Cross compile couldn't find dnn related libs
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
While I was following the Samples Cross-Compilation From Source segment in this documentation:
https://developer.nvidia.com/docs/drive/drive-os/6.0.6/public/driveworks-nvsdk/dwx_devguide_getting_started_drive_sdk_ngc_sdk_docker_container.html
I got the following out put form the terminal:
make.log (70.3 KB)
cmake.log (81.9 KB)
Though I did build the excutables, but dnn related samples such as sample_object_detector_tracker doesn’t seem to work correctly.
Dear @jiayu.yang,
It is a known issue( 3931886) reported in release notes (https://developer.download.nvidia.com/drive/secure/drive-sdk/docs/NVIDIA_DRIVE_OS_6.0.6_Linux_Release_Notes-3.pdf?9j28HQ-n9zMdwQHkw2-x-_1wMt6aR-uTHfX32IDvu7cGly-czFpXM24Iy5Hteh3xIN3aCLTqeHdqTVfyoMHUyMn4P_fGwfyZ5JoZxo_DhPGOVml2b95bzSQ48UPWBIzlJXKGYLyfVl-Rf5dmOwnUhQ5Cp8lnOETctTQNzr8qYhyhEwc7QBVCZP83&t=eyJscyI6ImdzZW8iLCJsc2QiOiJodHRwczovL3d3dy5nb29nbGUuY29tLyJ9)
In the release note it says
DNN samples don’t support Caffe models, detection will not work
properly with the default models.
So is there any way around to make it work?
Dear @jiayu.yang,
There is no work around for it and fix is implemented in next DW version already. We don’t have visibility on exact release date to communicate.
