I am trying to compile the radar_replay example in Nsight by including external libraries. I have correctly updated all the related CMAKE files in the project and host compilation can be done without any issue. However when I am trying to use the target build configuration to compile the example, the following errors are encountered. Could you please help me with this issue?
Nsight Console Content:
12:43:34 **** Incremental Build of configuration build-target for project DriveNet ****
make all
[ 0%] Built target update_cuda_deps
[ 26%] Built target dw_samples_framework
[ 29%] Built target sample_sensors_info
[ 33%] Built target sample_gps_logger
[ 36%] Built target sample_imu_logger
[ 40%] Built target sample_camera_replay
[ 43%] Built target sample_camera_seek
[ 47%] Built target sample_camera_multiple_replay
[ 52%] Built target sample_camera_usb
[ 57%] Built target sample_camera_pointgrey
[ 61%] Built target sample_record
[ 64%] Built target sample_canbus_logger
[ 70%] Built target sample_canbus_interpreter
[ 75%] Built target sample_lidar_replay
[ 77%] Building CXX object src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o
In file included from /home/conti/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/include/X11/Xlib.h:44:0,
from /home/conti/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/include/EGL/eglplatform.h:119,
from /home/conti/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/include/EGL/egl.h:39,
from /usr/local/driveworks-0.6/targets/aarch64-linux/include/dw/core/EGL.h:49,
from /usr/local/driveworks-0.6/samples-nsight/src/framework/../framework/Window.hpp:34,
from /usr/local/driveworks-0.6/samples-nsight/src/framework/../framework/DriveWorksSample.hpp:41,
from /usr/local/driveworks-0.6/samples-nsight/src/sensors/radar/radar_replay/main.cpp:31:
/usr/local/install/ecal-4.9.4/ecal/include/ecal/ecal_init.h:45:31: error: expected unqualified-id before numeric constant
static const unsigned int None = 0x000;
In file included from /home/conti/NVIDIA/Drive/5050bL_SDK/DriveSDK/drive-t186ref-linux/include/EGL/eglplatform.h:119:0,
/usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/logging.h:66:7: error: expected identifier before 'int'
class Status;
/usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/logging.h:66:7: error: multiple types in one declaration
In file included from /usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/common.h:50:0,
from /usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/descriptor.pb.h:9,
from /usr/local/install/ecal-4.9.4/contrib/ecal_proto/include/ecal/protobuf/ecal_proto_hlp.h:24,
from /usr/local/install/ecal-4.9.4/ecal/include/ecal/msg/proto.h:16,
from /usr/local/driveworks-0.6/samples-nsight/src/sensors/radar/radar_replay/main.cpp:70:
/usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/logging.h:90:32: error: expected ')' before '::' token
LogMessage& operator<^
/usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/logging.h:90:32: error: 'google::protobuf::internal::LogMessage& google::protobuf::internal::LogMessage::operator</usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/logging.h:90:26: error: expected ';' at end of member declaration
/usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include/google/protobuf/stubs/logging.h:90:58: error: expected unqualified-id before 'int'
make[2]: *** [src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o] Error 1
src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/build.make:62: recipe for target 'src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/main.cpp.o' failed
make[1]: *** [src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all] Error 2
make: *** [all] Error 2
CMakeFiles/Makefile2:938: recipe for target 'src/sensors/radar/radar_replay/CMakeFiles/sample_radar_replay.dir/all' failed
Makefile:127: recipe for target 'all' failed
12:43:36 Build Finished (took 1s.714ms)
Toolchain-V4L.cmake
# Copyright (c) 2016, NVIDIA CORPORATION. All rights reserved.
set(CMAKE_SYSTEM_NAME "Linux")
set(CMAKE_SYSTEM_VERSION 1)
set(VIBRANTE_BUILD ON) #flags for the CMakeList.txt
set(CMAKE_SYSTEM_PROCESSOR aarch64)
# need that one here, because this is a toolchain file and hence executed before
# default cmake settings are set
set(CMAKE_FIND_LIBRARY_PREFIXES "lib")
set(CMAKE_FIND_LIBRARY_SUFFIXES ".a" ".so")
# check that Vibrante PDK must be set
if(NOT DEFINED VIBRANTE_PDK)
if(DEFINED ENV{VIBRANTE_PDK})
message(STATUS "VIBRANTE_PDK = ENV : $ENV{VIBRANTE_PDK}")
set(VIBRANTE_PDK $ENV{VIBRANTE_PDK} CACHE STRING "Path to the vibrante-XXX-linux path for cross-compilation" FORCE)
endif()
else()
message(STATUS "VIBRANTE_PDK = ${VIBRANTE_PDK}")
endif()
if(DEFINED VIBRANTE_PDK)
if(NOT IS_ABSOLUTE ${VIBRANTE_PDK})
get_filename_component(VIBRANTE_PDK "${SDK_BINARY_DIR}/${VIBRANTE_PDK}" ABSOLUTE)
endif()
endif()
set(ARCH "aarch64")
set(VIBRANTE TRUE)
set(VIBRANTE_V5L TRUE)
add_definitions(-DVIBRANTE -DVIBRANTE_V5L)
set(TOOLCHAIN "${VIBRANTE_PDK}/../toolchains/tegra-4.9-nv")
set(CMAKE_CXX_COMPILER "${TOOLCHAIN}/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-g++")
set(CMAKE_C_COMPILER "${TOOLCHAIN}/usr/bin/aarch64-gnu-linux/aarch64-gnu-linux-gcc")
set(GCC_COMPILER_VERSION "4.9" CACHE STRING "GCC Compiler version")
# setup compiler for cross-compilation
set(CMAKE_CXX_FLAGS "-fPIC" CACHE STRING "c++ flags")
set(CMAKE_C_FLAGS "-fPIC" CACHE STRING "c flags")
set(CMAKE_SHARED_LINKER_FLAGS "" CACHE STRING "shared linker flags")
set(CMAKE_MODULE_LINKER_FLAGS "" CACHE STRING "module linker flags")
set(CMAKE_EXE_LINKER_FLAGS "" CACHE STRING "executable linker flags")
set(LD_PATH ${VIBRANTE_PDK}/lib-target)
set(LD_PATH_EXTRA ${VIBRANTE_PDK}/targetfs/lib/aarch64-linux-gnu)
# Please, be carefull looks like "-Wl,-unresolved-symbols=ignore-in-shared-libs" can lead to silent "ld" problems
set(CMAKE_SHARED_LINKER_FLAGS "-L${LD_PATH} -L${LD_PATH_EXTRA} -Wl,-rpath,${LD_PATH} ${CMAKE_SHARED_LINKER_FLAGS}")
set(CMAKE_MODULE_LINKER_FLAGS "-L${LD_PATH} -L${LD_PATH_EXTRA} -Wl,-rpath,${LD_PATH} ${CMAKE_SHARED_LINKER_FLAGS}")
set(CMAKE_EXE_LINKER_FLAGS "-L${LD_PATH} -L${LD_PATH_EXTRA} -Wl,-rpath,${LD_PATH} ${CMAKE_EXE_LINKER_FLAGS}")
# Set cmake root path. If there is no "/usr/local" in CMAKE_FIND_ROOT_PATH then FinCUDA.cmake doesn't work
set(CMAKE_FIND_ROOT_PATH ${VIBRANTE_PDK} ${VIBRANTE_PDK}/targetfs/usr/local/ ${VIBRANTE_PDK}/targetfs/ /usr/local)
# search for programs in the build host directories
set(CMAKE_FIND_ROOT_PATH_MODE_PROGRAM NEVER)
# for libraries and headers in the target directories
set(CMAKE_FIND_ROOT_PATH_MODE_LIBRARY ONLY)
set(CMAKE_FIND_ROOT_PATH_MODE_INCLUDE ONLY)
# set system default include dir
include_directories(BEFORE SYSTEM ${VIBRANTE_PDK}/include
#/usr/local/install/ecal-4.9.4/ecal/include
#/usr/local/install/ctzs_dependencies-eCAL_v4.9.4/libprotobuf3/include
# determine target device and pdk branch
if(NOT DEFINED VIBRANTE_PDK_DEVICE AND VIBRANTE_PDK)
if(${VIBRANTE_PDK} MATCHES "(vibrante|drive)-(t.+)-linux$")
set(VIBRANTE_PDK_DEVICE ${CMAKE_MATCH_2} CACHE STRING "Cross-compilation target device")
message(STATUS "VIBRANTE_PDK_DEVICE = ${VIBRANTE_PDK_DEVICE}")
else()
message(FATAL_ERROR "Can't determine target device for PDK: ${VIBRANTE_PDK}")
endif()
endif()
if(NOT DEFINED VIBRANTE_PDK_BRANCH AND VIBRANTE_PDK)
if(EXISTS "${VIBRANTE_PDK}/lib-target/version-nv-pdk.txt")
set(VIBRANTE_PDK_FILE "${VIBRANTE_PDK}/lib-target/version-nv-pdk.txt")
elseif(EXISTS "${VIBRANTE_PDK}/lib-target/version-nv-sdk.txt")
set(VIBRANTE_PDK_FILE "${VIBRANTE_PDK}/lib-target/version-nv-sdk.txt")
endif()
if(VIBRANTE_PDK_FILE)
file(READ ${VIBRANTE_PDK_FILE} version-nv-pdk)
if(${version-nv-pdk} MATCHES "^(.+)-[0123456789]+")
set(VIBRANTE_PDK_BRANCH ${CMAKE_MATCH_1} CACHE STRING "Cross-compilation PDK branch name")
message(STATUS "VIBRANTE_PDK_BRANCH = ${VIBRANTE_PDK_BRANCH}")
else()
message(FATAL_ERROR "Can't determine PDK branch for PDK ${VIBRANTE_PDK}")
endif()
else()
message(FATAL_ERROR "Can't open ${VIBRANTE_PDK}/lib-target/version-nv-(pdk/sdk).txt for PDK branch detection")
endif()
endif()
if(DEFINED VIBRANTE_PDK_BRANCH)
string(REPLACE "." ";" PDK_VERSION_LIST ${VIBRANTE_PDK_BRANCH})
# Some PDK's have less than three version numbers. Pad the list so we always
# have at least three numbers, allowing pre-existing logic depending on major,
# minor, patch versioning to work without modifications
list(LENGTH PDK_VERSION_LIST _PDK_VERSION_LIST_LENGTH)
while(_PDK_VERSION_LIST_LENGTH LESS 3)
list(APPEND PDK_VERSION_LIST 0)
math(EXPR _PDK_VERSION_LIST_LENGTH "${_PDK_VERSION_LIST_LENGTH} + 1")
endwhile()
set(VIBRANTE_PDK_PATCH 0)
set(VIBRANTE_PDK_BUILD 0)
list(LENGTH PDK_VERSION_LIST PDK_VERSION_LIST_LENGTH)
list(GET PDK_VERSION_LIST 0 VIBRANTE_PDK_MAJOR)
list(GET PDK_VERSION_LIST 1 VIBRANTE_PDK_MINOR)
if(PDK_VERSION_LIST_LENGTH GREATER 2)
list(GET PDK_VERSION_LIST 2 VIBRANTE_PDK_PATCH)
endif()
if(PDK_VERSION_LIST_LENGTH GREATER 3)
list(GET PDK_VERSION_LIST 3 VIBRANTE_PDK_BUILD)
endif()
set(VIBRANTE_PDK_VERSION ${VIBRANTE_PDK_MAJOR}.${VIBRANTE_PDK_MINOR}.${VIBRANTE_PDK_PATCH}.${VIBRANTE_PDK_BUILD})
add_definitions(-DVIBRANTE_PDK_VERSION=\"${VIBRANTE_PDK_VERSION}\") # requires escaping so it is treated as a string
# and not an invalid floating point with too many decimal points
add_definitions(-DVIBRANTE_PDK_MAJOR=${VIBRANTE_PDK_MAJOR})
add_definitions(-DVIBRANTE_PDK_MINOR=${VIBRANTE_PDK_MINOR})
add_definitions(-DVIBRANTE_PDK_PATCH=${VIBRANTE_PDK_PATCH})
add_definitions(-DVIBRANTE_PDK_BUILD=${VIBRANTE_PDK_BUILD})
message(STATUS "Vibrante version ${VIBRANTE_PDK_VERSION}")
endif()
