Hello @CJR,
I tried creating pipeline as you suggested. I was able to resolve some errors but errors are difficult to understand. I am posting my error and the code.
My error is -
(deepstream-nvdsanalytics-test:203): GStreamer-WARNING **: 16:08:13.115: Name ‘nvvideo-converter’ is not unique in bin ‘nvdsanalytics-test-pipeline’, not adding
(deepstream-nvdsanalytics-test:203): GStreamer-CRITICAL **: 16:08:13.116: gst_element_link_pads_full: assertion ‘GST_IS_ELEMENT (dest)’ failed
Elements could not be linked. Exiting.
My code is-
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include <math.h>
#include <string.h>
#include <sys/time.h>
#include <iostream>
#include <vector>
#include <unordered_map>
#include "gstnvdsmeta.h"
#include "nvds_analytics_meta.h"
#include "deepstream_config.h"
#ifndef PLATFORM_TEGRA
#include "gst-nvmessage.h"
#endif
int
main (int argc, char *argv[])
GMainLoop *loop = NULL;
GstElement *pipeline = NULL, *streammux = NULL, *sink = NULL, *pgie = NULL,
*nvtracker = NULL, *nvdsanalytics = NULL,
*nvvidconv = NULL, *nvosd = NULL, *nvvidconv1 = NULL, *transform1 = NULL, *cap_filter = NULL, *encoder = NULL, *codecparse = NULL, *mux = NULL, *tiler = NULL;
GstCaps *caps = NULL;
#ifdef PLATFORM_TEGRA
GstElement *transform = NULL;
#endif
GstBus *bus = NULL;
guint bus_watch_id;
GstPad *nvdsanalytics_src_pad = NULL;
guint i, num_sources;
guint tiler_rows, tiler_columns;
guint pgie_batch_size;
gulong bitrate = 2000000;
guint profile = 0;
/* Check input arguments */
if (argc < 2) {
g_printerr ("Usage: %s <uri1> [uri2] ... [uriN] \n", argv[0]);
return -1;
num_sources = argc - 1;
/* Standard GStreamer initialization */
gst_init (&argc, &argv);
loop = g_main_loop_new (NULL, FALSE);
/* Create gstreamer elements */
/* Create Pipeline element that will form a connection of other elements */
pipeline = gst_pipeline_new ("nvdsanalytics-test-pipeline");
/* Create nvstreammux instance to form batches from one or more sources. */
streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
if (!pipeline || !streammux) {
g_printerr ("One element could not be created. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), streammux);
for (i = 0; i < num_sources; i++) {
GstPad *sinkpad, *srcpad;
gchar pad_name[16] = { };
GstElement *source_bin = create_source_bin (i, argv[i + 1]);
if (!source_bin) {
g_printerr ("Failed to create source bin. Exiting.\n");
return -1;
gst_bin_add (GST_BIN (pipeline), source_bin);
g_snprintf (pad_name, 15, "sink_%u", i);
sinkpad = gst_element_get_request_pad (streammux, pad_name);
if (!sinkpad) {
g_printerr ("Streammux request sink pad failed. Exiting.\n");
return -1;
srcpad = gst_element_get_static_pad (source_bin, "src");
if (!srcpad) {
g_printerr ("Failed to get src pad of source bin. Exiting.\n");
return -1;
if (gst_pad_link (srcpad, sinkpad) != GST_PAD_LINK_OK) {
g_printerr ("Failed to link source bin to stream muxer. Exiting.\n");
return -1;
gst_object_unref (srcpad);
gst_object_unref (sinkpad);
/* Use nvinfer to infer on batched frame. */
pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
/* Use nvtracker to track detections on batched frame. */
nvtracker = gst_element_factory_make ("nvtracker", "nvtracker");
/* Use nvdsanalytics to perform analytics on object */
nvdsanalytics = gst_element_factory_make ("nvdsanalytics", "nvdsanalytics");
/* Use nvtiler to composite the batched frames into a 2D tiled array based
* on the source of the frames. */
tiler = gst_element_factory_make ("nvmultistreamtiler", "nvtiler");
/* Use convertor to convert from NV12 to RGBA as required by nvosd */
nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
if (!nvvidconv) {
g_printerr ("nvvdiconv element could not be created. Exiting.\n");
/* Create OSD to draw on the converted RGBA buffer */
nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
if (!nvosd) {
g_printerr ("nvosd element could not be created. Exiting.\n");
/* converter to convert RGBA to NV12 */
nvvidconv1 = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter1");
if (!nvvidconv1) {
g_printerr ("nvvidconv1 element could not be created. Exiting.\n");
/*create cap_filter */
cap_filter = gst_element_factory_make (NVDS_ELEM_CAPS_FILTER, "cap_filter");
if (!cap_filter) {
g_printerr ("cap_filter element could not be created. Exiting.\n");
/* create cap for filter */
caps = gst_caps_from_string ("video/x-raw, format=I420");
g_object_set (G_OBJECT (cap_filter), "caps", caps, NULL);
/* creatge encoder*/
encoder = gst_element_factory_make (NVDS_ELEM_ENC_H264_HW, "encoder");
if (!encoder) {
g_printerr ("encoder element could not be created. Exiting.\n");
/* create transform1 */
transform1 = gst_element_factory_make (NVDS_ELEM_VIDEO_CONV, "transform1");
g_object_set (G_OBJECT (transform1), "gpu-id", 0, NULL);
if (!transform1) {
g_printerr ("transform1 element could not be created. Exiting.\n");
#ifdef IS_TEGRA
g_object_set (G_OBJECT (encoder), "bufapi-version", 1, NULL);
#endif
g_object_set (G_OBJECT (encoder), "profile", profile, NULL);
g_object_set (G_OBJECT (encoder), "bitrate", bitrate, NULL);
/* create codecparse */
codecparse = gst_element_factory_make ("h264parse", "h264-parser");
if (!codecparse) {
g_printerr ("codecparse element could not be created. Exiting.\n");
/* create mux */
mux = gst_element_factory_make (NVDS_ELEM_MUX_MP4, "mux");
if (!mux) {
g_printerr ("mux element could not be created. Exiting.\n");
/* create sink */
sink = gst_element_factory_make (NVDS_ELEM_SINK_FILE, "filesink");
if (!sink) {
g_printerr ("sink element could not be created. Exiting.\n");
g_object_set (G_OBJECT (sink), "location", "capture.mp4", "sync", 0, "async" , FALSE, NULL);
// /* Finally render the osd output */
transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
// sink = gst_element_factory_make (NVDS_ELEM_SINK_FILE, "filesink");
// g_object_set (G_OBJECT (sink), "location", "capture.mp4", "sync", 0, "async" , FALSE, NULL);
if (!pgie || !nvtracker || !nvdsanalytics || !nvvidconv ||
!nvosd || !nvvidconv1 || !cap_filter || !encoder || !codecparse || !mux || !sink) {
return -1;
if(!transform) {
g_printerr ("One tegra element could not be created. Exiting.\n");
return -1;
#endif
g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
MUXER_OUTPUT_HEIGHT, "batch-size", num_sources,
"batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
/* Configure the nvinfer element using the nvinfer config file. */
g_object_set (G_OBJECT (pgie),
"config-file-path", "nvdsanalytics_pgie_config.txt", NULL);
/* Configure the nvtracker element for using the particular tracker algorithm. */
g_object_set (G_OBJECT (nvtracker),
"ll-lib-file", "/opt/nvidia/deepstream/deepstream-5.0/lib/libnvds_nvdcf.so",
"ll-config-file", "tracker_config.yml", "tracker-width", 640, "tracker-height", 480,
NULL);
/* Configure the nvdsanalytics element for using the particular analytics config file*/
g_object_set (G_OBJECT (nvdsanalytics),
"config-file", "config_nvdsanalytics.txt",
NULL);
/* Override the batch-size set in the config file with the number of sources. */
g_object_get (G_OBJECT (pgie), "batch-size", &pgie_batch_size, NULL);
if (pgie_batch_size != num_sources) {
g_printerr
("WARNING: Overriding infer-config batch-size (%d) with number of sources (%d)\n",
pgie_batch_size, num_sources);
g_object_set (G_OBJECT (pgie), "batch-size", num_sources, NULL);
tiler_rows = (guint) sqrt (num_sources);
tiler_columns = (guint) ceil (1.0 * num_sources / tiler_rows);
/* we set the tiler properties here */
g_object_set (G_OBJECT (tiler), "rows", tiler_rows, "columns", tiler_columns,
"width", TILED_OUTPUT_WIDTH, "height", TILED_OUTPUT_HEIGHT, NULL);
/* we add a message handler */
bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
gst_object_unref (bus);
/* Set up the pipeline */
/* we add all elements into the pipeline */
gst_bin_add_many (GST_BIN (pipeline), pgie, nvtracker, nvdsanalytics ,
nvvidconv, nvosd, nvvidconv1, cap_filter, encoder, codecparse, mux, sink,
NULL);
/* we link the elements together
* nvstreammux -> nvinfer -> nvtracker -> nvdsanalytics -> nvtiler ->
* nvvideoconvert -> nvosd -> transform -> sink
if (!gst_element_link_many (streammux, pgie, nvtracker, nvdsanalytics,
nvvidconv, nvosd, nvvidconv1, cap_filter, encoder, codecparse, mux, sink, NULL)) {
g_printerr ("Elements could not be linked. Exiting.\n");
return -1;
#else
gst_bin_add_many (GST_BIN (pipeline), pgie, nvtracker, nvdsanalytics,
nvvidconv, nvosd, nvvidconv1, cap_filter, encoder, codecparse, mux, sink, NULL);
* nvvideoconvert -> nvosd -> sink
return -1;
#endif
/* Lets add probe to get informed of the meta data generated, we add probe to
* the sink pad of the nvdsanalytics element, since by that time, the buffer
* would have had got all the metadata.
nvdsanalytics_src_pad = gst_element_get_static_pad (nvdsanalytics, "src");
if (!nvdsanalytics_src_pad)
g_print ("Unable to get src pad\n");
else
gst_pad_add_probe (nvdsanalytics_src_pad, GST_PAD_PROBE_TYPE_BUFFER,
nvdsanalytics_src_pad_buffer_probe, NULL, NULL);
/* Set the pipeline to "playing" state */
g_print ("Now playing:");
g_print (" %s,", argv[i + 1]);
g_print ("\n");
gst_element_set_state (pipeline, GST_STATE_PLAYING);
/* Wait till pipeline encounters an error or EOS */
g_print ("Running...\n");
g_main_loop_run (loop);
/* Out of the main loop, clean up nicely */
g_print ("Returned, stopping playback\n");
gst_element_set_state (pipeline, GST_STATE_NULL);
g_print ("Deleting pipeline\n");
gst_object_unref (GST_OBJECT (pipeline));
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
Please have a look.
Thanks in advance
