Cross-compile the program for Orin within Docker
I would like to use the container from JetPack Cross Compilation container | NVIDIA NGC for cross-compiling. However, my C++ package depends on pcl, which is installed using apt install and relies on CUDA and TensorRT. What should I do?
Unfortunately, TensorRT doesn’t have public cross-compile packages currently.
If I can rely on TensorRT, I only need CUDA.
If your application only needs CUDA, the container should meet your requirements.
But if the application needs to link to TensorRT libraries as well, this is not supported.
I need cuda, but I also need pcl installed with apt as well, how does this cross compile successfully?
Does pcl contain a cross-compiling toolkit?
If yes, suppose you can install it within the container.
Sorry, we don’t have too much experience with pcl+cross-compile.
It’s recommended to give it a try and let us know if you met any issues.
We have a lot of c++ 3rdparty libraries that we installed via apt, but we can’t get them via this container, so I’m confused when cross-compiling.
Could you share more info about the issue?
Is there any issue or error when installing them on the container?
I use cmake’s DCMAKE_TOOLCHAIN_FILE and SYSROOT to cross-compile, and I can’t have my apt-installed packages in the targetfs you provide for cross-compiling. How can I cross-compile properly?
Could you share more about your use case?
The container is used for cross-compiling an application that runs on the Jetson device.
Do you want to build a custom L4T image that is used for flashing?
