Create ota package failed
I want to upgrade from Jetpack 35.1 to R35.1, change rootfs, kernel, export TARGET_BSP and BASE_BSP corresponding to different Linux_for_Tegra folders, and then use the command to create the ota upgrade package, but the creation fails, the failed log is as follows: Excuse me Why?
➜  Linux_for_Tegra echo $BASE_BSP
/home/lw/Workspace/nvidia/Linux_for_Tegra
➜  Linux_for_Tegra echo $TARGET_BSP
/home/lw/Workspace/nvidia/upgrade/Linux_for_Tegra
➜  Linux_for_Tegra sudo -E  bash ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-xavier-nx-devkit R35-1
Target board(JETSON_XAVIER_NX_DEVKIT) and base version(R35_1) is not supported
Failed to run "ota_validate_params jetson-xavier-nx-devkit R35-1 internal /home/lw/Workspace/nvidia/upgrade/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_board_specs.conf BOARD_SPECS_ARRAY CHIPID"
Usage: sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh [options] <target board> <bsp version>
	Where,
		<target board>: target board. Supported boards: jetson-agx-xavier-devkit, jetson-xavier-nx-devkit-emmc.
		<bsp version>: the version of the base BSP. Supported versions: R32-7.
	options:
		-u <PKC key file>: PKC key used for odm fused board
		-v <SBK key file>: Secure Boot Key (SBK) key used for ODM fused board
		-s	Skip generating system image.
		-b	Update bootloader only. Only valid for update without layout change.
		-r	Update rootfs only. Only valid for update without layout change.
		-o	Specify the script to update rootfs partition.
		-f	Specify the rootfs image to be written to rootfs partition.
Example:
	sudo ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh -u PKCkeyfile -v SBKkeyfile jetson-xavier-nx-devkit-emmc R32-7
hello liwang54321,
is this a typo? may I know what exactly the base version and your target version.
In fact, I just want to upgrade from R35.1 to R35.1, not to update the jetpack version, but to update the rootfs and kernel.
Hi liwang54321,
Please try below command:
$ sudo -E  ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-xavier-nx-devkit-emmc R35-1
Please make sure your $BASE_BSP and $TARGET_BSP both are R35.1.
I tested it and it seems the result is the same
➜  Linux_for_Tegra sudo -E  ./tools/ota_tools/version_upgrade/l4t_generate_ota_package.sh jetson-xavier-nx-devkit-emmc R35-1
Target board(JETSON_XAVIER_NX_DEVKIT_EMMC) and base version(R35_1) is not supported
Failed to run "ota_validate_params jetson-xavier-nx-devkit-emmc R35-1 internal /home/lw/Workspace/nvidia/upgrade/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_board_specs.conf BOARD_SPECS_ARRAY CHIPID"
	Where,
	options:
Example:
Hi liwang54321,
Sorry for last update.
In released R35.1, image-based OTA can only work on AGX Xavier and NX with R32.7 to R35.1.
R35.1 to R35.1 is not supported.
