I am trying to do the same thing as this link, but with RTSP input instead of CSI camera.
My setup:
Jetson Xavier NX
Jetpack 4.4 DP
Deepstream 5.0.0 DP
I’ve applied the suggested patch to sources\apps\apps-common\src\deepstream_source_bin.c:
} else{
NVGSTDS_LINK_ELEMENT (bin->cap_filter, bin->nvvidconv);
NVGSTDS_LINK_ELEMENT (bin->nvvidconv, bin->cap_filter1);
/// added here, line 888
// also tried to probe source pad of bin->cap_filter and bin->cap_filter1, same result
// probe source pad of bin->src_elem, does not rotate at all
GstPad *src_pad;
src_pad = gst_element_get_static_pad (bin->nvvidconv, "src");
gst_pad_add_probe (src_pad, GST_PAD_PROBE_TYPE_BUFFER,
nvargus_src_pad_buffer_probe, NULL, NULL);
NVGSTDS_BIN_ADD_GHOST_PAD (bin->bin, bin->cap_filter1, "src");
I’ve also made small changes such that it rotates 90 degrees, rather than 180 degrees as in the previous post.
static GstPadProbeReturn
nvargus_src_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
gpointer u_data)
GstBuffer *buf = (GstBuffer *) info->data;
GstMapInfo outmap = GST_MAP_INFO_INIT;
gst_buffer_map (buf, &outmap, GST_MAP_WRITE);
NvBufSurface* surface = (NvBufSurface *)outmap.data;
NvBufSurfTransformRect src_rect, dst_rect;
src_rect.top = 0;
src_rect.left = 0;
src_rect.width = (guint) surface->surfaceList[0].width;
src_rect.height= (guint) surface->surfaceList[0].height;
dst_rect.top = 0;
dst_rect.left = 0;
dst_rect.width = (guint) surface->surfaceList[0].width;
dst_rect.height= (guint) surface->surfaceList[0].height;
NvBufSurface *dst_surface = NULL;
NvBufSurfaceCreateParams nvbufsurface_create_params;
nvbufsurface_create_params.gpuId = surface->gpuId;
nvbufsurface_create_params.width = (gint) surface->surfaceList[0].width;
nvbufsurface_create_params.height = (gint) surface->surfaceList[0].height;
nvbufsurface_create_params.size = 0;
nvbufsurface_create_params.colorFormat = surface->surfaceList[0].colorFormat;
nvbufsurface_create_params.layout = surface->surfaceList[0].layout;
nvbufsurface_create_params.memType = surface->memType;
NvBufSurfaceCreate(&dst_surface,1,&nvbufsurface_create_params);
NvBufSurfTransformParams nvbufsurface_params;
nvbufsurface_params.src_rect = &src_rect;
nvbufsurface_params.dst_rect = &dst_rect;
nvbufsurface_params.transform_flag = 0;
nvbufsurface_params.transform_filter = NvBufSurfTransformInter_Default;
NvBufSurfTransformConfigParams transform_config_params;
NvBufSurfTransform_Error err;
transform_config_params.compute_mode = NvBufSurfTransformCompute_Default;
transform_config_params.gpu_id = surface->gpuId;
transform_config_params.cuda_stream = NULL;
err = NvBufSurfTransformSetSessionParams (&transform_config_params);
// copy to dst_surface
err = NvBufSurfTransform (surface, dst_surface, &nvbufsurface_params);
// rototate 180 degree to original surface
nvbufsurface_params.transform_flag = NVBUFSURF_TRANSFORM_FLIP;
nvbufsurface_params.transform_flip = NvBufSurfTransform_Rotate90;
err = NvBufSurfTransform (dst_surface, surface, &nvbufsurface_params);
NvBufSurfaceDestroy(dst_surface);
gst_buffer_unmap (buf, &outmap);
return GST_PAD_PROBE_OK;
The rotation does work, but it seems like the same frame is being rotated a few times and pushed downstream. So instead of having a 90 degree rotated stream, I have some frames rotated 90, 180, 270, 360 degrees, in that particular order. See the output video (1.0 MB)
This is my config file
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
#gie-kitti-output-dir=streamscl
[tiled-display]
enable=0
rows=4
columns=2
width=1280
height=720
gpu-id=0
nvbuf-memory-type=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI 4=RTSP
type=4
uri=rtsp://192.168.2.216:8554/test
#num-sources=8
#drop-frame-interval=2
latency=200
gpu-id=0
# (0): memtype_device - Memory type Device
# (1): memtype_pinned - Memory type Host Pinned
# (2): memtype_unified - Memory type Unified
cudadec-memtype=0
[sink0]
enable=1
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
#iframeinterval=10
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=testf.mp4
source-id=0
[streammux]
gpu-id=0
##Boolean property to inform muxer that sources are live
live-source=1
batch-size=8
##time out in usec, to wait after the first buffer is available
##to push the batch even if the complete batch is not formed
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
##Enable to maintain aspect ratio wrt source, and allow black borders, works
##along with width, height properties
enable-padding=0
nvbuf-memory-type=0
## If set to TRUE, system timestamp will be attached as ntp timestamp
## If set to FALSE, ntp timestamp from rtspsrc, if available, will be attached
## attach-sys-ts-as-ntp=1
Once again, any help is greatly appreciated.
