I am trying to create a Fortran based DLL with OpenMP for use in Excel VBA. I am able to successfully create and use the non-OpenMP version. However, as soon as I include the OpenMP directives, and create the DLL, Excel crashes as soon as tries to use the DLL. If I compile the same code as an executable, I see the expected OpenMP behavior and output.
!program main
!implicit none
!real*8::xx(4,4),yy(4,4)
!xx=1.D0
!yy=0.D0
!call myarrtest(xx,yy,4,4)
!write(*,*) xx
!write(*,*) yy
!end program
subroutine myarrtest(arrin,arrout,sz1,sz2)
use omp_lib
!DEC$ ATTRIBUTES DLLEXPORT,STDCALL,REFERENCE,DECORATE,ALIAS:'myarrtest'::myarrtest
!DEC$ ATTRIBUTES REFERENCE::arrin,arrout,sz1,sz2
implicit none
integer*2::nthreads,tid
integer*2::i,j
integer*2,intent(in)::sz1,sz2
real*8,intent(in)::arrin(sz1,sz2)
real*8,intent(out)::arrout(sz1,sz2)
!$omp parallel num_threads(4) private(nthreads, tid)
tid = omp_get_thread_num()
!if (tid .eq. 0) then
!nthreads = omp_get_num_threads()
!print *, 'Number of threads = ', nthreads
!end if
!print *, 'Hello World from thread = ', tid
do j=1,sz2
arrout(tid+1,j)=(tid+1)*arrin(tid+1,j)
end do
!$omp end parallel
end subroutine
I compile the above code using the following command
pgfortran -mp -Mmakedll -Bstatic -o myarrtest_openmp.dll myarrtest_openmp.f90
The executable can be compiled by adding/removing appropriate comments. The executable seems to work fine.
The Excel side of VBA call is as follows.
Declare Sub myarrtest Lib "C:\OpenShare\Programming_Stuff\Fortran_Apps\Excel_Fortran_DLL\mytest\myarrtest_openmp.dll" _
(ByRef x As Double, ByRef y As Double, ByRef n1 As Integer, ByRef n2 As Integer)
Call myarrtest(vbarr(1, 1), fortarr(1, 1), n1, n2)
Any ideas of why the OpenMP setup crashes in Excel would be greatly appreciated. On a side note, I was able to successfully achieve this using Intel Fortran. I am hoping to solve this as I would like to eventually move towards a hybrid OpenMP+CUDA Fortran implementation.
Thanks in advance,
- Sam V
