Hi, I would like to create YUV images to be streamed over ROS from the NvMediaImage. However, using the nvmedia_imgplay sample, I noticed that the YUV output was written to a file, but this was slightly different from creating a single YUV image with an NvMediaImage. Could I check if it is possible to create a single YUV image from the NvMediaImage obtained from a single frame rendered from the image decoder?
Thank you!
