Hi, I am a newbie with Isaac gym. Basically, I want to set up an environment that involves training a model, so the environment has to be loaded to the GPU for a conventional RL task and not robotics. Is IsaacGym the right tool?
Also, I intend to wrap the environment in a vecenv wrapper to be used with stable baselines3. If IsaacGym is the right tool, can someone point me to a tutorial on how to create an environment?
I am trying to create an environment similar to this but with IsaacGym
class AdaptiveLearningRateOptimizer(gym.Env):
Optimization environment that implements the gym environment interface.
Can be used to learn an adaptive learning rate schedule.
Observations (6):
0: Training loss
1: Validation loss
2: Variance of predictions
3: Variance of prediction changes
4: Mean of output weight matrix
5: Variance of output weight matrix
6: Learning rate
Actions - Discrete (3):
0: Increases the learning rate
1: Decreases the learning rate
2: No-op
Actions - Continuous (1):
0: Scaling factor for the learning rate
def __init__(self, dataset, architecture, batch_size, update_freq, num_train_steps, initial_lr, discrete=True, action_range=1.05, lr_noise=True):
super().__init__()
data, net_fn = utils.load_dataset_and_network(dataset, architecture)
class SpecDummy():
def __init__(self, id):
self.id = id
self.spec = SpecDummy(id='AdaptiveLearningRateContinuous-v0' if not discrete else 'AdaptiveLearningRate-v0')
self.dataset = dataset
self.architecture = architecture
self.train_dataset = data[0]
self.val_dataset = data[1]
self.test_dataset = data[2]
self.net_fn = net_fn
self.batch_size = batch_size
self.update_freq = update_freq
self.num_train_steps = num_train_steps
self.initial_lr = initial_lr
self.ep_initial_lr = initial_lr
self.discrete = discrete
self.action_range = action_range
self.last_network_predictions = None
self.latest_end_val = None
if discrete:
self.action_space = spaces.Discrete(3)
else:
self.action_space = spaces.Box(
low=1/self.action_range,
high=1*self.action_range,
shape=(1,),
dtype=np.float32
self.observation_space = spaces.Box(
low=-np.inf,
high=np.inf,
shape=(7,),
dtype=np.float32
self.lr_noise = lr_noise
self.info_list = []
self.cuda = torch.cuda.is_available()
self.displayed_load_error = False
def _clip_lr(self):
Clips the learning rate to the [1e-5, 1e-1] range.
self.lr = float(np.clip(self.lr, 1e-5, 1e-1))
def _add_lr_noise(self, std=None, clip=True):
Adds Gaussian noise to the learning rate.
`std` denotes the standard deviation. Optionally clips the learning rate.
if std is None: std = 1e-5
self.lr += float(torch.empty(1).normal_(mean=0, std=std))
if clip: self._clip_lr()
def _update_lr(self, action, clip=True):
Updates the current learning rate according to a given action.
Functionality depends on whether environment is discrete or continuous.
if self.discrete:
if action == 0:
self.lr *= self.action_range
elif action == 1:
self.lr /= self.action_range
else:
self.lr *= float(action)
if self.training_steps != 0:
if self.lr_noise:
self._add_lr_noise(clip=clip)
self.schedule.step()
def test(self):
Computes loss and accuracy on a test set for the currently stored network.
test_generator = DataLoader(self.test_dataset, batch_size=self.batch_size, shuffle=False)
test_loss, test_acc = utils.AvgLoss(), utils.AvgLoss()
for x, y in test_generator:
with torch.no_grad():
if self.cuda:
x = x.cuda()
y = y.cuda()
yhat = self.net(x)
test_loss += F.cross_entropy(yhat, y)
test_acc += utils.accuracy(yhat, y)
return test_loss.avg, test_acc.avg
def step(self, action):
Takes a step in the environment and computes a new state.
self._update_lr(action)
train_loss = utils.AvgLoss()
val_loss = utils.AvgLoss()
for _ in range(self.update_freq):
if self.training_steps % self.num_train_batches == 0:
self.train_iter = iter(self.train_generator)
x, y = next(self.train_iter)
if self.cuda:
x = x.cuda()
y = y.cuda()
loss = F.cross_entropy(self.net(x), y)
train_loss += loss
self.training_steps += 1
self.optimizer.zero_grad()
loss.backward()
self.optimizer.step()
yhat_var = utils.AvgLoss()
network_predictions = []
for x, y in self.val_generator:
if self.cuda:
x = x.cuda()
y = y.cuda()
yhat = self.net(x)
val_loss += F.cross_entropy(yhat, y)
network_predictions.append(yhat)
yhat_var += yhat.var()
output_layer_weights = list(self.net.parameters())[-2]
assert output_layer_weights.size(0) == 10
network_prediction_change_var = []
for i, pred in enumerate(network_predictions):
try:
last_pred = self.last_network_predictions[i]
except:
last_pred = 0
network_prediction_change_var.append((pred - last_pred).var().cpu())
network_prediction_change_var = np.array(network_prediction_change_var).mean()
state = np.array([
train_loss.avg,
val_loss.avg,
yhat_var.avg,
network_prediction_change_var,
output_layer_weights.mean().data,
output_layer_weights.var().cpu().data,
self.lr
], dtype=np.float32)
reward = -val_loss.avg
done = self.training_steps > self.num_train_steps
info = {
'train_loss': train_loss.avg,
'val_loss': val_loss.avg,
'lr': self.lr
self.info_list.append(info)
self.last_network_predictions = deepcopy(network_predictions)
if done:
self.latest_end_val = float(val_loss.avg)
return state, reward, done, info
def reset(self, take_first_step=True):
Resets the environment and returns the initial state.
setproctitle.setproctitle('PPO2-ALRS-v0')
self.train_generator = DataLoader(self.train_dataset, batch_size=self.batch_size, shuffle=True)
self.val_generator = DataLoader(self.val_dataset, batch_size=self.batch_size, shuffle=True)
self.num_train_batches = len(list(self.train_generator))
self.training_steps = 0
self.info_list = []
self.net = self.net_fn()
if self.cuda:
self.net.cuda()
if self.initial_lr is None:
self.ep_initial_lr = float(np.random.choice([1e-2, 1e-3, 1e-4]))
else:
self.ep_initial_lr = self.initial_lr
if self.lr_noise:
self.ep_initial_lr += float(torch.empty(1).normal_(mean=0, std=self.ep_initial_lr/10))
self.ep_initial_lr = float(np.clip(self.ep_initial_lr, 1e-5, 1e-1))
self.lr = self.ep_initial_lr
self.optimizer = torch.optim.Adam(self.net.parameters(), lr=self.ep_initial_lr)
self.lambda_func = lambda _: self.lr/self.ep_initial_lr
self.schedule = torch.optim.lr_scheduler.LambdaLR(self.optimizer, lr_lambda=self.lambda_func)
if take_first_step:
state, _, _, _ = self.step(action=2 if self.discrete else 1)
return state
