Problem description
Hi All,
I am trying to build a TensorRT engine from TF2 Object detection API SSD MobileNet v2 320x320. I followed TensorRT/samples/python/tensorflow_object_detection_api at main · NVIDIA/TensorRT · GitHub
I successfully exported the TensorFlow model with float_image_tensor as the input type. However, when I try to create the onnx graph using create_onnx.py script, an error finishes the process showing that ‘Variable’ object has no attribute ‘values’. The full report is shown below
Any help is very appreciated, thanks in advance.
System information
numpy=1.22.3
Pillow 9.0.1
TensorRT = 8.4.0.6
TensorFlow 2.8.0
object detection 0.1
pycuda=2021.1
onnx=1.11.0
onnxruntime=1.11.0
tf2onnx==1.10.0
onnx-graphsurgeon==0.3.10
Windows 10
Steps to reproduce
- Download the SSD MobileNet v2 320x320 from TensorFlow 2 model zoo
- Export saved model with float image tensor as input type
cd /path/to/models/research/object_detection
python exporter_main_v2.py \
--input_type float_image_tensor \
--trained_checkpoint_dir /path/to/ssd_mobilenet_v2_320x320_coco17_tpu-8/checkpoint \
--pipeline_config_path /path/to/ssd_mobilenet_v2_320x320_coco17_tpu-8/pipeline.config \
--output_directory /path/to/export
- Create ONNX Graph
python create_onnx.py \
--pipeline_config /path/to/exported/pipeline.config \
--saved_model /path/to/exported/saved_model \
--onnx /path/to/save/model.onnx
Output report
python create_onnx.py --pipeline_config C:/Tensorflow/data/models/newModelSSDMobilenetv2_300/pipeline.config --saved_model C:/Tensorflow/data/models/newModelSSDMobilenetv2_300/saved_model --onnx C:/Tensorflow/data/models/newModelSSDMobilenetv2_300/model.onnx
C:\Tensorflow\venv\lib\site-packages\numpy\_distributor_init.py:30: UserWarning: loaded more than 1 DLL from .libs:
C:\Tensorflow\venv\lib\site-packages\numpy\.libs\libopenblas.EL2C6PLE4ZYW3ECEVIV3OXXGRN2NRFM2.gfortran-win_amd64.dll
C:\Tensorflow\venv\lib\site-packages\numpy\.libs\libopenblas.WCDJNK7YVMPZQ2ME2ZZHJJRJ3JIKNDB7.gfortran-win_amd64.dll
warnings.warn("loaded more than 1 DLL from .libs:"
INFO:tf2onnx.tf_loader:Signatures found in model: [serving_default].
INFO:tf2onnx.tf_loader:Output names: ['detection_anchor_indices', 'detection_boxes', 'detection_classes', 'detection_multiclass_scores', 'detection_scores', 'num_detections', 'raw_detection_boxes', 'raw_detection_scores']
WARNING:tensorflow:From C:\Tensorflow\venv\lib\site-packages\tf2onnx\tf_loader.py:711: extract_sub_graph (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Instructions for updating:
Use `tf.compat.v1.graph_util.extract_sub_graph`
INFO:ModelHelper:Loaded saved model from C:\Tensorflow\data\models\newModelSSDMobilenetv2_300\saved_model
INFO:tf2onnx.tfonnx:Using tensorflow=2.8.0, onnx=1.11.0, tf2onnx=1.10.0/07e9e0
INFO:tf2onnx.tfonnx:Using opset <onnx, 11>
INFO:tf2onnx.tf_utils:Computed 4 values for constant folding
INFO:tf2onnx.tfonnx:folding node using tf type=Select, name=Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Select_4
INFO:tf2onnx.tfonnx:folding node using tf type=Select, name=Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Select_5
INFO:tf2onnx.tfonnx:folding node using tf type=Select, name=Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Select_8
INFO:tf2onnx.tfonnx:folding node using tf type=Select, name=Postprocessor/BatchMultiClassNonMaxSuppression/map/while/PadOrClipBoxList/Select_1
INFO:tf2onnx.tf_utils:Computed 0 values for constant folding
INFO:tf2onnx.optimizer:Optimizing ONNX model
INFO:tf2onnx.optimizer:After optimization: BatchNormalization -53 (60->7), Cast -481 (2037->1556), Const -451 (3381->2930), Gather +7 (488->495), Identity -199 (199->0), Less -2 (99->97), Mul -2 (504->502), Placeholder -9 (18->9), Reshape -17 (405->388), Shape -8 (216->208), Slice -7 (427->420), Squeeze -22 (342->320), Transpose -272 (293->21), Unsqueeze -166 (478->312)
INFO:ModelHelper:TF2ONNX graph created successfully
INFO:ModelHelper:Model is ssd_mobilenet_v2_keras
INFO:ModelHelper:Height is 300
INFO:ModelHelper:Width is 300
INFO:ModelHelper:First NMS score threshold is 9.99999993922529e-09
INFO:ModelHelper:First NMS iou threshold is 0.6000000238418579
INFO:ModelHelper:First NMS max proposals is 100
[W] Inference failed. You may want to try enabling partitioning to see better results. Note: Error was:
This ORT build has ['TensorrtExecutionProvider', 'CUDAExecutionProvider', 'CPUExecutionProvider'] enabled. Since ORT 1.9, you are required to explicitly set the providers parameter when instantiating InferenceSession. For example, onnxruntime.InferenceSession(..., providers=['TensorrtExecutionProvider', 'CUDAExecutionProvider', 'CPUExecutionProvider'], ...)
INFO:ModelHelper:ONNX graph input shape: [1, 300, 300, 3] [NCHW format set]
INFO:ModelHelper:Found Conv node 'StatefulPartitionedCall/ssd_mobile_net_v2_keras_feature_extractor/model/Conv1/Conv2D' as stem entry
INFO:ModelHelper:Found Concat node 'StatefulPartitionedCall/concat_1' as the tip of BoxPredictor/ConvolutionalClassHead_
INFO:ModelHelper:Found Squeeze node 'StatefulPartitionedCall/Squeeze' as the tip of BoxPredictor/ConvolutionalBoxHead_
File "C:\Tensorflow\tensorflow_object_detection_api\create_onnx.py", line 673, in <module>
main(args)
File "C:\Tensorflow\tensorflow_object_detection_api\create_onnx.py", line 649, in main
effdet_gs.process_graph(args.first_nms_threshold, args.second_nms_threshold)
File "C:\Tensorflow\tensorflow_object_detection_api\create_onnx.py", line 622, in process_graph
self.graph.outputs = first_nms(-1, True, first_nms_threshold)
File "C:\Tensorflow\tensorflow_object_detection_api\create_onnx.py", line 486, in first_nms
anchors_tensor = self.extract_anchors_tensor(box_net_split)
File "C:\Tensorflow\tensorflow_object_detection_api\create_onnx.py", line 312, in extract_anchors_tensor
anchors_y = get_anchor(0, "Add")
File "C:\Tensorflow\tensorflow_object_detection_api\create_onnx.py", line 301, in get_anchor
if (node.inputs[1].values).size == 1:
AttributeError: 'Variable' object has no attribute 'values'
