I am trying to cross compile Qt for Jetson Nano. I configured the build with these parameters:
../qt-everywhere-src-5.15.1/configure -opengl es2 -device linux-jetson-nano -device-option CROSS_COMPILE=/opt/qt5jetson/gcc-linaro-7.5.0-2019.12-x86_64_aarch64-linux-gnu/bin/aarch64-linux-gnu- -sysroot /opt/qt5jetson/sysroot -prefix /usr/local/qt5jetson -opensource -confirm-license -skip qtscript -skip wayland -skip qtwebengine -force-debug-info -skip qtdatavis3d -nomake examples -make libs -pkg-config -v
when I tried to run make command I got error like below. I can’t find solution for this problem.
final link failed: Bad value
collect2: error: ld returned 1 exit status
Makefile:1227: recipe for target '../../lib/libQt5Core.so.5.15.1' failed
make[3]: *** [../../lib/libQt5Core.so.5.15.1] Error 1
make[3]: Leaving directory '/opt/qt5jetson/qt5build/qtbase/src/corelib'
Makefile:224: recipe for target 'sub-corelib-make_first' failed
make[2]: *** [sub-corelib-make_first] Error 2
make[2]: Leaving directory '/opt/qt5jetson/qt5build/qtbase/src'
Makefile:50: recipe for target 'sub-src-make_first' failed
make[1]: *** [sub-src-make_first] Error 2
make[1]: Leaving directory '/opt/qt5jetson/qt5build/qtbase'
Makefile:83: recipe for target 'module-qtbase-make_first' failed
make: *** [module-qtbase-make_first] Error 2"
How can I solve for this problem?
