Creating a pipeline for all type of inferences image-inference/rtsp/video file upload.
is there any deepstream sample app exists which accept all sort of inputs and save/stream output.
Yeah, the default deepstream app does that. Just edit the config file
Please check this,
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_ref_app_deepstream.html
source group:
uri
URI to the encoded stream. The URI can be a file, an HTTP URI, or an RTSP live source. Valid when type=2 or 3. With MultiURI, the %d format specifier can also be used to specify multiple sources. The application iterates from 0 to num-sources 1 to generate the actual URIs.
sink group:
type
Type of sink, to use.
1: Fakesink
2: EGL based windowed sink (nveglglessink) will be deprecated
3: Encode + File Save (encoder + muxer + filesink)
4: Encode + RTSP streaming
5: Overlay (Jetson only) will be removed in future release
6: Message converter + Message broker
yeah this works… the issue is with image(.jpg) inference in the same pipeline
using a switch for above mentioned pipeline based on input type(file-rtsp or jpg).
Did you have streammux in your pipeline? i see you used stdemux after nvdsanalytics
I tried this bins approach but it’s stuckking… elements successfully added and linked and
I see dataflow is there.
filesrc location=xxx ! jpegparse ! nvv4l2decoder ! m.sink0
filesrc location=xxx ! jpegparse ! nvv4l2decoder ! m.sink1
nvstreammux name=m width=xxx height=xxx batch-size=2 ! …
