Creating an outline effect on 3D objects (Scene View)
Is there a way to create an outline purple effect when hovering an object with the mouse?
I know basically how to use scene View widgets to captruie stage on hover , but creating the effect itself I don’t know.
I don’t think that’s possible currently. You could try using a ui.scene.PolygonMesh, giving it the same data as the mesh you’re hovering, and then scaling the PolygonMesh up a little. I imagine this would draw on top though.
is there a on hover selection event, like the change selection one ?
The viewport_api has a request_query function that will do what you want. The docs say that forVP1, it only works on click, but VP2 it should work for any mouse state.
