Hi everyone,
I wanted to create texture reference and an array on device(maybe in global or constant memory) and set it to the
texRef as below.
In the kernel, the texRef is defined:
texture<uchar, 2, cudaReadModeNormalizedFloat> texRef;
the `cuModule’ load the texRef, kernels without bug.
What happened is that the routines for texRef creation show 700 as CUresult (LAUNCH_FAILED)
Where can I find the bug?
Is memcopyHtoD right? (I cannot help choose this because this only use CUarray as an argument).
If I moved (3)(4)(5)(6) before(2), then they show CUDA_SUCCEED but (7) should be after (2) and it says 700 error too.
Thank you.
S.
[codebox]
//Creating array
CUDA_ARRAY_DESCRIPTOR cu_desc;
cu_desc.Width = imageWidth;
cu_desc.Height = imageHeight;
cu_desc.Format = CU_AD_FORMAT_UNSIGNED_INT32;
cu_desc.NumChannels = 1;
CUarray d_imageArray;
CU_SAFE_CALL(cuArrayCreate(&d_imageArray, &cu_desc)); //(1)
CU_SAFE_CALL(cuMemcpyHtoA(d_imageArray, 0, h_data, size)); //(2)
cutFree(h_data);
// creating tex ref.
CUtexref cuTexRef;
//CU_SAFE_CALL(cuTexRefCreate(&cuTexRef));
CU_SAFE_CALL(cuModuleGetTexRef(&cuTexRef, cuModule, "texRef")); //(3)
CU_SAFE_CALL(cuTexRefSetFilterMode(cuTexRef, CU_TR_FILTER_MODE_LINEAR)); //(4)
CU_SAFE_CALL(cuTexRefSetFlags(cuTexRef, CU_TRSF_NORMALIZED_COORDINATES)); //(5)
CU_SAFE_CALL(cuTexRefSetFormat(cuTexRef, CU_AD_FORMAT_UNSIGNED_INT32, 1)); //(6)
// setArray to cuTexRef.
CU_SAFE_CALL(cuTexRefSetArray(cuTexRef, d_imageArray, CU_TRSA_OVERRIDE_FORMAT)); //(7)
[/codebox]
