Crop Image with Nvanalytics Labelling and Nvosd Labelling
• DeepStream Version
• TensorRT Version
Hi, I am asking is it possible to crop the frames out, with the Nvanalytics Labelling (ROI, Line, Direction) & Nvosd detection labelling?
n_frame = pyds.get_nvds_buf_surface(hash(gst_buffer), frame_meta.batch_id)
frame_copy = np.array(n_frame, copy=True, order='C')
frame_copy = cv2.cvtColor(frame_copy, cv2.COLOR_RGBA2BGRA)
My current pipeline can crop images, but without any labelling, I need the Nvanalytics & NvOsd labelling.
• TensorRT Version
My pipeline is working fine, just to ask is there any workaround to crop with Nvanalytics & Nvosd output together using the code above
  1. which sample are you testing or referring to? do you mean On the video there is only osd detection labels, but no Nvanalytics Labelling?
  2. nvosd draws all labels on the video. you can set “osd-mode=2” in the configuration file of nvanalytic pulugin for drawing Nvanalytics Labelling (ROI, Line, Direction) with osd. then you can move the code above to the probe function which is added on osd src or after osd.
I have my own pipeline. It is working.
Yes, when i put display sink, the Nvanalytics and Nvosd labelling is drawn on my screen. Is just I would like to take a screenshot of some certain detection using code below
How can i attach the labelling into the buffer so that my screenshot will include the Nvanalytics & Nvosd labelling as well, instead of just a raw image of my video. Currently the probe function is looped on tiler’s pad.
As written in my last comment, you can move the code above to the probe function which is added on osd src or after osd because all labels are drawn by osd not tiler.
There is no update from you for a period, assuming this is not an issue anymore. Hence we are closing this topic. If need further support, please open a new one. Thanks.
