How would we implement this on a discrete GPU using NvBufSurfaceCreate()? gst_nvds_buffer_pool_new() can create a pool of buffers, however it is causes jitter issues on aother running process when acquiring the buffer. I am specifically looking to generate NVMM buffers using NvBufSurfaceCreate() so I can have control over the allocation of the GPU memory.
There is sample of how to use NvBufSurfaceCreate() in dsexample codes. Please refer to /opt/nvidia/deepstream/deepstream/sources/gst-plugins/gst-dsexample
@Fiona.Chen
Although NvBufSurfaceCreate() is used in the dsexample codes, it is not combined with any gstreamer functions that wrap the GPU buffer onto a GstBuffer. The example is for a transform plugin where a transformation is performed on the buffer created with NvBufSurfaceCreate() as opposed to a source plugin which generates the GstBuffer like the appsrc example in the zip file.
Yes, the gst-nvdsvideotemplate example uses gst_nvds_buffer_pool_new() to generate a GstBuffer, I mentioned it is causing jitter on another time sensitive process which is ran persistently. The jitter is caused when the call is made to acquire the buffer using gst_buffer_pool_acquire_buffer. This method is timed to last over 100us and causes jitter up to 400us on another process. The reason why I am specifically looking to use NvBufSurfaceCreate() is because I would have control over the allocation of the memory which I’m suspecting is done repetitively with gst_nvds_buffer_pool_new().
gst_nvds_buffer_pool_new() generates GstBuffers with NvBufSurface, and the GstBuffers can be used repeatedly in the pipeline. I don’t understand your description of the jitter issue, the buffers will be used in loop. You just need to create them once the pipeline is initialized.
A separate process that’s not using deepstream has processing time within 1.9 to 2.1 ms. When running deepstream with the gst_nvds_buffer_pool_new() and gst_pool_acquire_buffer() the timing of the other mentioned process takes between 1.6 to 2.4 ms. So before the jitter was about ±100us and after it became ±400us.
I’m not sure if this is going to fix the jitter issue but I figured out how to create the GstBuffers without gst_nvds_buffer_pool_new() and gst_buffer_acquire_buffer and instead using NvBufSurfaceCreate():
