Cross compile camera sample application using NSight.
Has anyone tried cross-compiling /samples/09_camera_jpeg_capture using NSight Or any of those samples for that matter? I would like to know how the project is set with these examples. How to make NSight project see tegra rootfs? I started with 09_camera_jpg_capture example to understand Argus APIs.
Hi, we don’t support cross-compile of the samples. You need to build them on target(TX1 or TX2).
I was able to cross-compile camera example using Qt5.9.1 and ran binary on TX1 but was not able to with NSight. I’d like to step thru camera example code using Nsight. Thanks.
We don’t officially support cross-compile, but it is good to know you have it work. Some other users may share experience about NSight. Thanks.
