Originally published at: https://developer.nvidia.com/blog/creating-a-human-pose-estimation-application-with-deepstream-sdk/
Human pose estimation is the computer vision task of estimating the configuration (‘the pose’) of the human body by localizing certain key points on a body within a video or a photo. This localization can be used to predict if the person is standing, sitting, lying down, or doing some activity like dancing or jumping.…
Hi awesome blog!
I have been trying to run this pose over multiple sources or video files.
Could you let me know how do I proceed with that? Do I make changes to the cpp file? If so, what?
Also, if I make a source file for making the pipeline and refer the config file, what changes do I need to make to the osd plugin, to display the lines and vectors of the keypoint?
does it work taking video input from jetson csi camera?
which changes are required to the config file in order to do so?
Any ideas why execution never completes?
./deepstream-pose-estimation-app one-by-one-person-detection.mp4 /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation/deepstream_pose_estimation
[sudo] password for nvidia:
Now playing: one-by-one-person-detection.mp4
Opening in BLOCKING MODE
0:00:02.753334359 3000 0x55a5a7f000 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation/deepstream_pose_estimation/pose_estimation.onnx_b1_gpu0_fp16.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input.1 3x224x224
1 OUTPUT kFLOAT 262 18x56x56
2 OUTPUT kFLOAT 264 42x56x56
0:00:02.753538242 3000 0x55a5a7f000 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation/deepstream_pose_estimation/pose_estimation.onnx_b1_gpu0_fp16.engine
0:00:02.758420373 3000 0x55a5a7f000 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:deepstream_pose_estimation_config.txt sucessfully
Running...
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
triied with the file
To change the source, you need to update deepstream_pose_estimation/deepstream_pose_estimation_app.cpp at master · NVIDIA-AI-IOT/deepstream_pose_estimation · GitHub file.
Does it provide better performance compare to Isaac implementation ?
Other pro or con compare to using it in Isaac ?
Hi ,
The base model is the same as Isaac 2D Skeleton Pose estimation model. In this project, we have integrated the model with Deepstream.
Hello, a question if I wanted to add RA, would it be possible to correct the code? ’
Hi, I’m trying to run the sample and it looks like it’s stalling at Running… and never ends.
The result file is being created but is empty.
I tried with several different onnx and video files, but get the same result.
I’m running this on Ubuntu 20.04
Any idea how to proceed with this?
Now playing: /home/jesper/Videos/sample_1080p_h264.mp4
0:00:00.973089312 11464 0x55e564a552a0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1701> [UID = 1]: deserialized trt engine from :/opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation/resnet18_baseline_att_224x224_A_epoch_249.onnx_b1_gpu0_fp16.engine
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:685 [Implicit Engine Info]: layers num: 4
0 INPUT kFLOAT input 3x224x224
1 OUTPUT kFLOAT part_affinity_fields 56x56x42
2 OUTPUT kFLOAT heatmap 56x56x18
3 OUTPUT kFLOAT maxpool_heatmap 56x56x18
0:00:00.973185447 11464 0x55e564a552a0 INFO nvinfer gstnvinfer.cpp:619:gst_nvinfer_logger:<primary-nvinference-engine> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:1805> [UID = 1]: Use deserialized engine model: /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream_pose_estimation/resnet18_baseline_att_224x224_A_epoch_249.onnx_b1_gpu0_fp16.engine
0:00:00.976275429 11464 0x55e564a552a0 INFO nvinfer gstnvinfer_impl.cpp:313:notifyLoadModelStatus:<primary-nvinference-engine> [UID 1]: Load new model:deepstream_pose_estimation_config.txt sucessfully
Running...
Hi Jesperlyng,
did you update anything in the source? It seems like you are using .mp4 input source and the pose estimation app supports h264 input streams.
Hi, well mp4 is just a container and as the file name suggests it’s h264 encoded so I expect that to be fine?
One thing to note here is that since I’m on Ubuntu 20.04 the Gstreamer version is 2.x and that might cause problems according to prior posts.
I figured out how to debug gst and got loads of warnings. If this could be caused by the wrong gstreamer version I’ll downgrade to Ubuntu 18 which has gstreamer 1.14 natively.
Thanks in advance
0:00:01.141163689 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 45281 will be dropped
0:00:01.141239886 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 9065 will be dropped
0:00:01.141315175 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 6635 will be dropped
0:00:01.141390460 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 313 will be dropped
0:00:01.141467691 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 28 Invalid, Size: 38004 will be dropped
0:00:01.141536478 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1310:gst_h264_parse_handle_frame:<h264-parser> input stream is corrupt; it contains a NAL unit of length 1
0:00:01.141618696 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 33850 will be dropped
0:00:01.141707008 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 44495 will be dropped
0:00:01.141777729 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 6 SEI, Size: 633 will be dropped
0:00:01.141862758 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 44985 will be dropped
0:00:01.141932700 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 12 Filler Data, Size: 341 will be dropped
0:00:01.142001344 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 5769 will be dropped
0:00:01.142077820 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 2 will be dropped
0:00:01.142145235 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 14 Prefix, Size: 43549 will be dropped
0:00:01.142203475 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 294 will be dropped
0:00:01.142257481 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 16 Depth Parameter Set, Size: 353 will be dropped
0:00:01.142312814 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 16 Depth Parameter Set, Size: 8591 will be dropped
0:00:01.142367642 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 2 will be dropped
0:00:01.142427417 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 33750 will be dropped
0:00:01.142484916 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 10947 will be dropped
0:00:01.142551013 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 14 Prefix, Size: 294 will be dropped
0:00:01.142609356 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 8434 will be dropped
0:00:01.142672138 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 31557 will be dropped
0:00:01.142727897 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1310:gst_h264_parse_handle_frame:<h264-parser> input stream is corrupt; it contains a NAL unit of length 1
0:00:01.142783034 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 10455 will be dropped
0:00:01.142842066 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 32705 will be dropped
0:00:01.142897583 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 283 will be dropped
0:00:01.142958937 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 49565 will be dropped
0:00:01.143024347 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 41558 will be dropped
0:00:01.143080549 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 648 will be dropped
0:00:01.143143526 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 14 Prefix, Size: 58266 will be dropped
0:00:01.143202569 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 28 Invalid, Size: 311 will be dropped
0:00:01.143262779 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 36945 will be dropped
0:00:01.143343935 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 152782 will be dropped
0:00:01.143408142 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 322 will be dropped
0:00:01.143472436 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 16 Depth Parameter Set, Size: 61224 will be dropped
0:00:01.143530134 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 319 will be dropped
0:00:01.143598716 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 95451 will be dropped
0:00:01.143678161 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 104673 will be dropped
0:00:01.143766553 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 13289 will be dropped
0:00:01.143854049 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 54114 will be dropped
0:00:01.143946789 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 59884 will be dropped
0:00:01.144031463 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1603:gst_h264_parse_sps_data: value greater than max. value: 5, max 2
0:00:01.144038958 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.144043716 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.144049113 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 41177 will be dropped
0:00:01.144113023 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 54042 will be dropped
0:00:01.144181508 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 77488 will be dropped
0:00:01.144246463 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 37694 will be dropped
0:00:01.144313487 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 75575 will be dropped
0:00:01.144399116 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 56470 will be dropped
0:00:01.144481016 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 132453 will be dropped
0:00:01.144543097 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 2 will be dropped
0:00:01.144596376 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 13770 will be dropped
0:00:01.144668469 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 22 Invalid, Size: 123142 will be dropped
0:00:01.144734780 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 37917 will be dropped
0:00:01.144806750 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 105005 will be dropped
0:00:01.144886377 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 102510 will be dropped
0:00:01.144953546 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 44574 will be dropped
0:00:01.145017379 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1599:gst_h264_parse_sps_data: failed to read UE
0:00:01.145024732 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.145031020 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.145039811 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 5 will be dropped
0:00:01.145122309 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 38363 will be dropped
0:00:01.145215424 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 48718 will be dropped
0:00:01.145298213 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 17 Reserved, Size: 9487 will be dropped
0:00:01.145375975 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 289 will be dropped
0:00:01.145456743 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 6771 will be dropped
0:00:01.145534926 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 589 will be dropped
0:00:01.145632913 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 68955 will be dropped
0:00:01.145721772 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 28 Invalid, Size: 10250 will be dropped
0:00:01.145802687 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 8049 will be dropped
0:00:01.145893836 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 21 Slice Depth/3D-AVC Extension, Size: 55691 will be dropped
0:00:01.146006158 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 108161 will be dropped
0:00:01.146105113 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.146115151 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.146122311 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.146131332 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 42174 will be dropped
0:00:01.146214123 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 11462 will be dropped
0:00:01.146366361 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 14 Prefix, Size: 289793 will be dropped
0:00:01.146471112 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 369 will be dropped
0:00:01.146582789 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 28 Invalid, Size: 127315 will be dropped
0:00:01.146694468 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 4 Slice DPC, Size: 82613 will be dropped
0:00:01.146780577 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 27 Invalid, Size: 32 will be dropped
0:00:01.146872022 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 20 Slice Extension, Size: 50250 will be dropped
0:00:01.146961250 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 34492 will be dropped
0:00:01.147043290 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 665 will be dropped
0:00:01.147125049 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 14389 will be dropped
0:00:01.147211822 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1571:gst_h264_parse_sps_data: failed to read UE
0:00:01.147221585 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.147228688 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.147237487 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 31512 will be dropped
0:00:01.147314895 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 280 will be dropped
0:00:01.147406220 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 22 Invalid, Size: 23582 will be dropped
0:00:01.147490924 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 5 will be dropped
0:00:01.147581533 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 50400 will be dropped
0:00:01.147671477 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 32651 will be dropped
0:00:01.147766248 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 48075 will be dropped
0:00:01.147848044 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 2 will be dropped
0:00:01.147938011 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 50279 will be dropped
0:00:01.148050310 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 115457 will be dropped
0:00:01.148132399 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 307 will be dropped
0:00:01.148210999 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 9013 will be dropped
0:00:01.148298889 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 51765 will be dropped
0:00:01.148390044 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 7601 will be dropped
0:00:01.148488744 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 78307 will be dropped
0:00:01.148570475 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 18 Reserved, Size: 11497 will be dropped
0:00:01.148651438 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 37932 will be dropped
0:00:01.148724592 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 640 will be dropped
0:00:01.148813318 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 61235 will be dropped
0:00:01.148895428 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 5 Slice IDR, Size: 15625 will be dropped
0:00:01.148973263 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 359 will be dropped
0:00:01.149072974 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 95893 will be dropped
0:00:01.149151353 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 650 will be dropped
0:00:01.149230255 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 7423 will be dropped
0:00:01.149320423 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 48898 will be dropped
0:00:01.149393704 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 354 will be dropped
0:00:01.149472608 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 6 SEI, Size: 30876 will be dropped
0:00:01.149587242 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1571:gst_h264_parse_sps_data: failed to read UE
0:00:01.149596539 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.149603465 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.149612338 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 124003 will be dropped
0:00:01.149721997 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 4 Slice DPC, Size: 92248 will be dropped
0:00:01.149809742 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 2 will be dropped
0:00:01.149886331 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 13530 will be dropped
0:00:01.149969762 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 43754 will be dropped
0:00:01.150124680 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 50427 will be dropped
0:00:01.150225255 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 50427 will be dropped
0:00:01.150309534 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 11566 will be dropped
0:00:01.150449786 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1603:gst_h264_parse_sps_data: value greater than max. value: 6, max 2
0:00:01.150460313 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.150467852 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.150476493 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 321 will be dropped
0:00:01.150570313 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1603:gst_h264_parse_sps_data: value greater than max. value: 6, max 2
0:00:01.150577964 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.150584596 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.150592837 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 321 will be dropped
0:00:01.150663567 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1558:gst_h264_parse_sps_data: failed to read uint8, nbits: 1
0:00:01.150671146 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.150677826 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.150686078 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 2 will be dropped
0:00:01.150787265 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1571:gst_h264_parse_sps_data: failed to read UE
0:00:01.150794924 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.150801390 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.150810064 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 59438 will be dropped
0:00:01.150908080 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 62405 will be dropped
0:00:01.151004980 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 6 SEI, Size: 71269 will be dropped
0:00:01.151081838 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 367 will be dropped
0:00:01.151165514 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 43525 will be dropped
0:00:01.151264618 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 69664 will be dropped
0:00:01.151357710 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 32419 will be dropped
0:00:01.151459868 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 16 Depth Parameter Set, Size: 60091 will be dropped
0:00:01.151539411 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 9836 will be dropped
0:00:01.151630694 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 48153 will be dropped
0:00:01.151708663 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 8992 will be dropped
0:00:01.151797758 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 56206 will be dropped
0:00:01.151907257 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 90148 will be dropped
0:00:01.151985563 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 4 Slice DPC, Size: 334 will be dropped
0:00:01.152057284 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 4540 will be dropped
0:00:01.152138488 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1571:gst_h264_parse_sps_data: failed to read UE
0:00:01.152146686 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.152153448 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.152161723 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 40643 will be dropped
0:00:01.152240973 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 13307 will be dropped
0:00:01.152388402 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:2006:gst_h264_parse_pps: value not in allowed range. value: 793, range -12-12
0:00:01.152398735 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:2046:gst_h264_parse_pps: error parsing "Picture parameter set"
0:00:01.152406135 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:882:gst_h264_parse_process_nal:<h264-parser> failed to parse PPS:
0:00:01.152414311 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 42190 will be dropped
0:00:01.152505483 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:2006:gst_h264_parse_pps: value not in allowed range. value: 793, range -12-12
0:00:01.152512689 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:2046:gst_h264_parse_pps: error parsing "Picture parameter set"
0:00:01.152519115 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:882:gst_h264_parse_process_nal:<h264-parser> failed to parse PPS:
0:00:01.152526690 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 42190 will be dropped
0:00:01.152757473 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.152768307 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.152775752 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.152784881 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.152953876 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.152963318 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.152970350 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.152978720 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.153142896 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.153151619 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.153158239 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.153167077 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.153309545 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.153317747 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.153327531 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.153336744 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.153450452 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.153459264 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.153466598 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.153475096 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.153567379 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.153574910 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.153580966 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.153588615 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.153678804 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1620:gst_h264_parse_sps_data: failed to read UE
0:00:01.153685763 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1909:gst_h264_parse_subset_sps: error parsing "Subset sequence parameter set"
0:00:01.153691781 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.153699830 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 23170 will be dropped
0:00:01.153810987 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1947:gst_h264_parse_pps: failed to read UE
0:00:01.153818338 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:2046:gst_h264_parse_pps: error parsing "Picture parameter set"
0:00:01.153824611 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:882:gst_h264_parse_process_nal:<h264-parser> failed to parse PPS:
0:00:01.153832792 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 44608 will be dropped
0:00:01.153920259 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1947:gst_h264_parse_pps: failed to read UE
0:00:01.153927048 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:2046:gst_h264_parse_pps: error parsing "Picture parameter set"
0:00:01.153932683 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:882:gst_h264_parse_process_nal:<h264-parser> failed to parse PPS:
0:00:01.153941359 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 44608 will be dropped
0:00:01.155236564 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1605:gst_h264_parse_sps_data: value greater than max. value: 38, max 12
0:00:01.155253002 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.155262241 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.155271894 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 328 will be dropped
0:00:01.155432152 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 38207 will be dropped
0:00:01.155580690 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 45775 will be dropped
0:00:01.155746576 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 66413 will be dropped
0:00:01.155893976 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 37941 will be dropped
0:00:01.156089148 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 213128 will be dropped
0:00:01.156266777 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 68449 will be dropped
0:00:01.156420033 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 24804 will be dropped
0:00:01.156551367 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 311 will be dropped
0:00:01.156719245 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 126991 will be dropped
0:00:01.156870329 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 6272 will be dropped
0:00:01.157000677 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 617 will be dropped
0:00:01.157144850 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 38146 will be dropped
0:00:01.157275481 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1605:gst_h264_parse_sps_data: value greater than max. value: 38, max 12
0:00:01.157283298 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.157289762 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.157298106 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 328 will be dropped
0:00:01.157436081 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 41886 will be dropped
0:00:01.157566896 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 2 will be dropped
0:00:01.157695874 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 12479 will be dropped
0:00:01.157823317 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 344 will be dropped
0:00:01.157951631 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 307 will be dropped
0:00:01.158095547 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 49334 will be dropped
0:00:01.158238264 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 5 Slice IDR, Size: 306 will be dropped
0:00:01.158377401 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 5 Slice IDR, Size: 306 will be dropped
0:00:01.158529201 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1571:gst_h264_parse_sps_data: failed to read UE
0:00:01.158536795 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.158543101 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.158552804 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 19876 will be dropped
0:00:01.158700335 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1571:gst_h264_parse_sps_data: failed to read UE
0:00:01.158707815 6249 0x560291e3aa40 WARN codecparsers_h264 gsth264parser.c:1817:gst_h264_parse_sps: error parsing "Sequence parameter set"
0:00:01.158714113 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:851:gst_h264_parse_process_nal:<h264-parser> failed to parse SPS:
0:00:01.158722551 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 7 SPS, Size: 19876 will be dropped
0:00:01.158861932 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 41841 will be dropped
0:00:01.159009472 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 55390 will be dropped
0:00:01.159141484 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 6 SEI, Size: 362 will be dropped
0:00:01.159285143 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 43490 will be dropped
0:00:01.159414761 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 8 PPS, Size: 38 will be dropped
0:00:01.159560203 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 39648 will be dropped
0:00:01.159761109 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 22 Invalid, Size: 203570 will be dropped
0:00:01.159966937 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 161528 will be dropped
0:00:01.160132889 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 48141 will be dropped
0:00:01.160352305 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 45717 will be dropped
0:00:01.160540986 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 45717 will be dropped
0:00:01.160674864 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 9575 will be dropped
0:00:01.160805303 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 21 Slice Depth/3D-AVC Extension, Size: 333 will be dropped
0:00:01.160951332 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 12 Filler Data, Size: 39338 will be dropped
0:00:01.161115492 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 28 Invalid, Size: 103293 will be dropped
0:00:01.161256850 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 16 will be dropped
0:00:01.161397637 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 21 Slice Depth/3D-AVC Extension, Size: 304 will be dropped
0:00:01.161532365 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 20 Slice Extension, Size: 7704 will be dropped
0:00:01.161676219 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 19 Slice Aux Unpartitioned, Size: 35390 will be dropped
0:00:01.161824163 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 7305 will be dropped
0:00:01.161958717 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 17 Reserved, Size: 323 will be dropped
0:00:01.162105532 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 17 Reserved, Size: 42218 will be dropped
0:00:01.162249148 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 21 Slice Depth/3D-AVC Extension, Size: 296 will be dropped
0:00:01.162414455 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 113388 will be dropped
0:00:01.162611989 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 187258 will be dropped
0:00:01.162779063 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 6603 will be dropped
0:00:01.162923593 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 64135 will be dropped
0:00:01.163104899 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 6 SEI, Size: 149113 will be dropped
0:00:01.163263251 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 53228 will be dropped
0:00:01.163398209 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 28 Invalid, Size: 8 will be dropped
0:00:01.163529236 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 8364 will be dropped
0:00:01.163654501 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 333 will be dropped
0:00:01.163767606 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 91651 will be dropped
0:00:01.163900425 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 303 will be dropped
0:00:01.164034877 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 346 will be dropped
0:00:01.164199861 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 4 Slice DPC, Size: 104836 will be dropped
0:00:01.164356969 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 38297 will be dropped
0:00:01.164513364 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 306 will be dropped
0:00:01.164651538 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 306 will be dropped
0:00:01.164813822 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 358 will be dropped
0:00:01.164958838 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 3 will be dropped
0:00:01.165112060 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 34308 will be dropped
0:00:01.165260197 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 330 will be dropped
0:00:01.165400128 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 7067 will be dropped
0:00:01.165532406 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 5964 will be dropped
0:00:01.165662049 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 631 will be dropped
0:00:01.165801962 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 36604 will be dropped
0:00:01.165939955 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 20960 will be dropped
0:00:01.166072382 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 3797 will be dropped
0:00:01.166282035 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 306145 will be dropped
0:00:01.166440469 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 21 Slice Depth/3D-AVC Extension, Size: 26604 will be dropped
0:00:01.166571047 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 28 will be dropped
0:00:01.166709931 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 41441 will be dropped
0:00:01.166842991 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 17 Reserved, Size: 350 will be dropped
0:00:01.166982281 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 24 Invalid, Size: 34369 will be dropped
0:00:01.167118884 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 25 Invalid, Size: 9981 will be dropped
0:00:01.167249927 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 30 Invalid, Size: 7764 will be dropped
0:00:01.167416848 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 12 Filler Data, Size: 88477 will be dropped
0:00:01.167561206 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 320 will be dropped
0:00:01.167736234 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 5 Slice IDR, Size: 104262 will be dropped
0:00:01.167899764 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 19 Slice Aux Unpartitioned, Size: 41084 will be dropped
0:00:01.168054162 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 12958 will be dropped
0:00:01.168424261 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 59261 will be dropped
0:00:01.168686096 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 59261 will be dropped
0:00:01.168872377 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 33 will be dropped
0:00:01.169051648 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 33 will be dropped
0:00:01.169259559 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 123141 will be dropped
0:00:01.169430224 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 53237 will be dropped
0:00:01.169578851 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 309 will be dropped
0:00:01.169726035 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 32 will be dropped
0:00:01.169873546 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 5 Slice IDR, Size: 9870 will be dropped
0:00:01.170022149 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 7197 will be dropped
0:00:01.170158664 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 16 will be dropped
0:00:01.170287449 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 317 will be dropped
0:00:01.170434112 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 44127 will be dropped
0:00:01.170599602 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 14 Prefix, Size: 7620 will be dropped
0:00:01.170746777 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 14 Prefix, Size: 7620 will be dropped
0:00:01.170890302 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 35846 will be dropped
0:00:01.171025131 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 13 SPS extension, Size: 9466 will be dropped
0:00:01.171167013 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 38774 will be dropped
0:00:01.171317762 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 66471 will be dropped
0:00:01.171460622 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 339 will be dropped
0:00:01.171619610 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 50248 will be dropped
0:00:01.171773794 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 7887 will be dropped
0:00:01.171926365 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 20 Slice Extension, Size: 52923 will be dropped
0:00:01.172063752 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 20 Slice Extension, Size: 6693 will be dropped
0:00:01.172210532 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 29 Invalid, Size: 58985 will be dropped
0:00:01.172360143 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 15 SPS Subset, Size: 55694 will be dropped
0:00:01.172529063 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 31220 will be dropped
0:00:01.172682523 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 16 will be dropped
0:00:01.172833740 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 23 Invalid, Size: 60468 will be dropped
0:00:01.172991857 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 31 Invalid, Size: 12403 will be dropped
0:00:01.173134926 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 26 Invalid, Size: 29002 will be dropped
0:00:01.173273294 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 21 Slice Depth/3D-AVC Extension, Size: 16226 will be dropped
0:00:01.173417853 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 43411 will be dropped
0:00:01.173565690 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 0 Unknown, Size: 50239 will be dropped
0:00:01.173766436 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 4 Slice DPC, Size: 60460 will be dropped
0:00:01.173929835 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1349:gst_h264_parse_handle_frame:<h264-parser> broken/invalid nal Type: 4 Slice DPC, Size: 60460 will be dropped
0:00:01.174118851 6249 0x560291e3aa40 WARN h264parse gsth264parse.c:1310:gst_h264_parse_handle_frame:<h264-parser> input stream is corrupt; it contains a NAL unit of length 1
Hi Jesperlyng,
Thank you for providing the log!
Are you able to use this stream with any other deepstream test sample?
platform: jetson xavier
I using the follow command:
$ ./deepstream-pose-estimation-app 20210110-02.mp4 /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-pose-estimation/images/
output:
One element could not be created. Exiting.
what is operation wrong to me?
May you should pass the uri format like $ ./deepstream-pose-estimation-app file://./20210110-02.mp4 /opt/nvidia/deepstream/deepstream-5.0/sources/apps/sample_apps/deepstream-pose-estimation/images/
I tried passing uri but my deepstream pose estimation app is killed when converting onnx model to tensorrt runtime model.
Thank you!
@mjhuria
I run my app on Jetson Xavier NX and got the same problem, anyway to solve the issue?
thank advance.
Hi Samuel,
Could you please run export GST_DEBUG=3 and then run the app? So, we can see more info on the error?
Thank you!
I converted onnx model to tensorrt engine first then passing the tensorrt path to config file and run successfully but I see that when I run on deepstream in my Jetson nano the results are worse than when I run the tensorrt model on my PC not via deepstream. What is wrong? Tks!
Hi mjhuria, thanks for replying :-)
I switched to Ubuntu 18.04, Gstreamer-1.14.5, Cuda 11.1 and TensorRT 7.2.1.6-ga. Seems it’s not that trivial to find the right combo of libs to use…
And I don’t think it made a lot of difference anyway except maybe for the gstreamer.
It still never ends unless I use a correct movie file as input, e.g. sample_720.h264.
It seems that the h264parser doesn’t like the mp4 container so even if the sample_1080p_264.mp4 is h264 encoded it fails. Or - actually it just warns about the h264parser just like before even though it should probably fail in this case.
When using the .h264 file it fails with
ERROR v4l2 gstv4l2object.c:2074:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from v4l-utils.git - media (V4L2, DVB and IR) applications and libraries
So I’m investigating this now.
When I run it in the nvidia container it works flawlessly.
Even though the sample .h264 file works it would be good to have a sample file specifically for this pose estimation app. Maybe you could share the one you use as example on blog :-) ?
Thanks for the work !
A minor update: in order to convert any video to the proper format needed by the h264parser, install ffmpeg with your preferred package manager and use
ffmpeg -i [input file] out.h264
Please, did you test the application for high resolution images (e.g. 1920 x 1080 ) using the provided pre-trained models (224x224 or 256x256). Thanks in advance.
