,prim_type=Xform,select_new_prim=False,create_default_xform=True),CreatePrim(prim_path=/Environment/Sky,prim_type=DomeLight,select_new_prim=False,attributes=?,create_default_xform=True),CreatePrim(prim_path=/Environment/DistantLight,prim_type=DistantLight,select_new_prim=False,attributes=?,create_default_xform=True),CreateMdlMaterialPrim(mtl_url=OmniPBR.mdl,mtl_name=Grid,mtl_path=/Environment/Looks/Grid),CreatePrim(prim_path=/Environment/Looks,prim_type=Scope,select_new_prim=False,stage=?),CreateMeshPrimWithDefaultXform(prim_path=/Environment/ground,prim_type=Plane,select_new_prim=False,prepend_default_prim=False),SetStaticCollider(path=/Environment/ground,approximationShape=convexHull),BindMaterialCommand(prim_path=/Environment/ground,material_path=/Environment/Looks/Grid,strength=?),ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 8.2642/15.3335GB, Swap: 30.5176/30.5176GB, VM: 1.71799e+10/1.71799e+10GB'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = 'ubuntu'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = '20.04.6 LTS (Focal Fossa)'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = '20.4.6'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = '1920x1080x32bit@240Hz'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = '9.721218258'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| Driver Version: 525.105.17 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | Intel(R) UHD Graphics (TGL GT1) | | | 11776 MB | 8086 | 0 |
| | | | | | 9a60 | ee98bced.. |
| 1 | NVIDIA GeForce RTX 3070 Laptop.. | Yes: 0 | | 8192 MB | 10de | 0 |
| | | | | | 249d | 92e80160.. |
| OS: Linux intown-GP66-Leopard-11UG, Version: 5.15.0-73-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: 11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz | Cores: Unknown | Logical: 16
| Total Memory (MB): 15701 | Free Memory: 12772
| Total Page/Swap (MB): 31249 | Free Page/Swap: 31249
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '2010459351834754271'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = 'default'
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
2023-06-12 02:03:20 [32,971ms] [Warning] [carb.crashreporter-breakpad.plugin] upload_file_minidump = '/home/intown/.local/share/ov/data/Kit/Create.Next/2022.3/fd63d16f-be12-4109-92af4088-6d9b2871.dmp.zip'
2023-06-12 02:03:24 [36,417ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: '/home/intown/.local/share/ov/data/Kit/Create.Next/2022.3/fd63d16f-be12-4109-92af4088-6d9b2871.dmp.zip', code:200, response:
2023-06-12 02:03:24 [36,417ms] [Warning] [carb.crashreporter-breakpad.plugin] 00000187348fe6bd-24ac2a
2023-06-12 02:03:24 [36,417ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/home/intown/.local/share/ov/data/Kit/Create.Next/2022.3/fd63d16f-be12-4109-92af4088-6d9b2871.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save).
2023-06-12 02:03:24 [36,417ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/home/intown/.local/share/ov/data/Kit/Create.Next/2022.3/fd63d16f-be12-4109-92af4088-6d9b2871.dmp.zip'
2023-06-12 02:03:24 [36,417ms] [Error] [carb.crashreporter-breakpad.plugin] the dump file was deleted due to a successful upload. Its originalsize was 405728 bytes and was readable.
2023-06-12 02:03:24 [36,424ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 2974 thread 2974
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = 'fd63d16f-be12-4109-92af4088-6d9b2871'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1686535367'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '33'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Create.Next'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.3.3-rc.15'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = 'hpcvis.vtkm_bridge.core-1.0.2-alpha-03,modulus_ext.core-22.9.0,modulus_ext.ui-2.0.0'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuId = 'Intel64 Family 6 Model 141 Stepping 1'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuName = '11th Gen Intel(R) Core(TM) i7-11800H @ 2.30GHz'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] cpuVendor = 'GenuineIntel'
2023-06-12 02:03:24 [36,424ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopOrigin = '(0, 0)'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] desktopSize = '3840x1080'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] displayCount = '2'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_0 = '1920x1080x32bit@240Hz'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] displayRes_1 = '1920x1080x32bit@60Hz'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Create Next'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] externalBuild = '1'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_0 = '0x5402006'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuDriver_1 = '525.105'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_0 = '12348205056'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] gpuVRAM_1 = '8589934592'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_0 = 'Intel(R) UHD Graphics (TGL GT1)'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] gpu_1 = 'NVIDIA GeForce RTX 3070 Laptop GPU'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '525.105'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=),CreatePrim(prim_path=/Environment,prim_type=Xform,select_new_prim=False,create_default_xform=True),CreatePrim(prim_path=/Environment/Sky,prim_type=DomeLight,select_new_prim=False,attributes=?,create_default_xform=True),CreatePrim(prim_path=/Environment/DistantLight,prim_type=DistantLight,select_new_prim=False,attributes=?,create_default_xform=True),CreateMdlMaterialPrim(mtl_url=OmniPBR.mdl,mtl_name=Grid,mtl_path=/Environment/Looks/Grid),CreatePrim(prim_path=/Environment/Looks,prim_type=Scope,select_new_prim=False,stage=?),CreateMeshPrimWithDefaultXform(prim_path=/Environment/ground,prim_type=Plane,select_new_prim=False,prepend_default_prim=False),SetStaticCollider(path=/Environment/ground,approximationShape=convexHull),BindMaterialCommand(prim_path=/Environment/ground,material_path=/Environment/Looks/Grid,strength=?),ToggleExtension(ext_id=modulus_scenario_fpga-22.9.0,enable=True)'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 8.2642/15.3335GB, Swap: 30.5176/30.5176GB, VM: 1.71799e+10/1.71799e+10GB'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] osDistro = 'ubuntu'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] osName = '20.04.6 LTS (Focal Fossa)'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] osVersion = '20.4.6'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] primaryDisplayRes = '1920x1080x32bit@240Hz'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] startup_time = '9.721218258'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| | | | | | Device-ID | UUID |
| | | | | | 9a60 | ee98bced.. |
| | | | | | 249d | 92e80160.. |
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '2010459351834754271'
2023-06-12 02:03:24 [36,425ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = 'default'
2023-06-12 02:03:24 [36,425ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 2974 backtrace follows:
2023-06-12 02:03:24 [36,526ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
/usr/bin/addr2line: DWARF error: section .debug_info is larger than its filesize! (0x93ef57 vs 0x530ea0)
2023-06-12 02:03:24 [36,602ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!gsignal+0xcb (??:?)
2023-06-12 02:03:24 [36,674ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!abort+0x12b (??:?)
2023-06-12 02:03:24 [36,747ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libLLVM-12.so.1!llvm::report_fatal_error(llvm::Twine const&, bool)+0x1d9 (??:?)
2023-06-12 02:03:24 [36,822ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libLLVM-12.so.1!llvm::report_fatal_error(char const*, bool)+0x26 (??:?)
2023-06-12 02:03:24 [36,896ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libLLVM-12.so.1!LLVMParseCommandLineOptions+0xebd (??:?)
2023-06-12 02:03:24 [36,969ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libLLVM-12.so.1!llvm::cl::Option::addArgument()+0x3b (??:?)
2023-06-12 02:03:24 [37,038ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: symengine_wrapper.cpython-37m-x86_64-linux-gnu.so!PyInit_symengine_wrapper+0x39966 (??:?)
/usr/bin/addr2line: DWARF error: section .debug_info is larger than its filesize! (0xc14d2 vs 0x90ed8)
2023-06-12 02:03:24 [37,112ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: ld-linux-x86-64.so.2!_dl_rtld_di_serinfo+0x6b0a (??:?)
2023-06-12 02:03:24 [37,187ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: ld-linux-x86-64.so.2!_dl_rtld_di_serinfo+0x6c11 (??:?)
2023-06-12 02:03:25 [37,259ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libc.so.6!_dl_catch_exception+0xe5 (??:?)
2023-06-12 02:03:25 [37,330ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: ld-linux-x86-64.so.2!_dl_find_dso_for_object+0xc3f (??:?)
2023-06-12 02:03:25 [37,402ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libc.so.6!_dl_catch_exception+0x88 (??:?)
2023-06-12 02:03:25 [37,473ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: ld-linux-x86-64.so.2!_dl_find_dso_for_object+0x17a (??:?)
2023-06-12 02:03:25 [37,481ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libdl.so.2!+0x134c
2023-06-12 02:03:25 [37,552ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libc.so.6!_dl_catch_exception+0x88 (??:?)
2023-06-12 02:03:25 [37,623ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libc.so.6!_dl_catch_error+0x33 (??:?)
/usr/bin/addr2line: DWARF error: section .debug_info is larger than its filesize! (0x2bd3c vs 0x14470)
2023-06-12 02:03:25 [37,696ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libdl.so.2!dlerror+0x319 (??:?)
2023-06-12 02:03:25 [37,767ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libdl.so.2!dlopen+0x4a (??:?)
2023-06-12 02:03:25 [37,873ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libpython3.7m.so.1.0!_PyImport_FindSharedFuncptr+0x180 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/./Python/dynload_shlib.c:98)
2023-06-12 02:03:25 [37,956ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libpython3.7m.so.1.0!_PyImport_LoadDynamicModuleWithSpec+0x14a (/builds/omniverse/externals/python-build/_build/Python-3.7.13/./Python/importdl.c:132)
2023-06-12 02:03:25 [38,034ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libpython3.7m.so.1.0!_imp_create_dynamic+0x129 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:2176)
2023-06-12 02:03:25 [38,111ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:25 [38,188ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:26 [38,266ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:26 [38,344ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:26 [38,421ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:26 [38,499ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:26 [38,576ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:26 [38,654ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:26 [38,731ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:26 [38,810ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:26 [38,889ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:26 [38,967ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:26 [39,046ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:26 [39,124ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:26 [39,201ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:27 [39,278ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:27 [39,355ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:27 [39,432ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:27 [39,510ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:27 [39,589ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:27 [39,668ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:27 [39,746ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:27 [39,825ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:27 [39,903ms] [Fatal] [carb.crashreporter-breakpad.plugin] 045: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:27 [39,981ms] [Fatal] [carb.crashreporter-breakpad.plugin] 046: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:27 [40,059ms] [Fatal] [carb.crashreporter-breakpad.plugin] 047: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:27 [40,137ms] [Fatal] [carb.crashreporter-breakpad.plugin] 048: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:27 [40,217ms] [Fatal] [carb.crashreporter-breakpad.plugin] 049: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:28 [40,295ms] [Fatal] [carb.crashreporter-breakpad.plugin] 050: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:28 [40,378ms] [Fatal] [carb.crashreporter-breakpad.plugin] 051: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:28 [40,456ms] [Fatal] [carb.crashreporter-breakpad.plugin] 052: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:28 [40,534ms] [Fatal] [carb.crashreporter-breakpad.plugin] 053: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:28 [40,611ms] [Fatal] [carb.crashreporter-breakpad.plugin] 054: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:28 [40,690ms] [Fatal] [carb.crashreporter-breakpad.plugin] 055: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:28 [40,766ms] [Fatal] [carb.crashreporter-breakpad.plugin] 056: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:28 [40,845ms] [Fatal] [carb.crashreporter-breakpad.plugin] 057: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:28 [40,922ms] [Fatal] [carb.crashreporter-breakpad.plugin] 058: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:28 [41,001ms] [Fatal] [carb.crashreporter-breakpad.plugin] 059: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:28 [41,081ms] [Fatal] [carb.crashreporter-breakpad.plugin] 060: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:28 [41,158ms] [Fatal] [carb.crashreporter-breakpad.plugin] 061: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:29 [41,236ms] [Fatal] [carb.crashreporter-breakpad.plugin] 062: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:29 [41,316ms] [Fatal] [carb.crashreporter-breakpad.plugin] 063: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:29 [41,394ms] [Fatal] [carb.crashreporter-breakpad.plugin] 064: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:29 [41,474ms] [Fatal] [carb.crashreporter-breakpad.plugin] 065: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:29 [41,553ms] [Fatal] [carb.crashreporter-breakpad.plugin] 066: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:29 [41,632ms] [Fatal] [carb.crashreporter-breakpad.plugin] 067: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:29 [41,709ms] [Fatal] [carb.crashreporter-breakpad.plugin] 068: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:29 [41,786ms] [Fatal] [carb.crashreporter-breakpad.plugin] 069: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:29 [41,869ms] [Fatal] [carb.crashreporter-breakpad.plugin] 070: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:29 [41,949ms] [Fatal] [carb.crashreporter-breakpad.plugin] 071: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:29 [42,028ms] [Fatal] [carb.crashreporter-breakpad.plugin] 072: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:29 [42,108ms] [Fatal] [carb.crashreporter-breakpad.plugin] 073: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:29 [42,185ms] [Fatal] [carb.crashreporter-breakpad.plugin] 074: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:30 [42,269ms] [Fatal] [carb.crashreporter-breakpad.plugin] 075: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:30 [42,346ms] [Fatal] [carb.crashreporter-breakpad.plugin] 076: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:30 [42,424ms] [Fatal] [carb.crashreporter-breakpad.plugin] 077: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:30 [42,502ms] [Fatal] [carb.crashreporter-breakpad.plugin] 078: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:30 [42,581ms] [Fatal] [carb.crashreporter-breakpad.plugin] 079: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:30 [42,658ms] [Fatal] [carb.crashreporter-breakpad.plugin] 080: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:30 [42,735ms] [Fatal] [carb.crashreporter-breakpad.plugin] 081: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:30 [42,813ms] [Fatal] [carb.crashreporter-breakpad.plugin] 082: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:30 [42,891ms] [Fatal] [carb.crashreporter-breakpad.plugin] 083: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:30 [42,969ms] [Fatal] [carb.crashreporter-breakpad.plugin] 084: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:30 [43,047ms] [Fatal] [carb.crashreporter-breakpad.plugin] 085: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:30 [43,126ms] [Fatal] [carb.crashreporter-breakpad.plugin] 086: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:30 [43,204ms] [Fatal] [carb.crashreporter-breakpad.plugin] 087: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:31 [43,282ms] [Fatal] [carb.crashreporter-breakpad.plugin] 088: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:31 [43,360ms] [Fatal] [carb.crashreporter-breakpad.plugin] 089: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:31 [43,437ms] [Fatal] [carb.crashreporter-breakpad.plugin] 090: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:31 [43,515ms] [Fatal] [carb.crashreporter-breakpad.plugin] 091: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:31 [43,593ms] [Fatal] [carb.crashreporter-breakpad.plugin] 092: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:31 [43,671ms] [Fatal] [carb.crashreporter-breakpad.plugin] 093: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:31 [43,749ms] [Fatal] [carb.crashreporter-breakpad.plugin] 094: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:31 [43,829ms] [Fatal] [carb.crashreporter-breakpad.plugin] 095: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:31 [43,906ms] [Fatal] [carb.crashreporter-breakpad.plugin] 096: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:31 [43,984ms] [Fatal] [carb.crashreporter-breakpad.plugin] 097: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:31 [44,062ms] [Fatal] [carb.crashreporter-breakpad.plugin] 098: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:31 [44,143ms] [Fatal] [carb.crashreporter-breakpad.plugin] 099: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:31 [44,221ms] [Fatal] [carb.crashreporter-breakpad.plugin] 100: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:32 [44,299ms] [Fatal] [carb.crashreporter-breakpad.plugin] 101: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:32 [44,380ms] [Fatal] [carb.crashreporter-breakpad.plugin] 102: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:32 [44,460ms] [Fatal] [carb.crashreporter-breakpad.plugin] 103: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:32 [44,537ms] [Fatal] [carb.crashreporter-breakpad.plugin] 104: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:32 [44,614ms] [Fatal] [carb.crashreporter-breakpad.plugin] 105: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:32 [44,693ms] [Fatal] [carb.crashreporter-breakpad.plugin] 106: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:32 [44,774ms] [Fatal] [carb.crashreporter-breakpad.plugin] 107: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:32 [44,853ms] [Fatal] [carb.crashreporter-breakpad.plugin] 108: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:32 [44,933ms] [Fatal] [carb.crashreporter-breakpad.plugin] 109: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:32 [45,014ms] [Fatal] [carb.crashreporter-breakpad.plugin] 110: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:32 [45,092ms] [Fatal] [carb.crashreporter-breakpad.plugin] 111: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:32 [45,170ms] [Fatal] [carb.crashreporter-breakpad.plugin] 112: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:33 [45,248ms] [Fatal] [carb.crashreporter-breakpad.plugin] 113: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:33 [45,326ms] [Fatal] [carb.crashreporter-breakpad.plugin] 114: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:33 [45,405ms] [Fatal] [carb.crashreporter-breakpad.plugin] 115: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:33 [45,483ms] [Fatal] [carb.crashreporter-breakpad.plugin] 116: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:33 [45,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] 117: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:33 [45,641ms] [Fatal] [carb.crashreporter-breakpad.plugin] 118: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:33 [45,719ms] [Fatal] [carb.crashreporter-breakpad.plugin] 119: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:33 [45,797ms] [Fatal] [carb.crashreporter-breakpad.plugin] 120: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:33 [45,875ms] [Fatal] [carb.crashreporter-breakpad.plugin] 121: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:33 [45,953ms] [Fatal] [carb.crashreporter-breakpad.plugin] 122: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:33 [46,033ms] [Fatal] [carb.crashreporter-breakpad.plugin] 123: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:33 [46,111ms] [Fatal] [carb.crashreporter-breakpad.plugin] 124: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:33 [46,188ms] [Fatal] [carb.crashreporter-breakpad.plugin] 125: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:34 [46,267ms] [Fatal] [carb.crashreporter-breakpad.plugin] 126: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:34 [46,346ms] [Fatal] [carb.crashreporter-breakpad.plugin] 127: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:34 [46,427ms] [Fatal] [carb.crashreporter-breakpad.plugin] 128: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:34 [46,506ms] [Fatal] [carb.crashreporter-breakpad.plugin] 129: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:34 [46,584ms] [Fatal] [carb.crashreporter-breakpad.plugin] 130: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:34 [46,665ms] [Fatal] [carb.crashreporter-breakpad.plugin] 131: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:34 [46,744ms] [Fatal] [carb.crashreporter-breakpad.plugin] 132: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:34 [46,824ms] [Fatal] [carb.crashreporter-breakpad.plugin] 133: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:34 [46,902ms] [Fatal] [carb.crashreporter-breakpad.plugin] 134: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:34 [46,979ms] [Fatal] [carb.crashreporter-breakpad.plugin] 135: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:34 [47,059ms] [Fatal] [carb.crashreporter-breakpad.plugin] 136: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:34 [47,138ms] [Fatal] [carb.crashreporter-breakpad.plugin] 137: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:34 [47,217ms] [Fatal] [carb.crashreporter-breakpad.plugin] 138: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:35 [47,300ms] [Fatal] [carb.crashreporter-breakpad.plugin] 139: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:35 [47,381ms] [Fatal] [carb.crashreporter-breakpad.plugin] 140: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:35 [47,459ms] [Fatal] [carb.crashreporter-breakpad.plugin] 141: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:35 [47,537ms] [Fatal] [carb.crashreporter-breakpad.plugin] 142: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:35 [47,615ms] [Fatal] [carb.crashreporter-breakpad.plugin] 143: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:35 [47,693ms] [Fatal] [carb.crashreporter-breakpad.plugin] 144: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:35 [47,772ms] [Fatal] [carb.crashreporter-breakpad.plugin] 145: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:35 [47,849ms] [Fatal] [carb.crashreporter-breakpad.plugin] 146: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:35 [47,927ms] [Fatal] [carb.crashreporter-breakpad.plugin] 147: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:35 [48,005ms] [Fatal] [carb.crashreporter-breakpad.plugin] 148: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:35 [48,082ms] [Fatal] [carb.crashreporter-breakpad.plugin] 149: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:35 [48,160ms] [Fatal] [carb.crashreporter-breakpad.plugin] 150: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:36 [48,241ms] [Fatal] [carb.crashreporter-breakpad.plugin] 151: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:36 [48,322ms] [Fatal] [carb.crashreporter-breakpad.plugin] 152: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:36 [48,403ms] [Fatal] [carb.crashreporter-breakpad.plugin] 153: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:36 [48,481ms] [Fatal] [carb.crashreporter-breakpad.plugin] 154: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:36 [48,560ms] [Fatal] [carb.crashreporter-breakpad.plugin] 155: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:36 [48,637ms] [Fatal] [carb.crashreporter-breakpad.plugin] 156: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:36 [48,715ms] [Fatal] [carb.crashreporter-breakpad.plugin] 157: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:36 [48,793ms] [Fatal] [carb.crashreporter-breakpad.plugin] 158: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:36 [48,871ms] [Fatal] [carb.crashreporter-breakpad.plugin] 159: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:36 [48,949ms] [Fatal] [carb.crashreporter-breakpad.plugin] 160: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:36 [49,027ms] [Fatal] [carb.crashreporter-breakpad.plugin] 161: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:36 [49,104ms] [Fatal] [carb.crashreporter-breakpad.plugin] 162: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:36 [49,183ms] [Fatal] [carb.crashreporter-breakpad.plugin] 163: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:37 [49,260ms] [Fatal] [carb.crashreporter-breakpad.plugin] 164: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:37 [49,339ms] [Fatal] [carb.crashreporter-breakpad.plugin] 165: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:37 [49,416ms] [Fatal] [carb.crashreporter-breakpad.plugin] 166: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:37 [49,495ms] [Fatal] [carb.crashreporter-breakpad.plugin] 167: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:37 [49,572ms] [Fatal] [carb.crashreporter-breakpad.plugin] 168: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:37 [49,650ms] [Fatal] [carb.crashreporter-breakpad.plugin] 169: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:37 [49,727ms] [Fatal] [carb.crashreporter-breakpad.plugin] 170: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:37 [49,805ms] [Fatal] [carb.crashreporter-breakpad.plugin] 171: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:37 [49,883ms] [Fatal] [carb.crashreporter-breakpad.plugin] 172: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:37 [49,962ms] [Fatal] [carb.crashreporter-breakpad.plugin] 173: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:37 [50,040ms] [Fatal] [carb.crashreporter-breakpad.plugin] 174: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:37 [50,119ms] [Fatal] [carb.crashreporter-breakpad.plugin] 175: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:37 [50,198ms] [Fatal] [carb.crashreporter-breakpad.plugin] 176: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:38 [50,277ms] [Fatal] [carb.crashreporter-breakpad.plugin] 177: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:38 [50,355ms] [Fatal] [carb.crashreporter-breakpad.plugin] 178: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:38 [50,433ms] [Fatal] [carb.crashreporter-breakpad.plugin] 179: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:38 [50,511ms] [Fatal] [carb.crashreporter-breakpad.plugin] 180: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:38 [50,592ms] [Fatal] [carb.crashreporter-breakpad.plugin] 181: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:38 [50,670ms] [Fatal] [carb.crashreporter-breakpad.plugin] 182: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:38 [50,749ms] [Fatal] [carb.crashreporter-breakpad.plugin] 183: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:38 [50,826ms] [Fatal] [carb.crashreporter-breakpad.plugin] 184: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:38 [50,905ms] [Fatal] [carb.crashreporter-breakpad.plugin] 185: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:38 [50,983ms] [Fatal] [carb.crashreporter-breakpad.plugin] 186: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:38 [51,063ms] [Fatal] [carb.crashreporter-breakpad.plugin] 187: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:38 [51,144ms] [Fatal] [carb.crashreporter-breakpad.plugin] 188: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:38 [51,223ms] [Fatal] [carb.crashreporter-breakpad.plugin] 189: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:39 [51,301ms] [Fatal] [carb.crashreporter-breakpad.plugin] 190: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:39 [51,381ms] [Fatal] [carb.crashreporter-breakpad.plugin] 191: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:39 [51,460ms] [Fatal] [carb.crashreporter-breakpad.plugin] 192: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:39 [51,539ms] [Fatal] [carb.crashreporter-breakpad.plugin] 193: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:39 [51,618ms] [Fatal] [carb.crashreporter-breakpad.plugin] 194: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:39 [51,696ms] [Fatal] [carb.crashreporter-breakpad.plugin] 195: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:39 [51,775ms] [Fatal] [carb.crashreporter-breakpad.plugin] 196: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:39 [51,855ms] [Fatal] [carb.crashreporter-breakpad.plugin] 197: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:39 [51,933ms] [Fatal] [carb.crashreporter-breakpad.plugin] 198: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:39 [52,011ms] [Fatal] [carb.crashreporter-breakpad.plugin] 199: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:39 [52,089ms] [Fatal] [carb.crashreporter-breakpad.plugin] 200: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:39 [52,167ms] [Fatal] [carb.crashreporter-breakpad.plugin] 201: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:40 [52,248ms] [Fatal] [carb.crashreporter-breakpad.plugin] 202: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:40 [52,327ms] [Fatal] [carb.crashreporter-breakpad.plugin] 203: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:40 [52,409ms] [Fatal] [carb.crashreporter-breakpad.plugin] 204: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:40 [52,489ms] [Fatal] [carb.crashreporter-breakpad.plugin] 205: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:40 [52,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] 206: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:40 [52,646ms] [Fatal] [carb.crashreporter-breakpad.plugin] 207: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:40 [52,724ms] [Fatal] [carb.crashreporter-breakpad.plugin] 208: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:40 [52,804ms] [Fatal] [carb.crashreporter-breakpad.plugin] 209: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:40 [52,882ms] [Fatal] [carb.crashreporter-breakpad.plugin] 210: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:40 [52,961ms] [Fatal] [carb.crashreporter-breakpad.plugin] 211: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:40 [53,039ms] [Fatal] [carb.crashreporter-breakpad.plugin] 212: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:40 [53,117ms] [Fatal] [carb.crashreporter-breakpad.plugin] 213: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:40 [53,195ms] [Fatal] [carb.crashreporter-breakpad.plugin] 214: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:41 [53,273ms] [Fatal] [carb.crashreporter-breakpad.plugin] 215: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:41 [53,352ms] [Fatal] [carb.crashreporter-breakpad.plugin] 216: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:41 [53,432ms] [Fatal] [carb.crashreporter-breakpad.plugin] 217: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:41 [53,514ms] [Fatal] [carb.crashreporter-breakpad.plugin] 218: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:41 [53,595ms] [Fatal] [carb.crashreporter-breakpad.plugin] 219: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:41 [53,675ms] [Fatal] [carb.crashreporter-breakpad.plugin] 220: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:41 [53,753ms] [Fatal] [carb.crashreporter-breakpad.plugin] 221: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:41 [53,832ms] [Fatal] [carb.crashreporter-breakpad.plugin] 222: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:41 [53,910ms] [Fatal] [carb.crashreporter-breakpad.plugin] 223: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:41 [53,989ms] [Fatal] [carb.crashreporter-breakpad.plugin] 224: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:41 [54,071ms] [Fatal] [carb.crashreporter-breakpad.plugin] 225: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:41 [54,149ms] [Fatal] [carb.crashreporter-breakpad.plugin] 226: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:42 [54,228ms] [Fatal] [carb.crashreporter-breakpad.plugin] 227: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:42 [54,308ms] [Fatal] [carb.crashreporter-breakpad.plugin] 228: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:42 [54,387ms] [Fatal] [carb.crashreporter-breakpad.plugin] 229: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:42 [54,467ms] [Fatal] [carb.crashreporter-breakpad.plugin] 230: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:42 [54,546ms] [Fatal] [carb.crashreporter-breakpad.plugin] 231: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:42 [54,624ms] [Fatal] [carb.crashreporter-breakpad.plugin] 232: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:42 [54,704ms] [Fatal] [carb.crashreporter-breakpad.plugin] 233: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:42 [54,782ms] [Fatal] [carb.crashreporter-breakpad.plugin] 234: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:42 [54,859ms] [Fatal] [carb.crashreporter-breakpad.plugin] 235: libpython3.7m.so.1.0!_PyFunction_FastCallDict+0x28f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:322)
2023-06-12 02:03:42 [54,938ms] [Fatal] [carb.crashreporter-breakpad.plugin] 236: libpython3.7m.so.1.0!object_vacall+0xa2 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1202)
2023-06-12 02:03:42 [55,016ms] [Fatal] [carb.crashreporter-breakpad.plugin] 237: libpython3.7m.so.1.0!_PyObject_CallMethodIdObjArgs+0xa5 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:1253)
2023-06-12 02:03:42 [55,097ms] [Fatal] [carb.crashreporter-breakpad.plugin] 238: libpython3.7m.so.1.0!PyImport_ImportModuleLevelObject+0x4df (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/import.c:1652)
2023-06-12 02:03:42 [55,176ms] [Fatal] [carb.crashreporter-breakpad.plugin] 239: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x73c6 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4770)
2023-06-12 02:03:43 [55,255ms] [Fatal] [carb.crashreporter-breakpad.plugin] 240: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:43 [55,334ms] [Fatal] [carb.crashreporter-breakpad.plugin] 241: libpython3.7m.so.1.0!PyEval_EvalCodeEx+0x3e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3959)
2023-06-12 02:03:43 [55,413ms] [Fatal] [carb.crashreporter-breakpad.plugin] 242: libpython3.7m.so.1.0!PyEval_EvalCode+0x1b (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:530)
2023-06-12 02:03:43 [55,492ms] [Fatal] [carb.crashreporter-breakpad.plugin] 243: libpython3.7m.so.1.0!builtin_exec+0x15d (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/bltinmodule.c:1098)
2023-06-12 02:03:43 [55,570ms] [Fatal] [carb.crashreporter-breakpad.plugin] 244: libpython3.7m.so.1.0!_PyMethodDef_RawFastCallDict+0x2f9 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:530)
2023-06-12 02:03:43 [55,648ms] [Fatal] [carb.crashreporter-breakpad.plugin] 245: libpython3.7m.so.1.0!_PyCFunction_FastCallDict+0x25 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:588 (discriminator 4))
2023-06-12 02:03:43 [55,727ms] [Fatal] [carb.crashreporter-breakpad.plugin] 246: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7848 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4641)
2023-06-12 02:03:43 [55,809ms] [Fatal] [carb.crashreporter-breakpad.plugin] 247: libpython3.7m.so.1.0!_PyEval_EvalCodeWithName+0xa9e (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:3930)
2023-06-12 02:03:43 [55,887ms] [Fatal] [carb.crashreporter-breakpad.plugin] 248: libpython3.7m.so.1.0!_PyFunction_FastCallKeywords+0x8f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:440 (discriminator 4))
2023-06-12 02:03:43 [55,966ms] [Fatal] [carb.crashreporter-breakpad.plugin] 249: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x9017 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:43 [56,045ms] [Fatal] [carb.crashreporter-breakpad.plugin] 250: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:43 [56,125ms] [Fatal] [carb.crashreporter-breakpad.plugin] 251: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x7e36 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:43 [56,206ms] [Fatal] [carb.crashreporter-breakpad.plugin] 252: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:44 [56,285ms] [Fatal] [carb.crashreporter-breakpad.plugin] 253: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
2023-06-12 02:03:44 [56,363ms] [Fatal] [carb.crashreporter-breakpad.plugin] 254: libpython3.7m.so.1.0!function_code_fastcall+0x6f (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Objects/call.c:285)
2023-06-12 02:03:44 [56,442ms] [Fatal] [carb.crashreporter-breakpad.plugin] 255: libpython3.7m.so.1.0!_PyEval_EvalFrameDefault+0x68a7 (/builds/omniverse/externals/python-build/_build/Python-3.7.13/Python/ceval.c:4616)
