I’m working on a camera driver for custom hardware.
I need to modify the device tree.
In the past I’ve done this by decompiling the dtb, editing the dts, and recompiling. This
is not optimal because labels and such are removed, and if distributed .dtsi files change
the decompiled dts won’t be valid any more. So I want to create the device tree from the
existing .dts, .dtsi, and .h files.
In general we try to avoid modifying unpacked build trees if at all possible, so I’m trying
to do this outside of the kernel build tree. There’s a cpp step, followed by a dtc compile.
I’m pretty close except there is a forward reference problem – /bpmp/bpmpthermal is referenced
before it is defined. I’m doing this starting with an unmodified tegra186-quill-p3310-1000-c03-00-base.dts
I guess I don’t understand how forward (or circular) references work in a device tree (dts). I
understand it could be done with phandle entries, but the problem here is a refernce
like this: thermal-sensors = <&{/bpmp/bpmpthermal} 2>; that fails. It seems to be an
order problem in tegra186-soc-base.dtsi, but these compile with a kernel “make dtbs” just fine.
Any ideas? Commands and output are below.
I’m sure I’ll have more questions, and I’ll try to answer where I can.
Thanks,
Cary
cpp -nostdinc -x assembler-with-cpp
-I …/…/Build/Kernel/source/hardware/nvidia/soc/tegra/kernel-include
-I …/…/Build/Kernel/source/hardware/nvidia/soc/tegra/kernel-include/kernel-4.4
-I …/…/Build/Kernel/source/hardware/nvidia/platform/tegra/common/kernel-dts
-I …/…/Build/Kernel/source/hardware/nvidia/soc/t18x/kernel-include
-I …/…/Build/Kernel/source/hardware/nvidia/soc/t18x/kernel-dts
-I …/…/Build/Kernel/source/hardware/nvidia/platform/t18x/common/kernel-dts
-I …/…/Build/Kernel/source/hardware/nvidia/platform/t18x/quill/kernel-dts
tegra186-quill-p3310-1000-c03-00-base.dts intermediate.dts
dtc --in-format dts --out-format dtb -o ssve.dtb intermediate.dts
ssve.dtb: ERROR (phandle_references): Reference to non-existent node or label “/bpmp/bpmpthermal”
ERROR: Input tree has errors, aborting (use -f to force output)
