I am trying to save detected object from a camera stream into PNG image.
So far I am having Segmentation faults, on a cudaFromNumpy
Have no clue why this happens. Debug prints of numpy array looks ok, sizes are in range.
Previously tried to use Python PIL
library, but images wasn’t right.
Described PIL attemp in this issue:
https://github.com/dusty-nv/jetson-inference/issues/463
#!/usr/bin/python
# Copyright (c) 2019, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
import jetson.inference
import jetson.utils
import argparse
import sys
from PIL import Image
import tempfile
import numpy
# parse the command line
parser = argparse.ArgumentParser(description="Locate objects in a live camera stream using an object detection DNN.",
formatter_class=argparse.RawTextHelpFormatter, epilog=jetson.inference.detectNet.Usage())
parser.add_argument("--network", type=str, default="ssd-mobilenet-v2", help="pre-trained model to load (see below for options)")
parser.add_argument("--overlay", type=str, default="box,labels,conf", help="detection overlay flags (e.g. --overlay=box,labels,conf)\nvalid combinations are: 'box', 'labels', 'conf', 'none'")
parser.add_argument("--threshold", type=float, default=0.5, help="minimum detection threshold to use")
parser.add_argument("--camera", type=str, default="0", help="index of the MIPI CSI camera to use (e.g. CSI camera 0)\nor for VL42 cameras, the /dev/video device to use.\nby default, MIPI CSI camera 0 will be used.")
parser.add_argument("--width", type=int, default=1280, help="desired width of camera stream (default is 1280 pixels)")
parser.add_argument("--height", type=int, default=720, help="desired height of camera stream (default is 720 pixels)")
try:
opt = parser.parse_known_args()[0]
except:
print("")
parser.print_help()
sys.exit(0)
# load the object detection network
net = jetson.inference.detectNet(opt.network, sys.argv, opt.threshold)
# create the camera and display
camera = jetson.utils.gstCamera(opt.width, opt.height, opt.camera)
display = jetson.utils.glDisplay()
# process frames until user exits
with tempfile.TemporaryDirectory() as tmpdirname:
while display.IsOpen():
# capture the image
img, width, height = camera.CaptureRGBA(zeroCopy=1)
jetson.utils.cudaDeviceSynchronize()
# detect objects in the image (with overlay)
detections = net.Detect(img, width, height, opt.overlay)
# print the detections
print("detected {:d} objects in image".format(len(detections)))
array = jetson.utils.cudaToNumpy(img, width, height, 4)
for detection in detections:
print(detection)
im = Image.fromarray(array, "RGBA")
cropped = im.crop((detection.Left, detection.Top, detection.Right, detection.Bottom))
path = tmpdirname + "/" + str(detection.Instance) + ".png"
# cropped.save(path, "PNG")
cuda_mem = jetson.utils.cudaFromNumpy(numpy.array(cropped))
jetson.utils.saveImageRGBA(path, cuda_mem, width, height)
print("detection stored at: " + path)
# render the image
display.RenderOnce(img, width, height)
# update the title bar
display.SetTitle("{:s} | Network {:.0f} FPS".format(opt.network, net.GetNetworkFPS()))
# print out performance info
net.PrintProfilerTimes()
