Creating Plugnins for tensorrt (operation : _Cast )
I successfully trained the ssd inception V2 model on a custom class and converted the frozen graph into the UFF file. Then using C++, when i try to parse the Uff file for inference and creating the engine, i get the following error.
…/…/…/Desktop/ssd_trt/incep_new_odapi.uff
Begin parsing model…
ERROR: UFFParser: Validator error: Cast: Unsupported operation _Cast
ERROR: sample_uff_mnist: Fail to parse
testssd: /home/nvidia/Desktop/ssd_trt/testssd.cpp:628: int main(int, char**): Assertion `tmpengine != nullptr’ failed.
Aborted (core dumped)
From the error, we can see that _Cast operation is unsupported. How can I create the custom plugins so that i could do the inference on my trained model.
I have read the documentation from https://docs.nvidia.com/deeplearning/sdk/tensorrt-developer-guide/index.html#c_topics and also https://github.com/NVIDIA/TensorRT/tree/release/5.1/plugin but they are too complex to follow. Is there any simple example that show how a plugin should be written and integrated with the inference code.
We have a sample for ssd inception V2 model and it is located at /usr/src/tensorrt/samples/sampleUffSSD/.
Please use the config.py in the folder to convert .pb file into uff model.
It also includes the required plugin layer: FlattenConcat and you can use it directly.
Hello AastaLL,
I have used the very same configuration file to convert the frozen graph to get the UFF file. As seen from the config.py, it implements the plugin layer “FlattenConcat” but the error that I am getting is for cast operation "_Cast ".
  1. Are you recommending me to use the same method as “FlattenConcat” to add the plugin layer for “_Cast” in the config file?
  2. Then what would be the equivalent operation for Cast in TensorRT ?
concat_box_loc = gs.create_plugin_node("concat_box_loc", op="FlattenConcat_TRT")
concat_box_conf = gs.create_plugin_node("concat_box_conf", op="FlattenConcat_TRT")
namespace_plugin_map = {
    "MultipleGridAnchorGenerator": PriorBox,
    "Postprocessor": NMS,
    "Preprocessor": Input,
    "ToFloat": Input,
    "image_tensor": Input,
    "MultipleGridAnchorGenerator/Concatenate": concat_priorbox,
    "concat": concat_box_loc,
    "concat_1": concat_box_conf
so from above, concat and concat_1 are replaced by FlattenConcat_TRT, so would it be same from Cast too and with what operation ?
  1. Also the C++ program in /usr/src/tensorrt/samples/sampleUffSSD/ has the C++ code for the plugin FlattenConcat as seen below. Should I write the same kind of C++ code for Cast operation ? if yes, how should I write it ? As seen from the code, it looks quite complex with several operations ? i could not find any documentation that would help understand to write a plugin.
class FlattenConcat : public IPluginV2
public:
    FlattenConcat(int concatAxis, bool ignoreBatch)
        : mIgnoreBatch(ignoreBatch)
        , mConcatAxisID(concatAxis)
        assert(mConcatAxisID == 1 || mConcatAxisID == 2 || mConcatAxisID == 3);
    //clone constructor
    FlattenConcat(int concatAxis, bool ignoreBatch, int numInputs, int outputConcatAxis, int* inputConcatAxis)
        , mOutputConcatAxis(outputConcatAxis)
        , mNumInputs(numInputs)
        CHECK(cudaMallocHost((void**) &mInputConcatAxis, mNumInputs * sizeof(int)));
        for (int i = 0; i < mNumInputs; ++i)
            mInputConcatAxis[i] = inputConcatAxis[i];
    FlattenConcat(const void* data, size_t length)
        const char *d = reinterpret_cast<const char*>(data), *a = d;
        mIgnoreBatch = read<bool>(d);
        mConcatAxisID = read<int>(d);
        mOutputConcatAxis = read<int>(d);
        mNumInputs = read<int>(d);
        CHECK(cudaMallocHost((void**) &mCopySize, mNumInputs * sizeof(int)));
        std::for_each(mInputConcatAxis, mInputConcatAxis + mNumInputs, [&](int& inp) { inp = read<int>(d); });
        mCHW = read<nvinfer1::DimsCHW>(d);
        std::for_each(mCopySize, mCopySize + mNumInputs, [&](size_t& inp) { inp = read<size_t>(d); });
        assert(d == a + length);
    ~FlattenConcat()
        if (mInputConcatAxis)
            CHECK(cudaFreeHost(mInputConcatAxis));
        if (mCopySize)
            CHECK(cudaFreeHost(mCopySize));
    int getNbOutputs() const override { return 1; }
    Dims getOutputDimensions(int index, const Dims* inputs, int nbInputDims) override
        assert(nbInputDims >= 1);
        assert(index == 0);
        mNumInputs = nbInputDims;
        mOutputConcatAxis = 0;
#ifdef SSD_INT8_DEBUG
        std::cout << " Concat nbInputs " << nbInputDims << "\n";
        std::cout << " Concat axis " << mConcatAxisID << "\n";
        for (int i = 0; i < 6; ++i)
            for (int j = 0; j < 3; ++j)
                std::cout << " Concat InputDims[" << i << "]"
                          << "d[" << j << " is " << inputs[i].d[j] << "\n";
#endif
        for (int i = 0; i < nbInputDims; ++i)
            int flattenInput = 0;
            assert(inputs[i].nbDims == 3);
            if (mConcatAxisID != 1)
                assert(inputs[i].d[0] == inputs[0].d[0]);
            if (mConcatAxisID != 2)
                assert(inputs[i].d[1] == inputs[0].d[1]);
            if (mConcatAxisID != 3)
                assert(inputs[i].d[2] == inputs[0].d[2]);
            flattenInput = inputs[i].d[0] * inputs[i].d[1] * inputs[i].d[2];
            mInputConcatAxis[i] = flattenInput;
            mOutputConcatAxis += mInputConcatAxis[i];
        return DimsCHW(mConcatAxisID == 1 ? mOutputConcatAxis : 1,
                       mConcatAxisID == 2 ? mOutputConcatAxis : 1,
                       mConcatAxisID == 3 ? mOutputConcatAxis : 1);
    int initialize() override
        CHECK(cublasCreate(&mCublas));
        return 0;
    void terminate() override
        CHECK(cublasDestroy(mCublas));
    size_t getWorkspaceSize(int) const override { return 0; }
    int enqueue(int batchSize, const void* const* inputs, void** outputs, void*, cudaStream_t stream) override
        int numConcats = 1;
        assert(mConcatAxisID != 0);
        numConcats = std::accumulate(mCHW.d, mCHW.d + mConcatAxisID - 1, 1, std::multiplies<int>());
        if (!mIgnoreBatch)
            numConcats *= batchSize;
        float* output = reinterpret_cast<float*>(outputs[0]);
        int offset = 0;
            const float* input = reinterpret_cast<const float*>(inputs[i]);
            float* inputTemp;
            CHECK(cudaMalloc(&inputTemp, mCopySize[i] * batchSize));
            CHECK(cudaMemcpyAsync(inputTemp, input, mCopySize[i] * batchSize, cudaMemcpyDeviceToDevice, stream));
            for (int n = 0; n < numConcats; ++n)
                CHECK(cublasScopy(mCublas, mInputConcatAxis[i],
                                  inputTemp + n * mInputConcatAxis[i], 1,
                                  output + (n * mOutputConcatAxis + offset), 1));
            CHECK(cudaFree(inputTemp));
            offset += mInputConcatAxis[i];
        return 0;
    size_t getSerializationSize() const override
        return sizeof(bool) + sizeof(int) * (3 + mNumInputs) + sizeof(nvinfer1::Dims) + (sizeof(mCopySize) * mNumInputs);
    void serialize(void* buffer) const override
        char *d = reinterpret_cast<char*>(buffer), *a = d;
        write(d, mIgnoreBatch);
        write(d, mConcatAxisID);
        write(d, mOutputConcatAxis);
        write(d, mNumInputs);
            write(d, mInputConcatAxis[i]);
        write(d, mCHW);
            write(d, mCopySize[i]);
        assert(d == a + getSerializationSize());
    void configureWithFormat(const Dims* inputs, int nbInputs, const Dims* outputDims, int nbOutputs, nvinfer1::DataType type, nvinfer1::PluginFormat format, int maxBatchSize) override
        assert(nbOutputs == 1);
        mCHW = inputs[0];
        assert(inputs[0].nbDims == 3);
        CHECK(cudaMallocHost((void**) &mCopySize, nbInputs * sizeof(int)));
        for (int i = 0; i < nbInputs; ++i)
            mCopySize[i] = inputs[i].d[0] * inputs[i].d[1] * inputs[i].d[2] * sizeof(float);
    bool supportsFormat(nvinfer1::DataType type, PluginFormat format) const override
        return (type == nvinfer1::DataType::kFLOAT && format == PluginFormat::kNCHW);
    const char* getPluginType() const override { return "FlattenConcat_TRT"; }
    const char* getPluginVersion() const override { return "1"; }
    void destroy() override { delete this; }
    IPluginV2* clone() const override
        return new FlattenConcat(mConcatAxisID, mIgnoreBatch, mNumInputs, mOutputConcatAxis, mInputConcatAxis);
    void setPluginNamespace(const char* libNamespace) override { mNamespace = libNamespace; }
    const char* getPluginNamespace() const override { return mNamespace.c_str(); }
private:
    template <typename T>
    void write(char*& buffer, const T& val) const
        *reinterpret_cast<T*>(buffer) = val;
        buffer += sizeof(T);
    T read(const char*& buffer)
        T val = *reinterpret_cast<const T*>(buffer);
        return val;
    size_t* mCopySize = nullptr;
    bool mIgnoreBatch{false};
    int mConcatAxisID{0}, mOutputConcatAxis{0}, mNumInputs{0};
    int* mInputConcatAxis = nullptr;
    nvinfer1::Dims mCHW;
    cublasHandle_t mCublas;
    std::string mNamespace;
namespace
const char* FLATTENCONCAT_PLUGIN_VERSION{"1"};
const char* FLATTENCONCAT_PLUGIN_NAME{"FlattenConcat_TRT"};
} // namespace
class FlattenConcatPluginCreator : public IPluginCreator
public:
    FlattenConcatPluginCreator()
        mPluginAttributes.emplace_back(PluginField("axis", nullptr, PluginFieldType::kINT32, 1));
        mPluginAttributes.emplace_back(PluginField("ignoreBatch", nullptr, PluginFieldType::kINT32, 1));
        mFC.nbFields = mPluginAttributes.size();
        mFC.fields = mPluginAttributes.data();
    ~FlattenConcatPluginCreator() {}
    const char* getPluginName() const override { return FLATTENCONCAT_PLUGIN_NAME; }
    const char* getPluginVersion() const override { return FLATTENCONCAT_PLUGIN_VERSION; }
    const PluginFieldCollection* getFieldNames() override { return &mFC; }
    IPluginV2* createPlugin(const char* name, const PluginFieldCollection* fc) override
        const PluginField* fields = fc->fields;
        for (int i = 0; i < fc->nbFields; ++i)
            const char* attrName = fields[i].name;
            if (!strcmp(attrName, "axis"))
                assert(fields[i].type == PluginFieldType::kINT32);
                mConcatAxisID = *(static_cast<const int*>(fields[i].data));
            if (!strcmp(attrName, "ignoreBatch"))
                mIgnoreBatch = *(static_cast<const bool*>(fields[i].data));
        return new FlattenConcat(mConcatAxisID, mIgnoreBatch);
    IPluginV2* deserializePlugin(const char* name, const void* serialData, size_t serialLength) override
        //This object will be deleted when the network is destroyed, which will
        //call Concat::destroy()
        return new FlattenConcat(serialData, serialLength);
private:
    static PluginFieldCollection mFC;
    int mConcatAxisID;
    static std::vector<PluginField> mPluginAttributes;
    std::string mNamespace = "";
PluginFieldCollection FlattenConcatPluginCreator::mFC{};
std::vector<PluginField> FlattenConcatPluginCreator::mPluginAttributes;
REGISTER_TENSORRT_PLUGIN(FlattenConcatPluginCreator);
Sorry for the late update.
Have you fixed this issue?
If not, would you mind to share current status with us?
Hey,
I am still not able to understand the procedure to create the custom plugin for the “Cast” operation !! I am reading forums and blogs about them , but still stuck at the plugin creating stage !! Any help would be appreciated !!
Thank you !!
Please check the config here:
https://devtalk.nvidia.com/default/topic/1056054/jetson-tx2/how-to-retrain-ssd_inception_v2_coco_2017_11_17-from-the-tensorrt-samples/post/5386149/#5386149
