I’m a beginner at using OptiX. I’m starting code development from several sample codes. Now I’d like to generate multiple pipelines with a single module, and I wrote codes below:
//-----------Generate pipelines--------------
constexpr char *raygen_program[]{"__raygen__pinhole", "__raygen__simplehit"};
constexpr char *misshit_program[]{"__miss__radiance", "__miss__simplehit"};
for (int i = 0; i < numPipeLine; i++) {//Want to generate numPipeLine pipelines.
pipeline[i] = nullptr;
vector<OptixProgramGroup> prgs_per_pipeline = program_group;//program_group has closest hit, intersection, and direct callables.
// i-th Ray generation program
OptixProgramGroupOptions raygen_prg_options = {};
OptixProgramGroupDesc raygen_prg_desc = {};
raygen_prg_desc.kind = OPTIX_PROGRAM_GROUP_KIND_RAYGEN;
raygen_prg_desc.raygen.module = module;
raygen_prg_desc.raygen.entryFunctionName = raygen_program[i];
OPTIX_CHECK_LOG(optixProgramGroupCreate(context, &raygen_prg_desc, 1, &raygen_prg_options, log, &sizeof_log, &raygen_prg[i]));
prgs_per_pipeline.push_back(raygen_prg[i]);//Raygen program is push backed for optixPipelineCreate
// i-th Miss hit program
OptixProgramGroupOptions miss_prg_options = {};
OptixProgramGroupDesc miss_prg_desc = {};
miss_prg_desc.kind = OPTIX_PROGRAM_GROUP_KIND_MISS;
miss_prg_desc.miss.module = module;
miss_prg_desc.miss.entryFunctionName = misshit_program[i];
OPTIX_CHECK_LOG(optixProgramGroupCreate(context, &miss_prg_desc, 1, &miss_prg_options, log, &sizeof_log, &miss_prg[i]));
prgs_per_pipeline.push_back(miss_prg[i]);//Miss hit program is push backed for optixPipelineCreate
//optixPipelineCreate for i-th pipeline
OptixPipelineLinkOptions pipe_link_option = {};
pipe_link_option.maxTraceDepth = 5;
pipe_link_option.debugLevel = OPTIX_COMPILE_DEBUG_LEVEL_FULL;
OPTIX_CHECK_LOG(optixPipelineCreate(context, &pipeline_compile_options, &pipe_link_option, prgs_per_pipeline.data(), prgs_per_pipeline.size(), log, &sizeof_log, &pipeline[i]));
OptixStackSizes stack_sizes = {};
for (auto &&prg: prgs_per_pipeline) OPTIX_CHECK(optixUtilAccumulateStackSizes(prg, &stack_sizes));
uint32_t stack_size_traversable, stack_size_state, continuation_stack_size;
OPTIX_CHECK(optixUtilComputeStackSizes(&stack_sizes, pipe_link_option.maxTraceDepth, 0, 3, &stack_size_traversable, &stack_size_state, &continuation_stack_size));
OPTIX_CHECK(optixPipelineSetStackSize(pipeline[i], stack_size_traversable, stack_size_state, continuation_stack_size, 2));
//-----------End Generate pipelines---------------
The code could be compiled with no error. Then I expected the following code can switch the pipelines called by changing i:
OPTIX_CHECK(optixLaunch(pipeline[i], stream, params_on_device, sizeof(Params), &sbt, params.width, params.height, 1));
However, the code always calls pipeline[0] even if i is set to 1. So what is my mistake?
Any help is greatly appreciated.
Kai
