The question you’re asking is related to the Jetson Orin NX module and its adaptation and bring-up process on a custom board. You’re following the Adaptation and Bring-Up Guide, but you’re having trouble understanding the organization and documentation of the kernel device tree files.
To address your concerns, let’s break down the information provided in the context.
The Jetson Orin NX module is a part of the Jetson Orin NX series, which is designed to support various configurations. The module is compatible with the Jetson Orin NX Developer Kit (P3767-0000), which includes the module and a carrier board.
The kernel device tree files are used to configure the hardware components of the module and the carrier board. The files are organized in a way that separates the configuration of the module from the carrier board.
In your case, you’re trying to bring up a custom board with an Orin NX module, and you’ve generated the pinmux spreadsheet and device tree files from it. However, you’re finding it difficult to understand the organization and documentation of the kernel device tree files.
The device tree files are divided into two categories: those that belong to the Jetson module (p3767) and those that belong to the official development board (p3768). The files that belong to the module are responsible for configuring the hardware components that are physically present on the module, such as the TI power monitor.
On the other hand, the files that belong to the development board are responsible for configuring the hardware components that are specific to the development board, such as the GPU. The GPU is disabled by default in the module’s device tree files, and it’s only enabled in one of the development board’s device tree files.
To answer your question, you don’t necessarily need to reverse-engineer the device tree files to figure out what belongs to the Jetson module and what to the development board. However, you do need to understand the organization and documentation of the files.
Here’s a suggested approach:
- Start by identifying the hardware components that are present on your custom board. This will help you determine which device tree files are relevant to your board.
- Look at the device tree files that belong to the Jetson module (p3767). These files will give you an idea of how the module’s hardware components are configured.
- Look at the device tree files that belong to the development board (p3768). These files will give you an idea of how the development board’s hardware components are configured.
- Compare the device tree files for the module and the development board. This will help you identify which configurations are specific to the development board and which ones are relevant to your custom board.
- Use the information you’ve gathered to create your own device tree files for your custom board. Make sure to include only the configurations that are relevant to your board.
In terms of comparing the Jetson Orin NX module to other modules, such as the Jetson Xavier NX or the Jetson AGX Xavier, here are some key differences:
- The Jetson Orin NX module is not pin-compatible with the Jetson Xavier NX module, but you can design a carrier board that supports both modules.
- The Jetson Orin NX module has a different set of hardware components compared to the Jetson Xavier NX module. For example, the Orin NX module has a more powerful GPU and a different set of interfaces.
- The Jetson AGX Xavier module is a more powerful module compared to the Jetson Orin NX module. It has a more powerful GPU and a different set of interfaces.
In terms of industrial environments, the Jetson AGX Orin Industrial module is designed to support industrial-grade applications. It has a more robust design and a wider operating temperature range compared to the standard Jetson AGX Orin module.
I hope this helps clarify things for you. If you have any further questions or concerns, feel free to ask.
