PS E:\Omniverse\pkg\create-2021.1.1_build\windows-x86_64\release> E:\Omniverse\pkg\create-2021.1.1_build\windows-x86_64\release\omni.create.launcher.bat
[Info] [carb] Logging to file: C:/Users/Owen/.nvidia-omniverse/logs/Kit/omni.create.launcher/100.3/kit_20210603_100043.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.147s] Loading user config located at: ‘E:/Omniverse/data/Kit/omni.create.launcher/100.3/user.config.json’
[0.319s] [ext: omni.create.app.launcher-1.0.0] startup
[0.336s] [ext: omni.create.launcher-2021.1.0] startup
[0.336s] app started
[0.336s] [ext: omni.create.launcher-2021.1.0] shutdown
[0.336s] [ext: omni.create.app.launcher-1.0.0] shutdown
PS E:\Omniverse\pkg\create-2021.1.1_build\windows-x86_64\release> [Info] [carb] Logging to file: C:/Users/Owen/.nvidia-omniverse/logs/Kit/Create/2021.1/kit_20210603_100043.log
[0.142s] Loading user config located at: ‘E:/Omniverse/data/Kit/Create/2021.1/user.config.json’
[0.299s] [ext: omni.assets-0.0.0] startup
[0.302s] [ext: omni.kit.window.splash-0.0.0] startup
[0.349s] [ext: omni.kit.async_engine-0.0.0] startup
[0.356s] [ext: omni.kit.agent-0.1.0] startup
[0.360s] [ext: omni.kit.splash-0.1.0] startup
[0.375s] [ext: omni.kit.loop-default-0.1.0] startup
[0.376s] [ext: omni.kit.test-0.0.0] startup
[0.403s] [ext: omni.kit.pipapi-0.0.0] startup
[0.412s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.421s] [ext: omni.services.facilities.base-1.0.0] startup
[0.425s] [ext: omni.services.core-1.1.0] startup
[0.588s] [ext: omni.services.transport.server.base-1.0.0] startup
[0.594s] [ext: omni.services.transport.server.http-1.0.0] startup
[0.800s] [ext: omni.timeline-0.0.0] startup
[0.805s] [ext: omni.kit.commands-0.0.0] startup
[0.816s] [ext: carb.audio-0.1.0] startup
[0.819s] [ext: omni.usd-0.1.8] startup
[1.068s] [ext: omni.client-0.1.0] startup
[1.091s] [ext: omni.services.registry-1.0.0] startup
[1.499s] [ext: omni.stats-0.0.0] startup
[1.508s] [ext: omni.appwindow-0.1.0-rc1] startup
[1.555s] [ext: omni.kit.renderer.core-0.0.0] startup
2021-06-03 02:00:45 [1,633ms] [Warning] [gpu.foundation] Skipping unsupported non-RTX GPU: NVIDIA GeForce GTX 1060 3GB
2021-06-03 02:00:45 [1,634ms] [Warning] [gpu.foundation] Skipping unsupported non-RTX GPU: NVIDIA GeForce GTX 1060 3GB
2021-06-03 02:00:45 [1,695ms] [Warning] [carb.graphics-direct3d.plugin] Aftermath failed to initialize.
2021-06-03 02:00:45 [1,958ms] [Warning] [carb.graphics-direct3d.plugin] Failed to initialize NGX. Optional DLSS feature will be disabled.
2021-06-03 02:00:45 [1,958ms] [Warning] [gpu.foundation] Raytracing is not supported on GPU: 1. Skipping this device.
| Driver Version: 462.31 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce GTX 1060 3GB | | | 2988 MB | 10de | b90a0000… |
| | | | | | 1c02 | 0 |
| 1 | Intel(R) HD Graphics 630 | | | 128 MB | 8086 | b5460000… |
| | | | | | 5912 | 0 |
| OS: Windows, Version: 10.0 (20H2), Build: 19042
| Processor: Intel(R) Core™ i7-7700 CPU @ 3.60GHz | Cores: 4 | Logical: 8
| Total Memory (MB): 16280 | Free Memory: 8905
| Total Page/Swap (MB): 32152 | Free Page/Swap: 19521
2021-06-03 02:00:45 [1,984ms] [Error] [gpu.foundation] No device could be created.
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce GTX 1060 3GB | Yes | | 2988 MB | 10de | b90a0000… |
| | | | | | 1c02 | 0 |
| 1 | Intel(R) HD Graphics 630 | Yes | | 128 MB | 8086 | b5460000… |
| | | | | | 5912 | 0 |
| Total Memory (MB): 16280 | Free Memory: 8860
| Total Page/Swap (MB): 32152 | Free Page/Swap: 19458
2021-06-03 02:00:46 [2,361ms] [Warning] [omni.kit.renderer.plugin] RT-capable GPU not found, switching to compatibility mode
[2.778s] [ext: omni.ui-2.1.2] startup
[2.802s] [ext: omni.kit.mainwindow-0.0.0] startup
[2.817s] [ext: omni.kit.uiapp-0.0.0] startup
[2.820s] [ext: omni.kit.tagging-0.1.0] startup
[2.907s] [ext: omni.kit.search_core-1.0.0] startup
[2.916s] [ext: omni.kit.widget.path_field-2.0.0] startup
[2.928s] [ext: omni.services.transport.client.base-1.0.0] startup
[2.937s] [ext: omni.kit.window.popup_dialog-1.0.0] startup
[2.950s] [ext: omni.kit.widget.filebrowser-2.0.4] startup
[2.966s] [ext: omni.kit.widget.browser_bar-2.0.0] startup
[2.978s] [ext: omni.services.client-0.2.0] startup
[3.011s] [ext: omni.kit.window.filepicker-2.0.3] startup
[3.068s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[3.167s] [ext: omni.kit.stage_templates-1.0.3] startup
[3.182s] [ext: omni.kit.asset_converter-1.0.1] startup
[3.202s] [ext: omni.kit.material.library-1.0.3] startup
[3.220s] [ext: omni.kit.thumbnails.images-0.1.0] startup
[3.234s] [ext: omni.kit.window.file-1.0.1] startup
[3.348s] [ext: omni.kit.window.script_editor-1.5.0] startup
[3.350s] [ext: omni.kit.context_menu-1.0.5] startup
[3.363s] [ext: omni.kit.menu.utils-1.0.1] startup
[3.380s] [ext: omni.kit.window.content_browser-2.0.3] startup
[3.440s] [ext: omni.kit.window.preferences-1.0.1] startup
[3.550s] [ext: omni.kit.tool.asset_exporter-1.0.2] startup
[3.568s] [ext: omni.kit.menu.file-1.0.1] startup
[3.584s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[3.606s] [ext: omni.kit.filebrowser_column.tags-1.0.0] startup
[3.622s] [ext: omni.kit.tool.collect-2.0.0] startup
[3.643s] [ext: omni.usdphysics-1.1.0] startup
[3.645s] [ext: omni.hydra.rtx-0.1.0] startup
[3.654s] [ext: omni.renderer-rtx-0.0.0] startup
[3.655s] [ext: omni.kvdb-0.0.0] startup
[3.669s] [ext: omni.convexdecomposition-1.1.0] startup
[3.684s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-06-03 02:00:47 [3,606ms] [Error] [omni.kit.window.viewport.plugin] Failed to initialize resource manager
2021-06-03 02:00:47 [3,606ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
[3.737s] [ext: omni.kit.widget.stage-2.3.3] startup
[3.761s] [ext: omni.localcache-0.0.0] startup
[3.775s] [ext: omni.debugdraw-0.0.0] startup
[3.789s] [ext: omni.kit.window.provide_feedback-0.1.0] startup
[3.863s] [ext: omni.physx-1.1.0-5.1] startup
[3.988s] [ext: omni.videoencoding-0.0.0] startup
[3.994s] [ext: omni.kit.renderer.capture-0.0.0] startup
[4.017s] [ext: omni.rtx.window.settings-0.6.0] startup
[4.035s] [ext: omni.kit.window.property-0.0.0] startup
[4.055s] [ext: omni.kit.capture-0.3.2] startup
[4.076s] [ext: omni.rtx.settings.core-0.5.4] startup
[4.094s] [ext: omni.kit.window.profiler-1.0.0] startup
[4.118s] [ext: omni.kit.property.usd-3.4.2] startup
[4.192s] [ext: omni.kit.window.movie_maker-0.3.1] startup
[4.219s] [ext: omni.kit.widget.layers-0.3.1] startup
[4.256s] [ext: omni.physx.ui-1.1.0-5.1] startup
[4.274s] [ext: omni.kit.widget.stage_icons-1.0.0] startup
[4.296s] [ext: omni.kit.property.material-1.4.1] startup
[4.320s] [ext: omni.kit.usd_undo-0.0.0] startup
[4.341s] [ext: omni.kit.property.layer-1.0.1] startup
[4.364s] [ext: omni.kit.window.toolbar-0.0.0] startup
[4.394s] [ext: omni.kit.window.stage-2.3.2] startup
[4.421s] [ext: omni.kit.property.physx-0.1.0] startup
[4.495s] [ext: omni.kit.property.transform-1.0.2] startup
[4.522s] [ext: omni.kit.property.audio-1.0.3] startup
[4.549s] [ext: omni.kit.property.geometry-1.0.6] startup
[4.575s] [ext: omni.kit.widget.graph-1.0.2] startup
[4.606s] [ext: omni.physx.vehicle-1.1.0-5.1] startup
[4.633s] [ext: omni.physx.cct-1.1.0-5.1] startup
[4.654s] [ext: omni.kit.property.light-1.0.2] startup
[4.685s] [ext: omni.kit.property.camera-1.0.2] startup
[4.711s] [ext: omni.kit.window.extensions-1.0.2] startup
[4.747s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[4.780s] [ext: omni.physx.bundle-1.1.0-5.1] startup
[4.780s] [ext: omni.kit.window.console-0.0.0] startup
[4.785s] [ext: omni.kit.property.bundle-1.2.2] startup
[4.814s] [ext: omni.kit.widget.live-0.0.0] startup
[4.816s] [ext: omni.kit.tool.asset_importer-2.0.0] startup
[4.845s] [ext: omni.kit.window.about-0.2.1] startup
[4.873s] [ext: omni.kit.widget.imageview-1.0.0] startup
[4.900s] [ext: omni.kit.window.status_bar-0.0.0] startup
[4.902s] [ext: omni.kit.window.title-1.0.0] startup
[4.934s] [ext: omni.kit.selection-0.0.0] startup
[4.962s] [ext: omni.kit.search.service-0.1.0] startup
[4.997s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[5.030s] [ext: omni.kit.thumbnails.usd-0.3.0] startup
[5.071s] [ext: omni.kit.property.tagging-1.0.1] startup
[5.105s] [ext: omni.kit.window.stats-0.0.0] startup
[5.138s] [ext: omni.create.app.setup-0.0.0] startup
[5.164s] [ext: omni.kit.utility.icon_modifier-0.1.2] startup
[5.202s] [ext: omni.kit.quicklayout-1.0.0] startup
[5.232s] [ext: omni.create.next-2021.1.0] startup
[5.232s] app started
[5.441s] [ext: omni.kit.builtin.init] startup
[5.444s] [ext: omni.kit.builtin.menu] startup
Windows fatal exception: access violation
Thread 0x00002e8c (most recent call first):
File “e:\omniverse\pkg\create-2021.1.1_build\kit_release_exts\omni.kit.splash\omni\kit\splash\setup.py”, line 63 in _send_data
File “e:\omniverse\pkg\create-2021.1.1_build\kit_release_build\target-deps\python\lib\threading.py”, line 864 in run File “e:\omniverse\pkg\create-2021.1.1_build\kit_release_build\target-deps\python\lib\threading.py”, line 916 in _bootstrap_inner
File “e:\omniverse\pkg\create-2021.1.1_build\kit_release_build\target-deps\python\lib\threading.py”, line 884 in _bootstrap
Current thread 0x00003304 (most recent call first):
2021-06-03 02:00:58 [15,159ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.debugdraw.plugin.dll!carbOnPluginStartup
2021-06-03 02:00:58 [15,160ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.physxui.plugin.dll
2021-06-03 02:00:58 [15,161ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.physxui.plugin.dll
2021-06-03 02:00:58 [15,162ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.physxui.plugin.dll
2021-06-03 02:00:58 [15,162ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.stageupdate.plugin.dll
2021-06-03 02:00:58 [15,163ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.usd.dll!omni::usd::UsdContext::unsubscribeLiveModeUpdateEvent
2021-06-03 02:00:58 [15,163ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.usd.dll!omni::usd::UsdContext::SetBoundingBoxSemanticId
2021-06-03 02:00:58 [15,163ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.usd.dll!omni::usd::OmniUsdMessenger::~OmniUsdMessenger
2021-06-03 02:00:58 [15,164ms] [Fatal] [carb.crashreporter-breakpad.plugin] carb.events.plugin.dll
2021-06-03 02:00:58 [15,165ms] [Fatal] [carb.crashreporter-breakpad.plugin] carb.events.plugin.dll
2021-06-03 02:00:58 [15,166ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.loop-default.plugin.dll
2021-06-03 02:00:58 [15,166ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll
2021-06-03 02:00:58 [15,167ms] [Fatal] [carb.crashreporter-breakpad.plugin] omni.kit.app.plugin.dll
2021-06-03 02:00:58 [15,167ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe
2021-06-03 02:00:58 [15,168ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit.exe
2021-06-03 02:00:58 [15,168ms] [Fatal] [carb.crashreporter-breakpad.plugin] KERNEL32.DLL!BaseThreadInitThunk
2021-06-03 02:00:58 [15,169ms] [Fatal] [carb.crashreporter-breakpad.plugin] ntdll.dll!RtlUserThreadStart
