Creating my own splash screen on the Jetson Xavier-NX using Jetpack 4.4
Hello Nvidia Forum,
I have tried to create my own splash screen by following the bmp-blob-README.txt instructions found in the Linux_for_Tegra/tools/bmp-splash directory.
I have created a 1920x1080 24bpp (Windows format) BMP image and placed it in the Linux_for_Tegra/tools/bmp-splash directory. I then ran the command:
OUT=$PWD ./genbmpblob_L4T.sh t210 ./config_file ./BMP_generator_L4T.py /usr/bin/lz4c my-bmp.blob
I was getting a few errors relating to the BMP_generator_L4T.py script, but have realised that I had to use Python 2.7. I now use the command:
OUT=$PWD /usr/bin/python2.7 ./genbmpblob_L4T.sh t210 ./config_file ./BMP_generator_L4T.py /usr/bin/lz4c my-bmp.blob
When I run the command I am getting the following error:
File “./genbmpblob_L4T.sh”, line 15
function compress_blob()
SyntaxError: invalid syntax
On my terminal, the ^ sign is positioned below the second b in the word blob. I haven’t made any changes to the genbmpblob_L4T.sh script, so I am unsure why I am getting a syntax error. Could you please advise on what the issue may be?
Many thanks,
Gavin
Sorry for the late reply.
I don’t think specifying /usr/bin/python2.7 makes any changes.
Try modifying the shebang in BMP_generator_L4T.py.
#!/usr/bin/python2.7
# Copyright (c) 2017-2020, NVIDIA CORPORATION.  All rights reserved.
# NVIDIA Corporation and its licensors retain all intellectual property
# and proprietary rights in and to this software, related documentation
# and any modifications thereto.  Any use, reproduction, disclosure or
# distribution of this software and related documentation without an express
# license agreement from NVIDIA Corporation is strictly prohibited.
Appendix:
    when blob-type = bmp , entry tuple format is:
        <filename bmp-type bmp-resolution>
    currently supported bmp-types: nvidia
    currently supported bmp-resolutions: 480, 720, 810, 1080, 4k.
    example: BMP_generator.py -t bmp -e "nvidia.bmp nvidia 720"
Hi DaveYYY,
Thank you for your reply.
Your advice has worked perfectly. Thank you.
I have just one final question. Is it possible to change the duration of how long the splash screen displays? It currently displays for approx. 1 second. Ideally I would like it to display for a bit longer.
Many thanks,
Gavin
Sorry but I don’t think that’s configurable.
Ah, that’s no problem.
Thanks again for your help!
Gavin
