Hi Guys,
I wish to read frames from camera continuously. I am trying to use createNVBuffer API to extract and store the frame. When I try to run the following code for a short duration it works without any issue. However, when I run it for a longer duration it I get the following error and the program terminates.
(Argus) Error InvalidState: (propagating from src/eglstream/FrameConsumerImpl.cpp, function releaseFrame(), line 317)
(Argus) Error EndOfFile: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 212)
size of uint8_t : 1
writeIndex : 2
(Argus) Error EndOfFile: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 315)
char *m_datamem ;
while (true)
// Acquire a Frame.
UniqueObj<Frame> frame(iFrameConsumer->acquireFrame());
cout<<"frame instantiated"<<endl;
IFrame *iFrame = interface_cast<IFrame>(frame);
cout<<"iFrame instantiated : "<<iFrame<< endl;
if (!iFrame)
break;
// Get the Frame's Image.
Image *image = iFrame->getImage();
EGLStream::NV::IImageNativeBuffer *iImageNativeBuffer
= interface_cast<EGLStream::NV::IImageNativeBuffer>(image);
TEST_ERROR_RETURN(!iImageNativeBuffer, "Failed to create an IImageNativeBuffer");
fd = iImageNativeBuffer->createNvBuffer(Argus::Size {m_framesize.width, m_framesize.height},
NvBufferColorFormat_YUV420, NvBufferLayout_Pitch, &status);
if (status != STATUS_OK)
TEST_ERROR_RETURN(status != STATUS_OK, "Failed to create a native buffer");
NvBufferParams params;
NvBufferGetParams(fd, ¶ms);
int fsize = params.pitch[0] * m_framesize.height ;
m_datamem = (char *)mmap(NULL, 1.5*fsize, PROT_READ | PROT_WRITE, MAP_SHARED, fd, params.offset[0]);
NvBufferDestroy(fd);
Kindly let me know what is wrong with this code. Is there a way to avoid allocating buffer at every iteration ? Is the destroy even happening ? Or is there some other issue.
@lamegeorge
Could you check if the sample code “/tegra_multimedia_api/samples/11_camera_object_identification” have the sample problem on your site and compare with it to figure out the problem.
Hi ShaneCCC,
Thanks for your response. Based on your suggestion, I ran “/tegra_multimedia_api/samples/11_camera_object_identification” and got the following error :
(NvOdmDevice) Error NotInitialized: V4L2Device not powered on (in dvs/git/dirty/git-master_linux/camera-partner/imager/src/V4L2Device.cpp, function setControlVal(), line 378)
Kindly let me know how to proceed.
Hi ShaneCCC,
I am trying to follow camera object identification code specifically only the ConsumerThread code. I have copied the code from camera_caffe_main.cpp into the file where I was reading the frame from camera.
When I try to do the code gets compiled successfully but I get a Linking Error as below:
ci/libci.a(aaOCVConsumer.cpp.o): In function `ArgusSamples::OCVConsumerThread::threadExecute()':
aaOCVConsumer.cpp:(.text+0x5d0): undefined reference to `NvV4l2ElementPlane::qBuffer(v4l2_buffer&, NvBuffer*)'
aaOCVConsumer.cpp:(.text+0x6a8): undefined reference to `NvV4l2ElementPlane::waitForDQThread(unsigned int)'
ci/libci.a(aaOCVConsumer.cpp.o): In function `ArgusSamples::OCVConsumerThread::converterCapturePlaneDqCallback(v4l2_buffer*, NvBuffer*, NvBuffer*, void*)':
aaOCVConsumer.cpp:(.text+0x804): undefined reference to `NvV4l2ElementPlane::qBuffer(v4l2_buffer&, NvBuffer*)'
ci/libci.a(aaOCVConsumer.cpp.o): In function `ArgusSamples::OCVConsumerThread::createImageConverter()':
aaOCVConsumer.cpp:(.text+0xa24): undefined reference to `NvVideoConverter::createVideoConverter(char const*, int)'
aaOCVConsumer.cpp:(.text+0xb14): undefined reference to `NvV4l2ElementPlane::setDQThreadCallback(bool (*)(v4l2_buffer*, NvBuffer*, NvBuffer*, void*))'
aaOCVConsumer.cpp:(.text+0xb34): undefined reference to `NvV4l2ElementPlane::setDQThreadCallback(bool (*)(v4l2_buffer*, NvBuffer*, NvBuffer*, void*))'
aaOCVConsumer.cpp:(.text+0xb54): undefined reference to `NvVideoConverter::setOutputPlaneFormat(unsigned int, unsigned int, unsigned int, v4l2_nv_buffer_layout)'
aaOCVConsumer.cpp:(.text+0xc04): undefined reference to `NvVideoConverter::setCapturePlaneFormat(unsigned int, unsigned int, unsigned int, v4l2_nv_buffer_layout)'
aaOCVConsumer.cpp:(.text+0xcc0): undefined reference to `NvV4l2ElementPlane::setupPlane(v4l2_memory, unsigned int, bool, bool)'
aaOCVConsumer.cpp:(.text+0xd7c): undefined reference to `NvV4l2ElementPlane::setupPlane(v4l2_memory, unsigned int, bool, bool)'
aaOCVConsumer.cpp:(.text+0xe58): undefined reference to `NvV4l2ElementPlane::getNthBuffer(unsigned int)'
aaOCVConsumer.cpp:(.text+0xe90): undefined reference to `NvV4l2ElementPlane::setStreamStatus(bool)'
aaOCVConsumer.cpp:(.text+0xf34): undefined reference to `NvV4l2ElementPlane::setStreamStatus(bool)'
aaOCVConsumer.cpp:(.text+0xfd8): undefined reference to `NvV4l2ElementPlane::startDQThread(void*)'
aaOCVConsumer.cpp:(.text+0xfec): undefined reference to `NvV4l2ElementPlane::startDQThread(void*)'
aaOCVConsumer.cpp:(.text+0x1068): undefined reference to `NvV4l2ElementPlane::qBuffer(v4l2_buffer&, NvBuffer*)'
ci/libci.a(aaOCVConsumer.cpp.o): In function `ArgusSamples::OCVConsumerThread::abort()':
aaOCVConsumer.cpp:(.text+0x1164): undefined reference to `NvV4l2Element::abort()'
collect2: error: ld returned 1 exit status
My CMakeLists.txt looks like the following:
cmake_minimum_required(VERSION 2.8)
project( hardwareCuda )
#SET(CMAKE_C_COMPILER /usr/bin/gcc)
#SET(CMAKE_CXX_COMPILER /usr/bin/g++)
set(CMAKE_MODULE_PATH "/usr/lib/aarch64-linux-gnu/" "/home/ubuntu/Downloads/argus/cmake" "~/Downloads" "${CMAKE_MODULE_PATH}")
set(CMAKE_MODULE_PATH "${CMAKE_SOURCE_DIR}/cmake" "${CMAKE_MODULE_PATH}")
set(CMAKE_C_FLAGS "-std=c++11")
#set(CMAKE_VERBOSE_MAKEFILE on)
find_package(PkgConfig REQUIRED)
pkg_check_modules(GTK3 REQUIRED gtk+-3.0)
find_package(Argus REQUIRED)
find_package(OpenGLES REQUIRED)
find_package(EGL REQUIRED)
find_package(X11 REQUIRED)
find_package( OpenCV REQUIRED )
find_package( OpenVX REQUIRED )
find_package(CUDA REQUIRED)
#find_package( VisionWorks REQUIRED )
include_directories( ${ARGUS_INCLUDE_DIR} ${EGL_INCLUDE_DIR} ${OPENGLES_INCLUDE_DIR} /home/ubuntu/Downloads/argus/samples/utils ${OpenCV_INCLUDE_DIRS} /usr/include /usr/local/include /opt/intel/ipp/include /home/ubuntu/tegra_multimedia_api/include/ ./ci /home/ubuntu/VisionWorks-1.6-Samples/nvxio/include/ /usr/local/cuda-8.0/targets/aarch64-linux/include/)
pkg_check_modules(GSTREAMER REQUIRED gstreamer-1.0)
include_directories(${GSTREAMER_INCLUDE_DIRS})
#set( CMAKE_VERBOSE_MAKEFILE on )
add_compile_options(-std=c++14)
cuda_add_executable( hardwareCuda aaTemplateMain.cpp absdiff.cu )
target_link_libraries( hardwareCuda ${OpenCV_LIBS} ${ARGUS_LIBRARIES} ${OPENGLES_LIBRARIES} ${GSTREAMER_LIBRARIES} ${X11_LIBRARIES} ${EGL_LIBRARIES} ${GTK3_LIBRARIES} /usr/local/lib/libopencv_bgsegm.so.3.1.0 /usr/lib/aarch64-linux-gnu/tegra/libnvbuf_utils.so /usr/lib/libvisionworks.so pthread /home/ubuntu/VisionWorks-1.6-Samples/libs/aarch64/linux/release/libovx.a cuda )
Kindly let me know how to resolve this Linking error.
The NvV4l2ElementPlane and NvVideoConverter classes are in the samples/common/classes/ find the the define and build it to your app.
Hi ShaneCCC,
Thanks for your response. I was able to find the required files at the location pointed by you. However, when I tried to build my application by supplying all the CPP files in this directory I seem to be getting the following message when I run my application. I have tried to adopt the same way of accessing camera as camera object identification code.
Failed to query video capabilities: Bad address
create vidoe converter return true
OCV CONSUMER: Waiting until producer is connected...
OCV CONSUMER: Producer has connected; continuing.
OCV CONSUMER: Done.
Any idea what could be going wrong ?
I think you need to figure below message output from and find the root cause.
Hi ShaneCCC,
I wish to process the raw YUV420 buffer directly and not make use of Video Converter. When I tried to study the code I observe that some APIs specific to Video Converter have been used. Can you suggest a way of following the sample in such a way that I can run the camera for longer duration before the process gets killed ?
Hi ShaneCCC,
I have the following queries :
- What is the role of mutex lock and what is m_queueCond ? What resources is it safeguarding ?
pthread_mutex_lock(&m_queueLock);
while (!m_gotError &&
((m_ConvOutputPlaneBufQueue->empty()) || (m_numPendingFrames >= MAX_PENDING_FRAMES)))
pthread_cond_wait(&m_queueCond, &m_queueLock);
if (m_gotError)
pthread_mutex_unlock(&m_queueLock);
break;
- What is the trigger condition for the following two callbacks ?
m_ImageConverter->capture_plane.
setDQThreadCallback(converterCapturePlaneDqCallback);
m_ImageConverter->output_plane.
setDQThreadCallback(converterOutputPlaneDqCallback);
If we are processing the frame as it comes and it takes more than (1/fps) time , what happens in this event ?
How to free the frame which has been received in case of the event described in #3. Does it create any problems ?
Kindly help me out.
