Cropped source results into non cropped source
• Hardware Platform (Jetson / GPU) Jetson Nano
• DeepStream Version 6.01
• JetPack Version (valid for Jetson only) 4.6.4
Hey guys i made a gst pipeline for two gies with cropped source, i want to osd in non-cropped video. Can you help me with this.
Here is my pipeline.
gst-launch-1.0 filesrc location= $source_path
! qtdemux ! h264parse ! nvv4l2decoder
! tee name=t
! queue
! nvvideoconvert nvbuf-memory-type=0 src-crop=400:400:600:300
! m.sink_0 nvstreammux name=m batch-size=1 width=600 height=300
! nvinfer config-file-path= $pgie_path
! nvinfer config-file-path= $sgie_path
! nvmultistreamtiler rows=1 columns=1 width=600 height=300
! nvvideoconvert ! nvegltransform ! nveglglessink sync=0
After cropping by nvvideoconvert, the original video is not available any more.
You may inference on the whole frame and filter the boxes outside the ROI in probe function.
Thank you for your quick response.
I now, I lose the original video in this way, what I’m asking, is there a any way to do mapping the bbox for original source shape.
Something like this.
There is a customized plugin needed which align the cropped video with the non-croppped video according to the timestamp if you want to use a pipeline like this. You need to write such plugin by yourself.
Ok, i’ll try and share the result.
Is your answer acceptable for the RTSP live source?
Thank you.
Surely it can be applied to RTSP source too.
