I am working with multiple rtsp streams in Python, the inference is done in an specific area of the frame, to do that, I’m using the src-crop property of the nvvidconv plugin, which works perfectly to clip all streams to the same coordinates.
But what I need is to set a specific crop for each stream because the resolution and my region of interest is different for each camera. So I tried to bind the nvvidconv in the loop where I read the stream and configure and link each source_bin with the sinkpad, but I can’t connect the src with nvvidconv, I got this error: TypeError: sinkpad argument: Expected Gst.Pad, but I got gi.Gstnvvideoconvert.
How can I bind my nvvidconv to the specific crop before the streamux output, or just after the src_bin read?
Thank you so much @Fiona.Chen That was exactly what I needed. I just implemented it in python and it works perfect!!
I just have a question, in the configuration file (config_preprocess.txt) there are defined some dimensions of the network input network-input-shape = 7,3,368,640 processing-width = 640 processing-height = 368
I already read the description of the documentation here (Gst-nvdspreprocess (Alpha) — DeepStream 6.0 Release documentation)) but I still have a doubt, the network-input-shape Should match the size of the network that I have configured in my primary gie, in this case YOLO with an input resolution of width=608, height=608?
When you use gst-nvdspreprocess plugin, the “input-tensor-meta=1” configuration should be configured in gst-nvinfer config file to skip the default pre-processing in gst-nvinfer. Then the tensor data from gst-nvdspreprocess will be input into gst-nvinfer throught correct path.
That setting helped me a lot. Without that line, nvdspreprocess was drawing the green box, but still had predictions outside the ROI, with input-tensor-meta=1 (setting by code in python) it solved, but I also had to rename the tensor from tensor-name=input_1 to tensor-name=data in config_preprocess.txt. (I write it in case it helps someone else)
Thanks for your help.
I still have a problem, that I’ve not been able to fix. For 1 stream it works perfect, it correctly recognizes objects within the ROI, but when I try to use it with multi-streaming I get the following error:
features = <Gst.CapsFeatures object at 0x7f0960be0340 (GstCapsFeatures at 0x7f06dc013da0)>
Custom Lib: Cuda Stream Synchronization failed
Cuda failure: status = 700 in cuResData at line 348
cuGraphicsMapResources failed with error (700) gst_eglglessink_cuda_buffer_copy
CustomTensorPreparation failed
free (): double free detected in tcache 2
Segment violation (generated core)
I was looking at C++ example /opt/nvidia/deepstream/deepstream-6.0/sources/apps/sample_apps/deepstream-preprocess-test/deepstream_preprocess_test.cpp between lines 251 and 351 and there are an extra loop to iterate over the ROI to get the final frames
but in python I get them as shown in the multi-stream example
batch_meta = pyds.gst_buffer_get_nvds_batch_meta(hash(gst_buffer))
l_frame = batch_meta.frame_meta_list
while l_frame is not None:
l_obj=frame_meta.obj_meta_list
while l_obj is not None:
Is it necessary to make a change in this part to fix the error I mentioned or is it due to a different reason? I am somewhat confused with this, if you have an example in python using nvdspreprocess I would really appreciate being able to share it
Yes, I already tried the deepstream-preprocess-test (C++) example on my platform and it had worked fine.
But… what I hadn’t tried is to use my config_preprocess.txt and config_infer_primary_yoloV3.txt configuration files with your example ./deepstream-preprocess-test, and to my surprise in C++ threw me the same Python error.
So, I looked closely at the differences int config_preprocess.txt, at one point I changed the value of tensor-data-type to INT8 (option 3) instead of FP32 (option 0 by default) since in my PGIE I have configured the network with network-mode=1 (INT8) to gain speed, I thought that both should be the same. So when I changed the value in config_preprocess.txt file to default, tensor-data-type=0 (FP32) everything worked perfect.
