Please provide the following info (check/uncheck the boxes after creating this topic): Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
[*] DRIVE OS Linux 5.2.0 and DriveWorks 3.5
other DRIVE OS version
other
I followed your post and github link.
Until Cross-Compile ROS step everything worked fine.
At this step I’m facing the below CMake error and unable to find any reference to resolve it.
<== Finished processing package [53 of 57]: 'rostopic'
==> Processing catkin package: 'topic_tools'
==> Creating build directory: 'build_isolated/topic_tools'
==> Building with env: '/home/lidar/ros_catkin_ws/install_isolated/env.sh'
==> cmake /home/lidar/ros_catkin_ws/src/ros_comm/topic_tools -DCATKIN_DEVEL_PREFIX=/home/lidar/ros_catkin_ws/devel_isolated/topic_tools -DCMAKE_INSTALL_PREFIX=/home/lidar/ros_catkin_ws/install_isolated -DCMAKE_BUILD_TYPE=Release -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_INCLUDE_DIR=/usr/include/python3.7m -DCMAKE_TOOLCHAIN_FILE=~/Downloads/Toolchain-V5L.cmake -G Unix Makefiles in '/home/lidar/ros_catkin_ws/build_isolated/topic_tools'
-- The C compiler identification is GNU 7.3.1
-- The CXX compiler identification is GNU 7.3.1
-- Check for working C compiler: /home/lidar/Documents/Nvidia_Drive/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc
-- Check for working C compiler: /home/lidar/Documents/Nvidia_Drive/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-gcc - works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /home/lidar/Documents/Nvidia_Drive/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++
-- Check for working CXX compiler: /home/lidar/Documents/Nvidia_Drive/DRIVE_OS_5.2.0_SDK_Linux_OS_DRIVE_AGX_XAVIER/DRIVEOS/toolchains/gcc-linaro-7.3.1-2018.05-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu-g++ - works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Using CATKIN_DEVEL_PREFIX: /home/lidar/ros_catkin_ws/devel_isolated/topic_tools
-- Using CMAKE_PREFIX_PATH: /home/lidar/ros_catkin_ws/install_isolated
-- This workspace overlays: /home/lidar/ros_catkin_ws/install_isolated
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.6.9", minimum required is "2")
-- Using PYTHON_EXECUTABLE: /usr/bin/python3
-- Using Debian Python package layout
-- Found PY_em: /home/lidar/.local/lib/python3.6/site-packages/em.py
-- Using empy: /home/lidar/.local/lib/python3.6/site-packages/em.py
-- Using CATKIN_ENABLE_TESTING: ON
-- Call enable_testing()
-- Using CATKIN_TEST_RESULTS_DIR: /home/lidar/ros_catkin_ws/build_isolated/topic_tools/test_results
-- gtest not found, C++ tests can not be built. Please install the gtest headers globally in your system to enable gtests
-- Using Python nosetests: /usr/bin/nosetests3
-- catkin 0.7.29
-- BUILD_SHARED_LIBS is on
-- Using these message generators: gencpp;geneus;genlisp;gennodejs;genpy
-- topic_tools: 0 messages, 8 services
CMake Warning at /home/lidar/ros_catkin_ws/install_isolated/share/catkin/cmake/test/gtest.cmake:160 (message):
skipping gtest 'topic_tools-utest' in project 'topic_tools' because gtest
was not found
Call Stack (most recent call first):
/home/lidar/ros_catkin_ws/install_isolated/share/catkin/cmake/test/gtest.cmake:89 (_catkin_add_executable_with_google_test)
/home/lidar/ros_catkin_ws/install_isolated/share/catkin/cmake/test/gtest.cmake:37 (_catkin_add_google_test)
CMakeLists.txt:85 (catkin_add_gtest)
-- Configuring done
CMake Error at CMakeLists.txt:96 (add_dependencies):
The dependency target "topic_tools-test_shapeshifter" of target "tests"
does not exist.
-- Generating done
CMake Warning:
Manually-specified variables were not used by the project:
PYTHON_INCLUDE_DIR
CMake Generate step failed. Build files cannot be regenerated correctly.
<== Failed to process package 'topic_tools':
Command '['/home/lidar/ros_catkin_ws/install_isolated/env.sh', 'cmake', '/home/lidar/ros_catkin_ws/src/ros_comm/topic_tools', '-DCATKIN_DEVEL_PREFIX=/home/lidar/ros_catkin_ws/devel_isolated/topic_tools', '-DCMAKE_INSTALL_PREFIX=/home/lidar/ros_catkin_ws/install_isolated', '-DCMAKE_BUILD_TYPE=Release', '-DPYTHON_EXECUTABLE=/usr/bin/python3', '-DPYTHON_INCLUDE_DIR=/usr/include/python3.7m', '-DCMAKE_TOOLCHAIN_FILE=~/Downloads/Toolchain-V5L.cmake', '-G', 'Unix Makefiles']' returned non-zero exit status 1
Reproduce this error by running:
==> cd /home/lidar/ros_catkin_ws/build_isolated/topic_tools && /home/lidar/ros_catkin_ws/install_isolated/env.sh cmake /home/lidar/ros_catkin_ws/src/ros_comm/topic_tools -DCATKIN_DEVEL_PREFIX=/home/lidar/ros_catkin_ws/devel_isolated/topic_tools -DCMAKE_INSTALL_PREFIX=/home/lidar/ros_catkin_ws/install_isolated -DCMAKE_BUILD_TYPE=Release -DPYTHON_EXECUTABLE=/usr/bin/python3 -DPYTHON_INCLUDE_DIR=/usr/include/python3.7m '-DCMAKE_TOOLCHAIN_FILE=~/Downloads/Toolchain-V5L.cmake' -G 'Unix Makefiles'
I have already fixed many issue which occurred during the setup except this one.
Please advice as how to resolve it.
(base) bin$ sudo -b X -ac -noreset -nolisten tcp
[sudo] password for nvidia:
(base) bin$ _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
_XSERVTransMakeAllCOTSServerListeners: server already running
(EE)
Fatal server error:
(EE) Cannot establish any listening sockets - Make sure an X server isn't already running(EE)
(EE)
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
(EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
(EE)
(EE) Server terminated with error (1). Closing log file.
(base) bin$ rosrun image_view image_view image:=/cameraData _autosize:=True
[ INFO] [1655365375.117176759]: Initializing nodelet with 7 worker threads.
[ERROR] [1655365375.541319789]: Failed to load nodelet [/image_view] of type [image_view/image] even after refreshing the cache: Failed to load library /opt/ros/melodic/lib//libimage_view.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /usr/lib/libgdal.so.20: undefined symbol: _ZN11xercesc_3_211InputSource11setEncodingEPKDs)
[ERROR] [1655365375.541469551]: The error before refreshing the cache was: Failed to load library /opt/ros/melodic/lib//libimage_view.so. Make sure that you are calling the PLUGINLIB_EXPORT_CLASS macro in the library code, and that names are consistent between this macro and your XML. Error string: Could not load library (Poco exception = /usr/lib/libgdal.so.20: undefined symbol: _ZN11xercesc_3_211InputSource11setEncodingEPKDs)
Yes, I tried to reboot the system but the issue remains. Actually the target is currently deployed on a vehicle and not connected to the host so without starting the desktop I cannot run the commands. I’ll try that once I have another system connected to target.
Actually I wrote a python code which is able to subscribe and visualise the published data from nv_sensors_producer executable by subscribing to the “cameraData” topic.
