My Create viewport has just all “grey color”, seems just nothing there. Any idea?
Douglas
Douglas
Could you have possibly clicked though a warning message about Nvidia driver version incompatibility?
This could lead to a gray viewpoint,
Can you place the logs for create into this forum. Location
C:/Users/[yourname]/.nvidia-omniverse/logs/Kit/Create/2020.3/kit_xxxxx_xxxx.log
I found that there is a single gpu mode for running, the problem solved, thank you very much anyway.
Best Regards,
Douglas
Hi Douglas,
glad single GPU mode works for you.
Could you please post the log file of the failed run nonetheless? That would be helpful to understand the apparent multi-GPU issue you were running into.
Tim
Hi Tim,
Kindly please see the attached log file for your reference.kit_20210101_200335.log (174.5 KB)
Douglas
