I want to know if there is a way to cross-compile for the Jetson Orin Nano from a Windows computer, using either WSL, Docker, or a virtual machine.
This environment is not supported. Please use host PC in Linux Ubuntu system.
Thank you very much for the quick reply. I have one more question: what about the Cross Compilation Container? Can this be used on Windows via Docker or is it only work in Linux?
The container is for x86 host PC in Linux Ubuntu. You may try it on Windows via Docker but it is not tested, so may not work.
Thank you very much. I understand this.
