• Hardware Platform (Jetson / GPU) Jetson Xavier AGX • DeepStream Version 5.0.0 • JetPack Version (valid for Jetson only) 4.5 • TensorRT Version 7.1.3
Hello! I am trying to run nvinfer on panoramic image so I am trying to make a batch from 1 source by cropping into multiple square images. I was digging through the example source files but could not find anything useful. Can you suggest any resources for my use-case?
Thank you for your suggestion!
In my limited understanding of GStreamer, I think that will cause a big performance bottleneck. Currently the original source will be 60fps 500x2000 and I plan to crop it into 6 images (some overlapping). So I will have to stream the 500x2000 at 60 fps with 6 sources. Do you think it will be fine?
@bcao Hello! I have been playing around with gst-dsexample but I am not sure how to construct a batch like nvstreammux since it is closed-source. Also, my output buffer size is expected to be larger than the input buffer so I have to use the transform callback. But I saw this Copy on content of input buffer to output buffer - #6 by DaneLLL. Is it still the case? And can you guide me on how to construct a batch?
