Create: Error saving layers because of permissions
Keeps coming up when trying to save file?
2023-05-22 16:37:05 [Error] [omni.usd] ERROR! Failed to save layer omniverse://localhost/Projects/Ballina-St-project/Ballina_St_-_Apartment.usdz due to permission issue.
Looks like a .usdz file type issue!!
Why are there letter extension like a and z on .usd files??
usdz is a zipped usd file. Assets downloaded from sketchfab will often be in this format. Although the file can be opened and displayed you can’t make modifications inside the zip file. You can resave the file as a usd and reopen it or go into your file browser and unzip the usdz into a folder you can read and write from before opening it up in Omniverse.
Essentially the usd is contained in a zip file and it won’t let you make edits to the content inside a zip. You can read up on USDZ here: Usdz File Format Specification — Universal Scene Description 23.05 documentation (openusd.org)
hello , could you help me ? I aslo met similar problems ?
below is my logs :
29,690ms] [Info] [omni.usd] Loading omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd
2024-09-26 06:42:04 [30,021ms] [Info] [omni.client.plugin] 214370: provider_http: Successfully created S3 provider for https://omniverse-content-production.s3.us-west-2.amazonaws.com
2024-09-26 06:42:05 [30,700ms] [Info] [omni.client.plugin] Tick: provider_http: Using CloudFront http://dcb18d6mfegct.cloudfront.net/, List = No
2024-09-26 06:43:41 [127,288ms] [Info] [omni.client.plugin] Tick: provider_http: Read failed! Error. URI=‘http://dcb18d6mfegct.cloudfront.net/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd’: Unknown response code from server. code=502
2024-09-26 06:43:41 [127,291ms] [Warning] [omni.usd] Warning (secondary thread): in _ReportErrors at line 2890 of /buildAgent/work/ac88d7d902b57417/USD/pxr/usd/usd/stage.cpp – In </Environment/sky>: Could not open asset @https://omniverse-content-production.s3.us-west-2.amazonaws.com/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd@ for reference introduced by @omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd@</Environment/sky>. (instantiating stage on stage @omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd@ <0x7ce654009950>)
2024-09-26 06:46:26 [291,645ms] [Info] [omni.client.plugin] Tick: provider_http: Read failed! Error. URI=‘http://dcb18d6mfegct.cloudfront.net/Assets/Skies/2022_1/Skies/Dynamic/ClearSky.usd’: Unknown response code from server. code=502
2024-09-26 06:46:26 [291,648ms] [Info] [omni.usd] omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd opened successfully in 261.96 seconds
2024-09-26 06:46:26 [291,667ms] [Info] [rtx.scenedb.plugin] [MBVH]: Creating scene acceleration structures for context 0, device mask: 0x3
2024-09-26 06:46:26 [291,667ms] [Info] [rtx.scenedb.plugin] [MBVH]: Creating scene acceleration structure for context 0/device 0, with motion raytracing DISABLED
2024-09-26 06:46:26 [291,667ms] [Info] [rtx.scenedb.plugin] [MBVH]: Creating scene acceleration structure for context 0/device 1, with motion raytracing DISABLED
2024-09-26 06:46:26 [292,304ms] [Info] [omni.usd.audio] refreshing the USD scene state
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] audio default: ‘enable doppler’ = ‘off’
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] audio default: ‘enable distance delay’ = ‘off’
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] audio default: ‘enable interaural delay’ = ‘off’
2024-09-26 06:46:26 [292,305ms] [Info] [omni.usd.audio] updated world unit scale {1.00 => 0.01}
2024-09-26 06:46:26 [292,360ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd.
2024-09-26 06:46:26 [292,361ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x7ce65400cd10.
2024-09-26 06:46:26 [292,365ms] [Info] [omni.kit.environment.core.models.usd_model_builder] [UsdModelBuilder] STOPPED!
2024-09-26 06:46:26 [292,365ms] [Info] [omni.kit.environment.core.models.usd_model_builder] [UsdModelBuilder] STARTED on Usd.Stage.Open(rootLayer=Sdf.Find(‘omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd’), sessionLayer=Sdf.Find(‘anon:0x7ce65400cd10’), pathResolverContext=)
2024-09-26 06:46:26 [292,365ms] [Info] [omni.kit.environment.core.ground.ground_helper] Ground found: None
2024-09-26 06:46:26 [292,377ms] [Info] [omni.kit.environment.core.sunstudy_player.player] [SunstudyPlayer] Found Dynamic sky: /Environment/sky
2024-09-26 06:46:26 [292,401ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd.
2024-09-26 06:46:26 [292,401ms] [Info] [omni.kit.widget.layers.layer_model] Load sublayers of layer anon:0x7ce65400cd10.
2024-09-26 06:46:29 [295,201ms] [Info] [omni.client.plugin] Tick: provider_nucleus: Failed omni1CreateAsset(omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd):
2024-09-26 06:46:30 [295,525ms] [Error] [omni.usd] ERROR! Failed to save layer omniverse://omniverse-server/Users/assets/assets/plateau/kyoto_flat.usd due to permission issue.
2024-09-26 06:46:30 [295,525ms] [Info] [omni.usd] USD saving failed
2024-09-26 06:49:36 [481,749ms] [Info] [carb] Plugin carb.scripting-python.plugin is already a dependency of omni.ui.glyphmanager.plugin; not changing unload order
Ok let me try to get some help for you on the issue. It may be because this asset is on a group Nucleus Server. Have you tried to do this with a local copy of this asset ?
