Creating Action Graph and Tf Trees from a python code
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA RTX 3500 Ada Generation
  • Driver Version: 565.57.01
Topic Description
Detailed Description
I am trying to use an action graph from Python code to create the tf tree of a robot. I followed the examples in the standalone application folder but have been without success so far.
Error Messages
[locobot_loader.py-3] 2025-01-28 21:02:03 [42,032ms] [Error] [ROS2BridgeHandler] Failed to create action graph: OmniGraphError: Failed to connect /ActionGraph/OnPlaybackTick.outputs:tick -> /ActionGraph/ReadSimTime.inputs:execIn [locobot_loader.py-3] [ERROR] [1738098123.600073694] [locobot_loader]: Failed to initialize LocobotLoader: Failed to setup ROS 2 bridge transforms [locobot_loader.py-3] Starting kit application with the following args: ['/home/ubuntu/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/ubuntu/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/isaacsim/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1024', '--/app/renderer/resolution/height=768', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/exts', '--ext-folder', '/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/apps', '--/physics/cudaDevice=0', '--portable'] [locobot_loader.py-3] Passing the following args to the base kit application: ['--ros-args', '-r', '__node:=locobot_loader'] [locobot_loader.py-3] Warp 1.2.1 initialized: [locobot_loader.py-3] CUDA Toolkit 11.8, Driver 12.7 [locobot_loader.py-3] Devices: [locobot_loader.py-3] "cpu" : "x86_64" [locobot_loader.py-3] "cuda:0" : "NVIDIA RTX 3500 Ada Generation Laptop GPU" (12 GiB, sm_89, mempool enabled) [locobot_loader.py-3] Kernel cache: [locobot_loader.py-3] /home/ubuntu/.cache/warp/1.2.1 [locobot_loader.py-3] Traceback (most recent call last): [locobot_loader.py-3] File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_loader.py", line 260, in main [locobot_loader.py-3] loader = LocobotLoader() [locobot_loader.py-3] File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_loader.py", line 89, in __init__ [locobot_loader.py-3] raise RuntimeError("Failed to setup ROS 2 bridge transforms") [locobot_loader.py-3] RuntimeError: Failed to setup ROS 2 bridge transforms [locobot_loader.py-3] [locobot_loader.py-3] During handling of the above exception, another exception occurred: [locobot_loader.py-3] [locobot_loader.py-3] Traceback (most recent call last): [locobot_loader.py-3] File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_loader.py", line 271, in main [locobot_loader.py-3] if loader: [locobot_loader.py-3] UnboundLocalError: local variable 'loader' referenced before assignment [locobot_loader.py-3] [locobot_loader.py-3] During handling of the above exception, another exception occurred: [locobot_loader.py-3] [locobot_loader.py-3] Traceback (most recent call last): [locobot_loader.py-3] File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_loader.py", line 281, in <module> [locobot_loader.py-3] main() [locobot_loader.py-3] File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_loader.py", line 274, in main [locobot_loader.py-3] if loader: [locobot_loader.py-3] UnboundLocalError: local variable 'loader' referenced before assignment [locobot_loader.py-3] Fatal Python error: Segmentation fault [locobot_loader.py-3] [locobot_loader.py-3] Current thread 0x000071c292bea740 (most recent call first): [locobot_loader.py-3] <no Python frame> [locobot_loader.py-3] [locobot_loader.py-3] Extension modules: omni.mdl.pymdlsdk._pymdlsdk, psutil._psutil_linux, psutil._psutil_posix, numpy.core._multiarray_umath, numpy.core._multiarray_tests, numpy.linalg._umath_linalg, numpy.fft._pocketfft_internal, numpy.random._common, numpy.random.bit_generator, numpy.random._bounded_integers, numpy.random._mt19937, numpy.random.mtrand, numpy.random._philox, numpy.random._pcg64, numpy.random._sfc64, numpy.random._generator, torch._C, torch._C._fft, torch._C._linalg, torch._C._nested, torch._C._nn, torch._C._sparse, torch._C._special, scipy._lib._ccallback_c, scipy.sparse._sparsetools, _csparsetools, scipy.sparse._csparsetools, scipy.sparse.linalg._isolve._iterative, scipy.linalg._fblas, scipy.linalg._flapack, scipy.linalg._cythonized_array_utils, scipy.linalg._flinalg, scipy.linalg._solve_toeplitz, scipy.linalg._matfuncs_sqrtm_triu, scipy.linalg.cython_lapack, scipy.linalg.cython_blas, scipy.linalg._matfuncs_expm, scipy.linalg._decomp_update, scipy.sparse.linalg._dsolve._superlu, scipy.sparse.linalg._eigen.arpack._arpack, scipy.sparse.csgraph._tools, scipy.sparse.csgraph._shortest_path, scipy.sparse.csgraph._traversal, scipy.sparse.csgraph._min_spanning_tree, scipy.sparse.csgraph._flow, scipy.sparse.csgraph._matching, scipy.sparse.csgraph._reordering, scipy.spatial._ckdtree, scipy._lib.messagestream, scipy.spatial._qhull, scipy.spatial._voronoi, scipy.spatial._distance_wrap, scipy.spatial._hausdorff, scipy.special._ufuncs_cxx, scipy.special._ufuncs, scipy.special._specfun, scipy.special._comb, scipy.special._ellip_harm_2, scipy.spatial.transform._rotation, PIL._imaging, PIL._imagingft, scipy.ndimage._nd_image, _ni_label, scipy.ndimage._ni_label, osqp._osqp, multidict._multidict, yarl._quoting_c, aiohttp._helpers, aiohttp._http_writer, aiohttp._http_parser, aiohttp._websocket, _cffi_backend, frozenlist._frozenlist, scipy.io.matlab._mio_utils, scipy.io.matlab._streams, scipy.io.matlab._mio5_utils, yaml._yaml, cv2, rcl_interfaces.rcl_interfaces_s__rosidl_typesupport_c, builtin_interfaces.builtin_interfaces_s__rosidl_typesupport_c (total: 80) [ERROR] [locobot_loader.py-3]: process has died [pid 87398, exit code -11, cmd '/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_loader.py --ros-args
Additional Information
What I’ve Tried
This is the code I implemented for that purpose
#!/usr/bin/env python3
import time
import logging
from typing import Optional, Dict, List, Tuple
import omni.graph.core as og
from omni.isaac.core.utils.extensions import enable_extension
from omni.isaac.core.utils import prims
import carb
class ROS2BridgeHandler:
    """Manages ROS 2 bridge functionality and graph nodes for Isaac Sim ROS 2 integration"""
    def __init__(self, domain_id: int = 30):
        """Initialize ROS 2 bridge handler
        Args:
            domain_id (int): ROS_DOMAIN_ID for communication
        # Setup logging
        self.logger = logging.getLogger("ROS2BridgeHandler")
        self.logger.setLevel(logging.INFO)
        # Store configuration
        self._domain_id = domain_id
        self._graph = None
        # Initialize bridge extension
        try:
            enable_extension("omni.isaac.ros2_bridge")
            time.sleep(1.0)  # Give time for extension to load
            self.logger.info("ROS 2 bridge extension enabled successfully")
        except Exception as e:
            self.logger.error(f"Failed to enable ROS 2 bridge extension: {str(e)}")
            raise
    def _validate_prim(self, prim_path: str) -> bool:
        """Validate if a prim path exists and is valid
        Args:
            prim_path (str): Path to validate
        Returns:
            bool: True if valid, False otherwise
        try:
            if not prims.is_prim_path_valid(prim_path):
                self.logger.error(f"Invalid prim path: {prim_path}")
                return False
            self.logger.info(f"Validated prim path: {prim_path}")
            return True
            self.logger.error(f"Error validating prim path: {str(e)}")
            return False
    def _create_graph_nodes(self, graph_path: str) -> Tuple[List, List]:
        """Create graph nodes and connections for ROS 2 bridge
        Args:
            graph_path (str): Path for the graph
        Returns:
            Tuple[List, List]: Nodes and connections lists
        # Base nodes required for all setups
        nodes = [
            ("OnTick", "omni.graph.action.OnPlaybackTick"),
            ("ReadSimTime", "omni.isaac.core_nodes.IsaacReadSimulationTime"),
            ("Context", "omni.isaac.ros2_bridge.ROS2Context"),
            ("PublishTF", "omni.isaac.ros2_bridge.ROS2PublishTransformTree"),
            ("PublishClock", "omni.isaac.ros2_bridge.ROS2PublishClock"),
            ("QoSConfig", "omni.isaac.ros2_bridge.ROS2QoSProfile")
        # Create base connections
        connections = [
            ("OnTick.outputs:tick", "ReadSimTime.inputs:execIn"),
            ("OnTick.outputs:tick", "PublishTF.inputs:execIn"),
            ("OnTick.outputs:tick", "PublishClock.inputs:execIn"),
            ("ReadSimTime.outputs:simulationTime", "PublishTF.inputs:timeStamp"),
            ("ReadSimTime.outputs:simulationTime", "PublishClock.inputs:timeStamp"),
            ("Context.outputs:context", "PublishTF.inputs:context"),
            ("Context.outputs:context", "PublishClock.inputs:context"),
            ("QoSConfig.outputs:qosProfile", "PublishTF.inputs:qosProfile"),
            ("QoSConfig.outputs:qosProfile", "PublishClock.inputs:qosProfile")
        return nodes, connections
    def setup_transforms(self, prim_path: str, enable_joint_states: bool = True, parent_frame: str = "world") -> bool:
        """Setup ROS 2 transformations and joint states publishing"""
        try:
            # Validate inputs
            if not self._validate_prim(prim_path):
                return False
            graph_path = "/ActionGraph"
            try:
                keys = og.Controller.Keys
                # Create graph with exact pattern from documentation
                self._graph = og.Controller.edit(
                        "graph_path": graph_path,
                        "evaluator_name": "execution"
                        keys.CREATE_NODES: [
                            ("OnPlaybackTick", "omni.graph.action.OnPlaybackTick"),
                        keys.CONNECT: [
                            ("OnPlaybackTick.outputs:tick", "ReadSimTime.inputs:execIn"),
                            ("OnPlaybackTick.outputs:tick", "PublishTF.inputs:execIn"),
                            ("OnPlaybackTick.outputs:tick", "PublishClock.inputs:execIn"),
                        keys.SET_VALUES: [
                            ("Context.inputs:domain_id", self._domain_id),
                            ("PublishTF.inputs:topicName", "/tf"),
                            ("PublishTF.inputs:targetPrims", [prim_path]),
                            ("PublishTF.inputs:parentFrameId", parent_frame),
                            ("PublishClock.inputs:topicName", "/clock")
                time.sleep(1.0)
                if enable_joint_states:
                    og.Controller.edit(
                        self._graph,
                                ("PublishJointState", "omni.isaac.ros2_bridge.ROS2PublishJointState")
                            keys.CONNECT: [
                                ("OnPlaybackTick.outputs:tick", "PublishJointState.inputs:execIn"),
                                ("ReadSimTime.outputs:simulationTime", "PublishJointState.inputs:timeStamp"),
                                ("Context.outputs:context", "PublishJointState.inputs:context")
                            keys.SET_VALUES: [
                                ("PublishJointState.inputs:topicName", "/joint_states"),
                                ("PublishJointState.inputs:targetPrim", prim_path)
                # Evaluate graph
                og.Controller.evaluate_sync(self._graph)
                time.sleep(0.5)  # Give time for evaluation
                self.logger.info("Successfully setup ROS 2 transforms")
                return True
                self.logger.error(f"Failed to create action graph: {str(e)}")
                return False
            self.logger.error(f"Failed to setup transforms: {str(e)}")
            return False
    def cleanup(self):
        """Cleanup graph resources"""
        try:
            if self._graph is not None:
                og.Controller.clear(self._graph)
                self._graph = None
                self.logger.info("ROS 2 bridge cleanup successful")
            self.logger.error(f"Error during cleanup: {str(e)}")
After looking at the Action Graph in ROS2 Transform Trees and Odometry, I discovered that I was trying to connect two blocks (On Play Tick and Read Simulation Time) that shouldn’t be connected together
